Root_Werks Samba Member
Joined: December 31, 2007 Posts: 818 Location: San Juan Islands
Posted: Thu Feb 15, 2024 3:23 pm Post subject: The Berg 5 Speed Thread |
Wanted to start a thread specifically for Berg 5 Speed conversions. There are a few build threads out there, but no real one-source for experiences, trail and errors etc.
I'll start with my build (which I had to twice):
Rhino case, Super Diff built for a Swing.
Originally built with gears:
3.78, 2.25, 1.56, 1.22 .89 on 3.88 R&P
I ran this setup for about 1,500 miles and just didn't like that 4th was close to 3rd in the RPM spread. So out the transmission goes to a different builder more local to me.
Current gears:
3.78, 2.25, 1.48, 1.04, .82 on 3.88 R&P
The RPM spread is SO much nicer and if I need to, can run 60MPH in 4th for long freeway grades too steep for the .82. Keep the head temps down. I've been running these gears for 500 miles and loving them. So far, no head temp issues in 5th on long freeway runs.
I'll see if I can get a few pictures up.
_________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Feb 15, 2024 3:27 pm Post subject: Re: The Berg 5 Speed Thread |
Installing the 5spd in the Bug was fairly straight forward. The biggest challenge was ensuring the transmission didn't make any contact with frame or body. Just shoving the trans into place would have hard contact on the body under the back seat at the seat belt mounts and torsion bar tube at the mount area.
Required using a jack to push the seat belt mounting plate up a little and cutting/welding the torsion bar tube to create a dimple.
No good pictures of the two clearance mods and I'm certain every Bug would be a little different.
Posted: Thu Feb 15, 2024 3:30 pm Post subject: Re: The Berg 5 Speed Thread |
Here's a picture of stock 4spd and Berg 5spd with Rhino case. A bit of size difference. Rhino case with 5spd weighs a bit more. I should have weighed the two transmissions. I'm guessing 25lbs more.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77070 Location: Sneaking up behind you
Posted: Thu Feb 15, 2024 3:34 pm Post subject: Re: The Berg 5 Speed Thread |
Here's some info on my Berg 5.
Builder - Gary Berg
Case - Volkswagen "Rhino" case, heavy duty side covers
Mounts - Gene Berg GB-642P heavy duty rear mounts and Gene Berg GB-643F front crossmember
Gear Ratios - Close ratio 1st, 2nd, 3rd, 4th and 5th, steel shift forks, hardened keys
1st - 3.78:1 (heavy duty, late model)
2nd - 2.06:1 (stock, late model)
3rd - 1.58:1 (welded hub)
4th - 1.21:1 (welded hub)
5th - 0.82:1 (welded hub)
Rev - 3.61:1 (stock, late model)
Differential - ZF, Limited Slip (LSD) with 4 spyder gears (11 tooth)
Ring / Pinion - Gene Berg GB-660K-3875 (Klinkenberg), 3.875:1 ratio, 8 bolt
Shifter - Gene berg GB-5710, 5-speed shifter, new shift rod bushing
Axles - Type 181 Stub Axles and C/V Joints with Sway-A-Way Axles
Lubrication - Valvoline Gear Lube, 80-90W API Service GL-5 and MT-1 rated
Misc. - Heavy duty cross shaft (welded), GBE Super Duty Pinion Bearing Retainer, Welded Clutch tube
Pictures of the build: https://www.glenn-ring.com/berg5/
Updated by Gary Berg
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Feb 15, 2024 3:39 pm Post subject: Re: The Berg 5 Speed Thread |
Glenn,
I think I remember you saying you ran a regular Super Diff for a while before swapping to the ZF. If so, did you have issues with noise from the Super Diff?
Under load, I'm getting a little noise in 4th and quite a bit in 5th. Quiet under decel, just under any load. 1-3 are quiet.
I'm wondering if that's a product of either the Super Diff (Extra lube holes drilled) or just low quality gears?
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
Glenn Mr. 010
Posted: Thu Feb 15, 2024 3:53 pm Post subject: Re: The Berg 5 Speed Thread |
This is why I replaced the Super Diff with the ZF.
Member #1009
#BlueSquare
Posted: Thu Feb 15, 2024 4:14 pm Post subject: Re: The Berg 5 Speed Thread |
Oh boy, I'll check for little chunks of metal when I change the oil.
Good shot of the mid-mount. A must for the 5spd conversion. Easy to install, after final fitting of the transmission, installed the little rubber mounts, set the metal tabs on top, welded in place.
Bruce Samba Member
Joined: May 16, 2003 Posts: 17302 Location: Left coast, Canada
Posted: Sat Feb 17, 2024 3:20 am Post subject: Re: The Berg 5 Speed Thread |
Glenn wrote: |
Differential - ZF, Limited Slip (LSD) with 4 spyder gears (9 tooth) |
Correction. ZFs use different spider gears than the stock open diff. _________________
Bruce Samba Member
Posted: Sat Feb 17, 2024 3:25 am Post subject: Re: The Berg 5 Speed Thread |
Root_Werks wrote: |
I'm wondering if that's a product of either the Super Diff (Extra lube holes drilled) or just low quality gears? |
When you're going straight down the road, the spider gears inside the diff are stationary, so they aren't the source of your noise.
It is most likely due to a noisy 4th gear set (as 5th gear). _________________
Glenn Mr. 010
Posted: Sat Feb 17, 2024 6:26 am Post subject: Re: The Berg 5 Speed Thread |
Bruce wrote: |
Glenn wrote: |
Correction. ZFs use different spider gears than the stock open diff. |
Bruce,
He asked why I switched and the broken gear is why I finally switched. Never implied the gears are the same. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Feb 17, 2024 10:56 am Post subject: Re: The Berg 5 Speed Thread |
Bruce wrote: |
Root_Werks wrote: |
It is most likely due to a noisy 4th gear set (as 5th gear). |
Pretty much what I'm thinking as well. 3rd and 4th are GEM/Arrow gears, welded and quiet. The .82 5th is unknown to me. All I could find on it was a "C" stamped on both gears. Don't know what brand.
Bruce Samba Member
Posted: Sat Feb 17, 2024 8:44 pm Post subject: Re: The Berg 5 Speed Thread |
Glenn wrote: |
Bruce wrote: |
Glenn wrote: |
Bruce,
He asked why I switched and the broken gear is why I finally switched. Never implied the gears are the same. |
My reply wasn't related to the reason you switched diffs. Just that your original spec list quoted 11 tooth gears in a ZF. A Beetle ZF (and 091) has 9 tooth spiders. 11 tooth spiders are from the stock open diff from 61 to 72. Then 10 tooth spiders from 73 on like the busted one in your pic. _________________
gears Samba Member
Joined: October 28, 2002 Posts: 4396 Location: Tamarack, Bend, Kailua
Posted: Sun Feb 18, 2024 7:33 am Post subject: Re: The Berg 5 Speed Thread |
Since we're side-tracking, stuffing 930-size spider/ side gears into early ZF:
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
six7vdub Samba Member
Joined: December 05, 2005 Posts: 45 Location: Las Vegas, NV
Posted: Wed Feb 21, 2024 9:34 am Post subject: Re: The Berg 5 Speed Thread |
What is a roundabout cost for going with a decent 5 speed build? Reading through this thread I see that there are upgrades that some have went with, so i'm just looking for a general number on a 5 speed that would be putting power down for a mild 2276 with roughly 180hp. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9843 Location: Oregon
Posted: Wed Feb 21, 2024 9:49 am Post subject: Re: The Berg 5 Speed Thread |
six7vdub wrote: |
Figure $1k per forward gear. Or so I was quoted a few years back 🤔 _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Wed Feb 21, 2024 10:43 am Post subject: Re: The Berg 5 Speed Thread |
67rustavenger wrote: |
six7vdub wrote: |
Figure $1k per forward gear. Or so I was quoted a few years back 🤔 |
That's pretty close to the cost of my build. Although I added another chunk of change to swap out my 3-4-5.
Glenn Mr. 010
Posted: Wed Feb 21, 2024 1:32 pm Post subject: Re: The Berg 5 Speed Thread |
When I had mine rebuilt, I was told to insure it for $6000. That included the upgraded parts and the ZF LSD. That was 12 years ago so add a few $$$ _________________ Glenn
Member #1009
#BlueSquare
Olli from NJ Samba Member
Posted: Wed Feb 21, 2024 3:42 pm Post subject: Re: The Berg 5 Speed Thread |
Don't forget the mid-mount and the shifter. About another $500.
The thing to really take into account if one is serious about a GB5, is the potential wait on GB. My GB5 build was completed recently and the wait on GB supplying the builder the kit was 19 months. And the builder was told at the time of the order that they (GB) were ready to start a production run. My builder ordered 3 kits.
My GB5; IRS, Rhino case (gusseted), 4.12 R&P, 3.75, 2.25, 1.58, 1.14, .89 all gears are Weddle except for the .89 which is German OE. Quaife diff, 930 out put flanges, all internal components are REM polished.
Street Ghia. 25.2" rear tire. The engine is a 235 HP 2387 (with the belt on and muffler) power band is 3900-6500+
Olli |
SilverThing Samba Member
Posted: Wed Feb 21, 2024 7:45 pm Post subject: Re: The Berg 5 Speed Thread |
gears wrote: |
Different discs too? The side gears look like they have a different spline _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Bruce Samba Member
Posted: Thu Feb 22, 2024 1:15 am Post subject: Re: The Berg 5 Speed Thread |
SilverThing wrote: |
gears wrote: |
Since we're side-tracking, stuffing 930-size spider/ side gears into early ZF: |
Different discs too? The side gears look like they have a different spline |
Talk about differentials here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=694936 _________________
