52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Fri Mar 15, 2024 8:29 pm Post subject: 383 distributor |
does a 383 have a mark for #1 cylinder.could not see one. could someone show me where #1 should be located on the cap.and or rotor pointing on housing thanks |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Fri Mar 15, 2024 11:32 pm Post subject: Re: 383 distributor |
The rotor should point near the right side of the Bosch 383 badge for #1 cyl tdc _________________ Jack Staggs
Actual name |
Posted: Sat Mar 16, 2024 10:23 pm Post subject: Re: 383 distributor |
thanks ,looks like a reputable So Cal builder had an off day, drive gear in wrong, now rotor points to a faint mark on housing to the right as you said. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76966 Location: Sneaking up behind you
Posted: Sun Mar 17, 2024 5:03 am Post subject: Re: 383 distributor |
[/img] _________________ Glenn
Member #1009
#BlueSquare |
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Sun Mar 17, 2024 5:12 am Post subject: Re: 383 distributor |
Glenn, does the split distributor have number three lobe off 90 degrees like later ones? |
Glenn Mr. 010
Posted: Sun Mar 17, 2024 5:26 am Post subject: Re: 383 distributor |
I've never seen one come from Bosch that has a #3 mark. If so, it's been added. _________________ Glenn
Member #1009
#BlueSquare |
DDub Samba Member
Posted: Sun Mar 17, 2024 7:36 am Post subject: Re: 383 distributor |
Sorry I was not clear. I meant that the cam is ground to compensate for number 3 overheating. I had read that later ones were done that way, just wondering if 383s were. I have not put one on a distributor machine to check. |
Glenn Mr. 010
Posted: Sun Mar 17, 2024 7:39 am Post subject: Re: 383 distributor |
They were not.
The #3 retard of 3* was on the 68-71 aluminum distributor. The switch to the offset cooler negated the need for the retard. _________________ Glenn
Member #1009
#BlueSquare |
DDub Samba Member
Posted: Sun Mar 17, 2024 8:36 am Post subject: Re: 383 distributor |
Thank you. I was not sure when they did it but was sure you were the guy to ask. |
Posted: Tue Mar 19, 2024 12:26 pm Post subject: Re: 383 distributor |
thanks for the pic Glen. |
