fleff Samba Member
Posted: Tue Dec 12, 2023 12:07 pm Post subject: Advice needed for rust remediation |
I've had my bus for about a dozen years and it was pretty thoroughly refurbished when I bought it. However, I'm starting to see a bit of rust between the underside of the gutter and the body...so just above the windows. It's not everywhere, but I'd like to get ahead of it.
I'm thinking of sanding it and then painting, but also wondering what the best way would be. Maybe use a rust converter? Other? _________________ '76 VW Campmobile
'98 VW Passat
'69 Piper Comanche |
far rider Samba Member
Joined: August 30, 2005 Posts: 773 Location: Rutland, VT
Posted: Mon Dec 18, 2023 5:25 pm Post subject: Re: Advice needed for rust remediation |
I would sand it and seal it with either Master Series or Eastwood Rust Encapsulator Prdmium. Finish paint over that.Good luck _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
clarkster75 Samba Member
Joined: September 25, 2006 Posts: 161 Location: Lots of good clean livin' Utah
Posted: Tue Jan 23, 2024 10:00 pm Post subject: Re: Advice needed for rust remediation |
My 0.02
Since "dustless blasting" has a huge footprint in TX, maybe you can meet someone for an hour to just do around/at the gutter.
Once that is clean, then you can follow something closely to what the first response you received.
A sealer/converter is mainly a band aid.
If you had stripped/blasted, then you could prime/seal and get the paint back on.
The stripping/rust removal is probably 60% of the job, and getting it alll primed and painted once clean shouldn't be too bad.
But yes, having "one" spot with bubble rust really leaves a downer on the rest of the car. Weird how that works. Hope you get smooth sailing on your fix |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9977 Location: Huntington Beach, CA
Posted: Tue Feb 06, 2024 11:16 pm Post subject: Re: Advice needed for rust remediation |
Naval Jelly and a wire brush. Wire brush the shit out of the rust. Then apply a layer of Naval Jelly as per the directions. Rinse completely with water. Brush and reapply as needed until neutralized! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Mon Feb 19, 2024 4:38 am Post subject: Re: Advice needed for rust remediation |
VW_Jimbo wrote: |
Naval Jelly and a wire brush. Wire brush the shit out of the rust. Then apply a layer of Naval Jelly as per the directions. Rinse completely with water. Brush and reapply as needed until neutralized! |
THIS! or localized blasting if available |
