JeffnDes1977 Samba Member
Posted: Sun Jul 16, 2023 12:44 pm Post subject: Rear shock mounting options |
Just bought this buggy last weekend. There are things that I'm going to correct or change. And these rear shock mounts look like they aren't made for factory trailing arms. While ripping around my property today, the driver side bolt broke right off. I expected issues at some point because the shocks hit the mounting in the trailing arm when extended.
What's a good solution? I'm not a a financial position for better trailing arms at this time.
_________________ 1977 Bay 2.0 FI
1968 Sandrail/ woods buggy project
1970 Sandrail
19?? Sandrail project - soon to be for sale!
1960 Beetle - My first car! |
dustymojave Samba Member
Posted: Wed Aug 02, 2023 10:42 pm Post subject: Re: Rear shock mounting options |
After you have lots of fun getting that broken bolt out of the mount, you might think about adding a tab from the motor mount brace to put the shock bolt in double sheer instead of putting all that leverage on that poor bolt.
You may also need to add some bump stops as the shock might be doing that job now. They don't need to be expensive. Wrecking yards are a good source for all sorts of bump stops. Or even just steel to steel.
It could also be that the shock is too short for the job. _________________ Richard
SoCalBajas Member
Posted: Thu Aug 03, 2023 8:06 am Post subject: Re: Rear shock mounting options |
Yes! That bolt isn't tight - thank goodness. I can move it a little with my finger. This weekend I'm going to weld a nut to it and just unscrew it. I believe these are stock shocks for a bug, but since the mounting is different from a bug, it could be too short. I'm not looking for anything high-end, just functional.
Does anyone on here have pictures of shock mounting for a Chenowth frame like this? _________________ 1977 Bay 2.0 FI
1970 Sandrail
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20386 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Aug 03, 2023 3:08 pm Post subject: Re: Rear shock mounting options |
The problem is not trailing arm it is the geometry of the shock... Upper mount is positioned wrong for clearance of trailing arm... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
DesertSasquatchXploration Samba Member
Posted: Fri Aug 04, 2023 6:52 am Post subject: Re: Rear shock mounting options |
Quick fix just do a simple double sheer mount like dustymojave said. The position the shock is in after it broke off is where it wants to be, looks like you have a frame section that just needs a couple tabs welded on and you have a mount. Some 3 inch wide 3/16 flat strap steel can be found in the remnants section of any steel yard for cheap.
The simplest way to make matching tabs quick is to cut a section of strap steel the length of two tabs plus the diameter of the tube on your frame then with a matching hole saw (in red) drill/Cut thru and like Magic you have two tabs with the notch, now you clamp the tabs together in a vice drill your mounting hole debur and weld EZ. Cost you 5 bucks at the most.
Posted: Fri Aug 04, 2023 12:38 pm Post subject: Re: Rear shock mounting options |
IF you are looking for tabs, this site has many options and they are not expensive....
https://www.aa-mfg.com/product-category/shock-mounts/ _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
cbeck Samba Member
Posted: Fri Aug 04, 2023 6:12 pm Post subject: Re: Rear shock mounting options |
The eggspurts say the shock bolts are supposed to be parallel to the diagonal arm pivot bolt. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Fri Aug 04, 2023 7:45 pm Post subject: Re: Rear shock mounting options |
cbeck wrote: |
The eggspurts say the shock bolts are supposed to be parallel to the diagonal arm pivot bolt. |
100% agree like it is from the factory. Building a mount that turns the top pivot parallel with the bottom might be way past the OPs skill level. A number of us would have this issue fixed in a couple hours not everybody is at that skill level. A few home brewed weld tabs made dirt cheap is better then the goof ball single shear designed that failed and was off by a mile. OP said money was tight. |
Posted: Sun Aug 06, 2023 8:04 pm Post subject: Re: Rear shock mounting options |
You guys have some very good advice. I'm going to see if I can get the top bolt parallel with the trailing arm pivot like previously mentioned. That makes sense. Honestly, I hadn't thought of that. These shock bosses were on the buggy when I got it, so I assumed they were original to the frame, but now I'm thinking the weren't. They have got to go! _________________ 1977 Bay 2.0 FI
1970 Sandrail
Posted: Sat Aug 19, 2023 7:34 pm Post subject: Re: Rear shock mounting options |
I’ve been busy and haven’t had a lot of time to mess with this issue. But last week I burned some tabs and I think they’ll will work. I’d like some feedback. They aren’t 100% ready to be welded, I still have some grinding to do. From measuring my other buggy, they are going to be mounted about a half inch higher than stock. The pivot follows the trailing arm better as well.
1970 Sandrail
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Wed Aug 23, 2023 9:24 am Post subject: Re: Rear shock mounting options |
That is exactly what tou need. Maybe beef it up a little incase you bottom the shock out and add a bar to your hoop or something.
not necessarily that exact point but somewhere that will spread the load better _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Tue Sep 12, 2023 6:47 pm Post subject: Re: Rear shock mounting options |
I got these made up and welded in last weekend. I don't love my welds though - a bit thicker than I wanted. But they are pretty sturdy. I'll at a reinforcement on the top tube eventually.
1970 Sandrail
Posted: Tue Sep 12, 2023 7:04 pm Post subject: Re: Rear shock mounting options |
About your welds, if they hold they are good.... IF you want to improve it takes practice...
https://www.youtube.com/watch?v=Xod-ByrxHg4
Your work seems to be taking you in right direction..... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Wed Sep 13, 2023 5:18 am Post subject: Re: Rear shock mounting options |
I’ve grown up around welding, but I only weld here and there on my projects and very occasionally at work. These tabs were surprisingly challenging to weld because of their positions. If I were to do it again, I’d weld it differently. And I think I should have moved a bit faster with the mig torch. _________________ 1977 Bay 2.0 FI
1970 Sandrail
Posted: Fri Oct 13, 2023 10:03 pm Post subject: Re: Rear shock mounting options |
How has the fix been doing? It looked good.
Just FYI... Buggy frames don't come from the makers with shock mounts 99% of the cases. Either designed to use the factory VW shock mounts, or intended to get shock mounts custom fabricated. _________________ Richard
SoCalBajas Member
Posted: Thu Dec 28, 2023 1:49 pm Post subject: Re: Rear shock mounting options |
dustymojave wrote: |
Just FYI... Buggy frames don't come from the makers with shock mounts 99% of the cases. Either designed to use the factory VW shock mounts, or intended to get shock mounts custom fabricated. |
Well I haven’t had a chance to test it yet! I pulled the gas tank and decided to mount a smaller tank in a different way. That’s finally finished and I plan to drive this weekend. _________________ 1977 Bay 2.0 FI
1970 Sandrail
Posted: Thu Jan 25, 2024 1:53 am Post subject: Re: Rear shock mounting options |
JeffnDes1977 wrote: |
Well I haven’t had a chance to test it yet! I pulled the gas tank and decided to mount a smaller tank in a different way. That’s finally finished and I plan to drive this weekend. |
Aaaannndddd?????? _________________ Richard
SoCalBajas Member
Posted: Wed Feb 21, 2024 3:02 pm Post subject: Re: Rear shock mounting options |
The new mounts work very well. I'm happy with the setup. I'm probably on the top-end of the mounting though. I feel like I should get oil filled shocks and use limiting straps to keep from tearing them up. Oh and I have my new gas tank installed and I like that too.
1970 Sandrail
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 210 Location: NE Indiana
Posted: Wed Feb 21, 2024 3:44 pm Post subject: Re: Rear shock mounting options |
Looking good, I would have to lay those seats back some to make to make for a more comfortable ride.
Kenric _________________ The empty can rattles the most! |
Posted: Wed Feb 21, 2024 5:02 pm Post subject: Re: Rear shock mounting options |
woodsbuggy wrote: |
Kenric |
Oh yeah. They beat the snot out of me. I don’t love them. The seat rails came on the car, but I barely made those seats work. Really, they aren’t great. _________________ 1977 Bay 2.0 FI
1970 Sandrail
