Holzy22 Samba Member
Posted: Sat Dec 23, 2023 3:17 pm Post subject: new Kadrons sputtering on low RPM |
Just installed a brand new 1915 motor into my bus. Had it running pretty good with the original dual 32 PDIST set up. Decided to buy the 40k 40mm Kadron dual carb kit.
It idles fine and cruises at high RPM just fine, but on initial take off, or after switching gears and the rpms drop, it sputters and stalls then sort of catches (if that make sense) and then goes great. Then I change gears or slow down and it sputters again until higher RPMS are achieved.
I have:
Perfect balance on both carbs,
3/8 line from manifold to manifold to balance.
Enrichment on both dialed in.
timing is at 10 static and 30 total.
bosch SVDA distributor hooked up to the right carb.
thoughts? |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2389 Location: Seekonk,Massachusetts USA
Posted: Sat Dec 23, 2023 4:42 pm Post subject: Re: new Kadrons sputtering on low RPM |
Nooooo, don't tell me that, just spent $750 on them cause I thought my new 1915 needed more than those 32's.
Have to get them to work.
My brake booster is also T'd off from the balance line, could that be playing havoc with the set up? |
Posted: Sat Dec 23, 2023 5:04 pm Post subject: Re: new Kadrons sputtering on low RPM |
Holzy22 wrote: |
I don't think the brake booster is playing havoc with the 40K. You can bypass the brake booster to confirm. Do the road test in a safe location. I also spent good money on my EMPI 40K, and back in the box they went.
https://studio.youtube.com/video/zBFFnh7Y1oY/edit _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7229 Location: Videbaek Denmark
Posted: Sat Dec 23, 2023 5:15 pm Post subject: Re: new Kadrons sputtering on low RPM |
Holzy22 wrote: |
I have:
thoughts? |
You should have bought a nice set of IDF´s instead. But now you have them.
What is the rest of the engine? _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
richparker Samba Member
Joined: November 24, 2011 Posts: 6989 Location: Durango, CO
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Sat Dec 23, 2023 6:18 pm Post subject: Re: new Kadrons sputtering on low RPM |
You sure got a lot of negative responses. Without calling anyone wrong, I would keep in mind that more than a few people have successfully used those carbs and they have a good reputation, overall.
My personal experience with them was wonderful with years of un- temperamental smooth reliability. I have a set waiting for the engine I’m gathering parts for.
With your symptoms, I would wonder if the fuel pressure is higher than recommended. Do you have a fuel pressure regulator?
I would wait until someone who understands Kadrons chimes in. Kaddy Shack is an obvious resource.
Chuey |
Posted: Sat Dec 23, 2023 6:52 pm Post subject: Re: new Kadrons sputtering on low RPM |
Chuey wrote: |
Chuey |
Some of the Empi 40K carbs have issues. Real Kadrons are better. Kaddy Shack give up, on getting the EMPI 40K carbs to work right. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Posted: Sat Dec 23, 2023 7:38 pm Post subject: Re: new Kadrons sputtering on low RPM |
Yes, doesn't seem to be much love for these, but I have them now and am determined to make them work. CIP said these ones would be the most fool proof with almost no issues.
The engine is a pretty stock 1915. Stock cam and heads as far as performance upgrades.
It feels like the carbs are starving for fuel for that brief moment, that's my guess. I will get a fuel pressure reg on there, but never had an issue before. Maybe not enough pressure to deliver enough fuel? I have not touched the pumps, they are adjusted the same as they came. Will call empi after the holidays to check on that. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9657 Location: Pearl River, NY
Posted: Sat Dec 23, 2023 10:06 pm Post subject: Re: new Kadrons sputtering on low RPM |
About 25 yrs ago I had a similar issue with genuine Kads on my nearly stock 1600 in my '77 Beetle. Hesitation when starting off. I tried these instructions to adjust the accelerator pump, which improved and nearly eliminated the hesitation. http://www.lowbugget.com/main_page.html Also aimed the accel pump squirt tube slightly so that the fuel stream aimed right at the gap of the throttle plate and the carb inside wall when the throttle started to open.
The Beetle has utilized a low-pressure Facet-style electric fuel pump from the PO for numerous types of carbs, from Dell'Orto dual throats, Weber IDFs, Kads, and most recently even a stock Solex single. Fuel line pressure using a test gauge is about 2.5 psi. |
Posted: Sun Dec 24, 2023 2:13 am Post subject: Re: new Kadrons sputtering on low RPM |
Holzy22 wrote: |
Empi Kads are not the easiest to get to work well. The older Brazil ones were fine.
- "Stock" 1914. Soo, I am assuming that you have corrected the compression ratio the redneck way, with shimming the cylinders. To get to something like 8-1 you need a deck height of approx 0,090" with untouched heads. That is right in the "death" zone where you get a very inefficient burn. With that in mind you should increase timing 3 degrees and increase the main jet to 135. Increase pump squirt with 1,5 turn. 135 main may not be enough, but go from there. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Sun Dec 24, 2023 11:56 am Post subject: Re: new Kadrons sputtering on low RPM |
wow, really, need to do all of that just to make these carbs work. As per a previous post, should I just put my 32 PDIST's back on? Is there a big performance difference even if I get these K's to work? Assumed a 1915 needed bigger carbs. |
Posted: Sun Dec 24, 2023 4:25 pm Post subject: Re: new Kadrons sputtering on low RPM |
Holzy22 wrote: |
Let us know, how it works out with the Empi 40K carbs. (CIP1 said, these ones would be the most fool proof with almost no issues.) _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
Posted: Sun Dec 24, 2023 6:02 pm Post subject: Re: new Kadrons sputtering on low RPM |
Well, yes, and no. It not like the 32´s will solve your problems. The 32´s are simply masking your issues with limiting the airflow to the engine. If you built the engine like I assumed and laid out above you will not feel the difference between a less than good timing setting versus an optimum, because the engine can´t breathe enough for it to make a difference.
In a well tuned set up the power difference between the 32´s and the Kads will be somewhere between 7 & 10 hp _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Mon Dec 25, 2023 9:36 am Post subject: Re: new Kadrons sputtering on low RPM |
lol I didn't know I had problems, but I get what you are saying, performance from my new 1915 may have been limited by the 32's and to get it to breathe fully, the 40ks, tuned properly with the engine will do that. And yes that's what I am looking for. So I am going to forge on and and get them dialed in. |
craigman Samba Member
Posted: Mon Dec 25, 2023 11:47 pm Post subject: Re: new Kadrons sputtering on low RPM |
My local vw shop sent 3 sets of EMPI Kids back to EMPI to try and figure out why they don't work. Until further notice, they're not selling any more EMPI kads. |
Posted: Tue Dec 26, 2023 8:31 am Post subject: Re: new Kadrons sputtering on low RPM |
Tuned them a little more as per Alstrup. Gave the pumps 1 turn, adjusted the idle mixture screws one more time. Did not increase the jets...yet. Road test was better, still a little hesitation when shifting gears, but better. But you can tell they just feel a little off. Will talk with EMPI and Kris at CIP Canada, (he is awesome), and see what they recommend as well. |
Posted: Tue Dec 26, 2023 9:11 pm Post subject: Re: new Kadrons sputtering on low RPM |
Was just thinking, actually the oil that flung onto my new right side air filter (uuugh) got me thinking, I have not set up the PCV valve venting yet. My breather tube is just wide open for now. Would this make a difference? I cant see PCV pressure in the motor causing any of my sputtering issues, but it did get me going down an internet rabbit hole on PCV venting. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9779 Location: Oregon
Posted: Tue Dec 26, 2023 9:25 pm Post subject: Re: new Kadrons sputtering on low RPM |
Is this not your current engine filtration and case vapor ventilation system?
If so, are you running the oil vapor recovery system from the breather/oil filler tower like in the image above?
If not, adapt your breather tube to one of you intake filters, or a breather box of some sort. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
