Sloanstavern Samba Member
Joined: July 31, 2014 Posts: 35 Location: Chandler AZ
Posted: Fri Nov 24, 2023 9:02 am Post subject: New Build- Baby Blue |
Howdy all I thought I would get my build thread started this morning. Last spring I picked up a non-running 74 super beetle. The motor was out and much was missing but the body was laser straight and rust free even though it was hidden in several layers of what appeared to be house paint.
This is not my first air cooled, I restored a 69 bay window with my daughter and had a nice surviving type III square pack. But both were mechanically sound so this is my first full restoration. I finished the bodywork and paint last spring before I left for the summer and now I’m going to work on the motor and interior- more to follow.
Kennys72bug Samba Member
Posted: Fri Nov 24, 2023 7:15 pm Post subject: Re: New Build- Baby Blue |
Paint job looks real nice !!! Did you paint it yourself? My bug needs a paint job. |
Posted: Sat Nov 25, 2023 4:17 am Post subject: Re: New Build- Baby Blue |
Kennys72bug wrote: |
Thanks,
yes I did ( It is just average, but better than it was!)
I got this premixed color from Summit racing. It was just what I wanted and the price is great.
This is my third car with their brand paint and so far so good. |
ECDriver Samba Member
Joined: May 26, 2004 Posts: 13 Location: Casa Grande AZ
Posted: Sat Nov 25, 2023 6:03 am Post subject: Re: New Build- Baby Blue |
Really nice looking. Where did you find the beautiful series 45 Toyota Troop carrier? Looks great also! |
Posted: Sat Nov 25, 2023 11:58 am Post subject: Re: New Build- Baby Blue |
Thank you, I picked up the Troopy from Saudi Arabia five years ago. And spent two years doing a full nut and bold restoration now she’s just a fun driver.
Posted: Tue Nov 28, 2023 6:38 am Post subject: Re: New Build- Baby Blue |
Just finished the engine tear down and rebuild. This is my first attempt with an air cooled engine, and what a delight. Such a beautiful and simple little machine. Before the tear down, I managed to do a compression check using a high torque drill on the flywheel nut Cylinders three and four were 90 psi and cylinders one and two were 30 psi. Upon tear down I found rust and corrosion on the problematic cylinder bank. I decided to go with the top and rebuild kit from AA performance with new heads, cylinders and pistons.
The reassembly was a blast and I think I’ve got everything back where it should go. I’m taking a break before I start the wiring as I think I need to replace the harness. On other restorations, I’ve used the painless wiring system with good success so I may try one of their universal kits.
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4429 Location: Stuck in Ohio
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed Nov 29, 2023 1:47 am Post subject: Re: New Build- Baby Blue |
Looks really good so far! I’ve been using summit paint for a while now, but I’ve noticed the color tends to chip easily. Both the red and the black single stage do it, but the epoxy and urethane high builds don’t! Have you run in to that at all? _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Wed Nov 29, 2023 5:37 am Post subject: Re: New Build- Baby Blue |
scrivyscriv wrote: |
Looks really good so far! I’ve been using summit paint for a while now, but I’ve noticed the color tends to chip easily. Both the red and the black single stage do it, but the epoxy and urethane high builds don’t! Have you run in to that at all? |
Thanks,
I have done 4 vehicles with Summit paint ( Hi build, Epoxy, and Single stage). I have not seen any real difference in durability compared to Matrix, or Dupont.
I imagine Summit brand is manufactured by a leading paint Co. Not sure which one private labels it for them - I have found all the other Summit brand items to be high quality |
Posted: Sat Mar 09, 2024 4:47 pm Post subject: Re: New Build- Baby Blue |
Well, I can’t put it off any longer time to tackle the electrical work. I was hoping to find a complete new harness, but no luck. I could find a main harness from the engine compartment forward, but that wiring is actually pretty straightforward. It is the rats nest under the dash that’s got me Worried. Anyway, I got the engine of fire and idle nicely now I need to get to work on this stuff slowly I’m figuring it out but I came across this duck, and I think it may be interrupting the circuit between the key and the starter do you guys know what this thing does?
I don’t seem to be getting any juice out, going to the starter as I turn the key
cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Sat Mar 09, 2024 5:02 pm Post subject: Re: New Build- Baby Blue |
Glad to see you back!
That relay on the fuse block is the seatbelt lock relay, that orginally prevents the car from being started if the seatbelt is not clicked in. This has generally been bypassed by lots of PO's, which probably includes yours. _________________ 71' Super Convertible (Orange)
74 Super Beetle (Red) |
Posted: Sun Mar 10, 2024 7:21 am Post subject: Re: New Build- Baby Blue |
Thanks, It looks like it is still in service.
The more I tear into this the more I realize - I wont be able to sleep at night if I run that old harness. Since no '74 Super beetle front end harness is available, I will go to my 2nd choice. A painless 21 circuit universal harness (P/N 10102).
I used this on my FJ45 and it did the trick, very high quality and detailed instructions . Given the rear motor it may be close for some of the engine circuits, but it should be OK |
vamram Samba Member
Posted: Sun Mar 10, 2024 8:16 am Post subject: Re: New Build- Baby Blue |
Love the color. What equipment did you use to paint it? And did it take a lot sanding and polishing after the fact? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sun Mar 10, 2024 2:35 pm Post subject: Re: New Build- Baby Blue |
Thank you very much. No I have not cut or buffed the finish and truth be told it definitely looks like an amateur did it but I’m happy because it’s one color and kind of shiny.
The gun set up I have is from Eastwood. It’s their brand called concourse and I got a set that has a large and small gun with three different orifice sizes. The gun works great. In my opinion the biggest challenge is getting the gun set up properly that’s half the battle. Then just use good lighting And watch the paint go on.
If you have never done it, I encourage you to give it a shot like anything else just takes some practice and to be honest with you I’d rather pay 300 bucks for me to do a mediocre paint job than 5000 for a pro no offense
Rome Samba Member
Joined: June 02, 2004 Posts: 9657 Location: Pearl River, NY
Posted: Sun Mar 10, 2024 5:17 pm Post subject: Re: New Build- Baby Blue |
Good work with the DiY paint job, and with the engine assembly. Will you remove those plugs from the fan shroud fresh air outlets to connect those outlets to the heater box inlets with the big hoses and allow the air to flow through them? Did you remember to install the air deflector tins under each pair of cylinders before putting the pushrod tubes on?
Your original cylinder heads have been machined to a "semi-hemi" style combustion chamber. That type of machining will lower your compression ratio due to removing head material from the "ceiling" of the chamber. Do you know the volume of the chambers in your new heads? Helpful to know so you can determine the compression ratio.
I also made an attempt to paint a car; was a '62 Beetle that was originally anthracite grey. I chose a nice bright blue similar to the one you ended up with; was the same color as my dad's then-new Audi Fox, named Miami Blue. That was in 1976, using Martin Senour acrylic enamel, a rented air compressor and spray gun; working outside. Nowadays I'd have kept the original grey color because in the meantime it's become one of my fave classic colors. |
Posted: Sun Mar 10, 2024 5:22 pm Post subject: Re: New Build- Baby Blue |
Thanks,
Yes I have the flex tube for the air intakes ( It is rather delecate so I am waiting to install. I did get a full tin set up ( Some I had the rest I replaced.
I did not measure the head space ( this rebuild was OJT so Im sure i missed alot - just happy it was running so well!)
I painting my first vehicle in 1977, same way rented compressor, out side with a borrowed gun! |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Sun Mar 10, 2024 7:50 pm Post subject: Re: New Build- Baby Blue |
Sloanstavern wrote: |
...I’d rather pay 300 bucks for me to do a mediocre paint job than 5000 for a pro no offense |
BINGO. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Posted: Wed Mar 13, 2024 9:51 am Post subject: Re: New Build- Baby Blue |
Well, there is no turning back now. I’ve decided to go forward with the new painless, wiring harness. While removing the factory harness, the good news is, it was not all cut up by previous owners, the bad news, however, is all the vinyl and connectors were severely deteriorated and crack in my hands plus all the connections were heavily corroded. The removal went fine until I had to pass the rear harness over the wheel arch. As my dear uncle Allen would say there is a special place in hell for the guy who designed that access. In that vinyl conduit were multiple connectors that made it impossible to pull the wires through , and that foam insulation was not gonna budge. Finally, I got it out and left the old vinyl conduit in place to run my new wires through.
The painless kit I purchased is a universal that is suitable for SUVs and trucks so it does have a lot of wire length, However, since I’m trying to make it fit a rear
engine vehicle, I’ll have to get creative. The harness brakes into three main categories, front interior and rear. Then the subcategories from there, I laid it all out to see if I can mount the fuse box up in the foot well and still reach the engine. Some wires will make it, but a few are too short if I move the fuse box further back in the vehicle to solve that problem, then the wires for the instrument panel will be too short. Since there’s fewer wires going to the engine and some of them do actually reach I think I will mount it in the foot wheel upfront and simply add on wiring to the back to finish layout today and maybe start install tomorrow
slayer61 Samba Member
Posted: Wed Mar 13, 2024 11:28 am Post subject: Re: New Build- Baby Blue |
^^^ Good for you! I used a similar kit to do my buggy. A little planning, a little time, and, for me it worked out perfectly. No troubleshooting in the end. It just worked. After all, it's just a big adult version of "connect-the-dots"
You will have a better idea of how your car works, and you'll know exactly what to do to remedy it if it does let you down somewhere.
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
