johnanddes Satellite Wrangler
Joined: October 17, 2004 Posts: 692 Location: Orcutt CA
Posted: Sun Oct 22, 2023 7:58 pm Post subject: Rear Decklid curve |
So crazy question. I have a spare Decklid that I am going to possibly use as a patch panel for my c-pillar (thanks death foam). Has anyone attempted this? It seems that the contour is the same. Otherwise I’ll attempt to find C-pillar.
_________________ John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk |
RLFD213 Samba Member
Posted: Mon Oct 23, 2023 12:37 pm Post subject: Re: Rear Decklid curve |
I wouldn’t use the deck lid. Just get scrap and start your piece in the seam where the rain gutter is |
viiking Samba Member
Joined: May 10, 2013 Posts: 2673 Location: Sydney Australia
Posted: Mon Oct 23, 2023 5:22 pm Post subject: Re: Rear Decklid curve |
Why not use the deck lid if it is scrap and the right sort of contour?
The benefit is that using original steel will give you a better weld solution as the metal composition will be the same rather than use scrap from an unknown source.
Whenever I’ve had to do rust repairs I have always used metal from donor sections even if the section is from a different part. The only caveat is that the thickness is the same. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
ChunkyChief Samba Member
Joined: October 20, 2023 Posts: 4 Location: Lithuania
Posted: Mon Nov 06, 2023 6:07 am Post subject: Re: Rear Decklid curve |
Looks like you need way more than a spare deck lid. The whole rear fender mounting strip appears to be rusting. You may need a donor and/or repair panels. I currently happen to be working on the same area on the other side and it is pretty tricky.
All in all it depends on whether you want a quick fix-up or if you want to strip everything and do a proper long-lasting repair. |
Posted: Tue Nov 14, 2023 11:33 pm Post subject: Re: Rear Decklid curve |
ChunkyChief wrote: |
I am going to do it right. I have a couple of years to tackle it. I want to do it slow and steady. If I can’t do it I found a good body man that won’t take every last penny I have. _________________ John
1968 F250
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Nov 15, 2023 4:35 pm Post subject: Re: Rear Decklid curve |
Pull the fender off and strip the paint off the rusty areas.
Cheaper/better to do your own bodywork. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Nov 15, 2023 10:25 pm Post subject: Re: Rear Decklid curve |
johnanddes wrote: |
I am going to do it right. I have a couple of years to tackle it. I want to do it slow and steady. If I can’t do it I found a good body man that won’t take every last penny I have. |
I'd say, get fresh repair panels where possible, and for the rest find donor cutouts. |
