Rave Wood Samba Member
Posted: Thu Aug 10, 2023 4:43 am Post subject: back axle/shocks |
So I have the first Trekker to be imported to the UK! It was taken to bits 30 years ago and now I've bought it! Most of the parts are there but some are not. I have manuals and part cats. But i cant figure out how the back shocks go back on. Do I need the spacer tube. And also the brake line run, where exactly does it go. So I'm thinking some pics of existing Trekkers could help! I've got the oldest swing axle configuration. Thanks in anticipation.
Rave |
FJBLF Samba Member
Posted: Thu Aug 10, 2023 6:53 pm Post subject: Re: back axle/shocks |
Yours must have the Gear Reduction Boxes, Just like my 72'. Yes there is a spacer that goes between the Gear Box Housing and the Shock, The long screw goes through it and and the Shock Groomet the nut goes on the inside end. PN# 181 513 125 Spacer Tube. You won't get the Schocks on with out it. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Semper_Dad Samba Member
Posted: Fri Aug 11, 2023 12:33 pm Post subject: Re: back axle/shocks |
It would be interesting to know more about your Trekker. Year? Exhaust and heating setup? I'm assuming right hand drive. Do you have the b-pillar extensions for the 3 point seatbelts? What years was the Trekker available in the UK?
I had the opportunity to see one at a car show in the US. I believe it eventually made it way back to the UK
Pics taken in 2005.
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Sat Aug 12, 2023 4:32 am Post subject: Re: back axle/shocks |
FJBLF wrote: |
Yours must have the Gear Reduction Boxes, Just like my 72'. Yes there is a spacer that goes between the Gear Box Housing and the Shock, The long screw goes through it and and the Shock Gromet the nut goes on the inside end. PN# 181 513 125 Spacer Tube. You won't get the Shocks on with out it. |
I hope I'm in the right place...not used to this forum yet and "Quote" seemed the only way to post a reply!
So thanks, Yes, I have the reduction boxes. I figured I need the spacer. However it is not available as a part. Fortunately its not a very complicated piece to fabricate if I know the dimensions, ie:how long it should be. Then I could do with a picture of how it all goes together as its hard to visualise with everything removed on my axle. Are these things you can help me with?
Cheers in anticipation, Rave |
Posted: Sat Aug 12, 2023 4:40 am Post subject: Re: back axle/shocks |
Semper_Dad wrote: |
Pics taken in 2005.
Hi, So it was registered in 1970! RHD but carries a 181 chassis no! Believed to be the first imported and probably as an exhibition car/dealership promotion. As I understand it, Trekkers were imported from this time til 74/76 but then discontinued due to lack of demand and/or safety considerations! No door pillar extensions, simple lap belts. I'm now fittting a 1600 single port twin webber. A heater has come with it( not sure if original but heater control switch mounted on the dash.
Hope that helps,
Cheers, Rave |
Posted: Sat Aug 12, 2023 4:46 pm Post subject: Re: back axle/shocks |
I don't think there is any way to tell the difference between a 181 VIN and a 182 VIN. The 3rd digit would simply be a year digit. In the case of a 182 built in 1970, it would start out simply as 180.
Curious whether all Trekkers retrained the swing axles or did they go to IRS say about 1973.
The example I've shown certain has some 1974 elements to it such as the hamster cheeks and cowl mounted mirrors. I wonder if later Trekker retained the gas heaters or used the Beetle style heating.
Pretty sure your gas heater setup is factory. US versions got the Beetle heat in 1974. The reason they dropped the gas heater was that they were so expensive. It was cheaper to add heat exchangers. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
FJBLF Samba Member
Posted: Sat Aug 12, 2023 6:49 pm Post subject: Re: back axle/shocks |
Sure, I'll take a few pics tomorrow and send them to you _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
FJBLF Samba Member
Posted: Mon Aug 14, 2023 2:07 pm Post subject: Re: back axle/shocks |
THere you have them. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Tue Aug 15, 2023 2:02 pm Post subject: Re: back axle/shocks |
Nice One, thank you so much. That's quite an extension! Would it be possible for you to measure the length of the spacer and post here. Great to see the brake line run too! |
