69Bugme Samba Member
Posted: Fri Feb 23, 2024 8:42 pm Post subject: Help |
My first Beetle 1969. Runs great, then dies at stop. Four times now in three weeks. Cranks fine, battery strong. After 30 minutes it starts. I changed out coil, plug wires, condenser, then went to dual Empi carbs and headers. It’s a stock 1600 cc single port. This thing rips.
Today, dies at stop sign. Cranks won’t start. Wait 40 minutes and it starts. Engine is not over heating. What say you? |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4525 Location: Oklahoma City, OK
Posted: Sat Feb 24, 2024 3:24 am Post subject: Re: Help |
Plugged fuel outlet in tank, or inline filter or both. Outlet in tank has a mesh screen like a filter that can get clogged from years of debris and rust. |
Schatzievw Samba Member
Posted: Sat Feb 24, 2024 8:16 am Post subject: Re: Help |
Another possibility is an intermittent ignition switch or harness connector on bottom of steering column. |
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Sat Feb 24, 2024 8:49 am Post subject: Re: Help |
Could it be vapor lock? The old trick was to put a couple wooden clothes pins on the fuel line. _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Sat Feb 24, 2024 3:14 pm Post subject: Re: Help |
Still have the smell. Most think it’s vapor lock but my mechanic still thinks electrical. Just dropped it off. We’ll see. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3592 Location: viroqua wi.
Posted: Sat Feb 24, 2024 3:20 pm Post subject: Re: Help |
Sticky needle, Or one spec of fuel hose in the bowl. |
Posted: Sun Feb 25, 2024 7:52 am Post subject: Re: Help |
Carbs are brand new, just installed. Happened with old carb too. I’ll let y’all know what mechanic finds. All my research points to vapor lock. |
Posted: Sun Mar 03, 2024 8:57 am Post subject: Re: Help |
Fuel leak was found in soft line just before copper line. It was leaking into heater duct so no spots on the ground.
Starts great when cold. When warm it sometimes won’t start. If you put the gas pedal to floor it fires right up. We will change out fuel pump next. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9779 Location: Oregon
Posted: Sun Mar 03, 2024 10:14 am Post subject: Re: Help |
69Bugme wrote: |
The throttle application when warm is quite normal.
I can't find the correct page in the owners manual. But it is listed as a normal operation for hot start up.
If your car is running and driving great. Live with it for now. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sun Mar 03, 2024 10:46 am Post subject: Re: Help |
67rustavenger wrote: |
69Bugme wrote: |
If your car is running and driving great. Live with it for now. |
Page 18, at temps above freezing point or when engine is still warm...From the August 1968 manual for 1969 in the technical dropdown. _________________ 1964 Sedan 6 volt |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1385 Location: Wichita, KS
Posted: Sun Mar 03, 2024 11:02 am Post subject: Re: Help |
69Bugme wrote: |
69Bugme wrote: |
I changed out coil, plug wires, condenser, then went to dual Empi carbs and headers. It’s a stock 1600 cc single port. |
Note that the owner's manual instructions are for stock engine and carb setup.
But with dual aftermarket carbs & etc. modifications, it's anybody's guess as to what will work or not -- each mod job is a law unto itself... _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Sun Mar 03, 2024 11:17 am Post subject: Re: Help |
69Bugme wrote: |
...then went to dual Empi carbs... |
baldessariclan wrote: |
But with dual aftermarket carbs & etc. modifications, it's anybody's guess as to what will work or not -- each mod job is a law unto itself... |
Welp, reading helps. Thoughts it was stock stuff. Good luck! _________________ 1964 Sedan 6 volt |
Posted: Tue Mar 19, 2024 12:31 pm Post subject: Re: Help |
All is well. Turns out that it was the fuel pump. Starts and runs perfect. Thanks all. |
