70bus Samba Member
Posted: Wed Feb 21, 2024 1:32 am Post subject: Gas tank fitment |
I put the gas tank in tonight, and I am not happy with it.
First I had to decide which fasteners to use on the sender
Those nylon washers didn’t even fit the holes, and neither those nor the Wolfsburg West screws (center) were long enough t for the better gaskets, so bolts it is. VW spec’d 5x25 but I went with 20. 25 is really long, and I’d rather keep the bottom of them out of the gas. Hooked up sender and hit the ignition and the gauge goes up, gauge goes down, gauge goes up… full and E needle positions seemed appropriate.
However, I do not like the way the tank fits. It seems to rock on a high bit near the center, and does not seat properly on the fuel tap hole. It seems to tilt a bit to rear as well.
Yes the felts are in the wrong place; I found a good pic of where they go later.
I don’t think it’s the fault of the WW tank; more likely it’s a combo of a beat up truck, aftermarket metal, and maybe the tank. It’s possible that drawing down the straps will pull it level towards the front but it seems unlikely. Filler looks ok, but not sure how far it should stick out!
Anyone else with a replacement floor in this area have issues? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
"If Von Dutch was alive, he'd walk in there with a pistol and shoot these people."
-Robert Williams |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24774 Location: Olympia Wash Rinse & Repeat
Posted: Wed Feb 21, 2024 10:55 am Post subject: Re: Gas tank fitment |
Sorry, but that hole in the image below looks fugly:
The panel hole for the bottom of the tank should be rounded with no holes in the corners for water and mud to get up under the tank.
Tank neck should stick up as much as any other bus. _________________ In Stereo, Where Available! |
Posted: Wed Feb 21, 2024 10:58 am Post subject: Re: Gas tank fitment |
Post-1967 bus example shown in the image below:
Same hole with nice even upward turned lip to work properly with the seal under the tank. At the very least you need to weld up the corners on the sheet metal you have now. _________________ In Stereo, Where Available! |
Kb65single Samba Member
Posted: Wed Feb 21, 2024 11:15 am Post subject: Re: Gas tank fitment |
My gas tank hole. Sorry the picture isn't close enough. Seems like the lip around the hole might be too tall. From previous posts you state you don't have a welder. Maybe take the tank out and grind that lip down. Looks like the hole is to small. Sorry I'm in AZ or I would measure.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14280 Location: Casa de Oro, California
Posted: Wed Feb 21, 2024 6:55 pm Post subject: Re: Gas tank fitment |
70bus wrote: |
How did you make the threads and washers bulletproof against fuel migration? |
70bus Samba Member
Posted: Wed Feb 21, 2024 11:14 pm Post subject: Re: Gas tank fitment |
I coated the threads with Gasgacinch, as well as under the washers, but I'm open to better solutions! _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Thu Feb 22, 2024 5:17 am Post subject: Re: Gas tank fitment |
I think you win for most new threads started in the past year. |
70bus Samba Member
Posted: Thu Feb 22, 2024 11:11 am Post subject: Re: Gas tank fitment |
Cool! Did I win a new bus?
I do dig through the old posts for answers, but if I don't see one, I ask. I found I get fewer responses to a question if it was just in my truck's page, so a new thread it is. Sincere apologies I have such a boring bus for so much space... _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
Clara Samba Member
Posted: Thu Feb 22, 2024 11:29 am Post subject: Re: Gas tank fitment |
originally they used bolts. Not sure of the length _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
70bus Samba Member
Posted: Fri Feb 23, 2024 10:07 pm Post subject: Re: Gas tank fitment |
N 10 209 1 Bolt hex. head M 5x25… 5 As I said I used 20mm.
Ok, so the tank seems fine; certainly didn’t see any complaints about WW tanks besides leaky necks at some point.
Setting tank level sets the tap at an angle and setting tap level…
Well, that doesn’t seem right
So I assume the angle makes a little sump below the tap level to catch debris etc.
Looking inside there is definitely a hump at the center seam
Small but enough to make the tank not sit right. Everything below is straight, so I guess it’s the overlap of floor panels. Nothing to be done about that!
Oh, I assume this is correct on strap attachment?
The hole
Is larger than the gasket for it by a few mm. Ugly edge work. If I put on the tap and place the tank where it likes, the tap is here
If I move the tap away from the edge, it leaves a hellacious gap.
I am not impressed with this panel. I guess I’ll have to sit the tank where’s its most stable and has adequate clearance for the tap, and fill that huge gap as best I can. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
Posted: Sat Feb 24, 2024 5:34 am Post subject: Re: Gas tank fitment |
The hole does appear to be the problem. If the lip is too tall can it be flattened to lessen the stability problem and fill some of the gap? Hammer and dolly? Maybe just on one side? I don't have a bus or truck without a tank handy to look at but I seem to remember that the area around there is not flat and has some profile to match the tank shape |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 370 Location: Mississippi
Posted: Sat Feb 24, 2024 6:55 am Post subject: Re: Gas tank fitment |
3 pound hammer and various pieces of wood pound away at the high spots using the wood to cushion the hammer blows.
Good Luck! _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
Posted: Sat Feb 24, 2024 9:32 am Post subject: Re: Gas tank fitment |
70bus wrote: |
No that strap anchoring is totally bogus.
Sump in the tank can be reduced by removing the shorter fuel tap pipe.
That will reduce water in the tank so it does not rust out in that sump area. Easier to pull the carb float chamber plug to drain any water that gets into the system. _________________ In Stereo, Where Available! |
70bus Samba Member
Posted: Sat Feb 24, 2024 11:00 am Post subject: Re: Gas tank fitment |
Bogus in what way? All I could see in archives is 'fold it over' and not much clearer in the shop manual. How does it go? I did think 'that won't hold up long in an accident' so glad to hear it can be improved.
I'll fold down the front lip and see if that helps close the gap. Panel is at least thick enough to not need it for reinforcement. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
Posted: Sat Feb 24, 2024 11:44 am Post subject: Re: Gas tank fitment |
70bus wrote: |
Bogus in what way? All I could see in archives is 'fold it over' and not much clearer in the shop manual. How does it go? I did think 'that won't hold up long in an accident' so glad to hear it can be improved. |
You want the end of that strap to be a little longer coming out that forward side. Then bend that end backward into the rear slot that the strap end that comes out of to go over the tank. What you are trying to do is to have the longer rear part of the strap to clamp down on that end when it is tightened down on the tank. Kind of like putting your right foot hard onto your left foot, then the left just can not move. Hope that makes sense! _________________ In Stereo, Where Available! |
70bus Samba Member
Posted: Sat Feb 24, 2024 8:24 pm Post subject: Re: Gas tank fitment |
Looking at the damage to the truck, it's possible it always had a bend in the middlle...
Too bad that mat is there!
That strap didn't come back with the truck, but it looks longer than the ones I bought - what should be the strap length in a truck? Note that the last person to fool with the straps also did it incorrectly - like me, it is simply folded once.
I don't see any obvious faults in rebuilding.
The 2mm hump in center can probably be dealt with easily, but that tap hole is gonna be a pain to get right... from the shots of the original floor, the repro hole looks too close to the divider supports, but that could be the angle of pics. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
70bus Samba Member
Posted: Tue Feb 27, 2024 11:39 pm Post subject: Re: Gas tank fitment |
Talking to the body shop, these repro panels do not come with the tap hole punched out like factory did; they must be cut out. So the location is a bit imprecise, the ‘lips’ are not exact, and the corners are not formed as stock. I get to massage them as best I can; rather than cut or grind (non-reversible) I’ll bend the edges for a better fit.
Also, I note from the pic of my bus when hauled out of field, that I managed to get the sender wire hole 180 degrees from proper spot. Sigh. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
70bus Samba Member
Posted: Sat Mar 02, 2024 12:05 pm Post subject: Re: Gas tank fitment |
Thanks to Kb65single, I think I've found the problem.
Kb's original tap hole
Mine
Measurements from his gas tank divider metal at the floor. 2 3/8" and 5 1/8" front and back. the hole is 4 7/8" from side to side (no pic)
So my hole is roughly 1/2" too far forward. In addition, it is about the same amount too far over to passenger side. A pain in the ass, but fixable. I am not going to complain too much about it to the body shop - after all, I measured verrry carefully and still managed to put the sender wire hole in the wrong place. I will need to bend down some metal and cut some. I wonder if I can find my air nibbler, if it will cut this gauge, and if my sausage compressor can keep up with it. Otherwise it's hacksaw time :P
For others putting in new floors, here are the measurements:
Tap 'valley' is 10mm deep measured from top of ribs
Higher on the passenger side by 9mm
Lip is 2-3mm tall
Where the sender hole should go (you are facing rearward)
Mine is at top
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
70bus Samba Member
Posted: Fri Mar 08, 2024 8:22 pm Post subject: Re: Gas tank fitment |
Was told 'dude it's a gas tank' often enough to plow ahead rather than start sawing the hole to slightly different position. Even 2 gaskets leaves a bit of daylight visible around tap hole but otherwise it seems... done. Not great, but done. I'll caulk the areas I can see have gaps. Still think the tap is a little too close to frame, and it looks like that's going to affect my reserve assembly; not sure it will work at such an angle.
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
