djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32659 Location: Reading Pennsylvania
Posted: Fri Jun 30, 2023 1:41 pm Post subject: 090 Automatic Rebuild |
OK ......
In my younger days I would tackle any project with Vim & Vigor!
The "Can Do" attitude!
Maybe I'm just feeling my age .....
but I'm looking at this 090 Automatic thinking ...... I'm pretty sure I can rebuild it....... but am I simply deceiving myself?"
I mean it is a simple matter of disassembly, cleaning, inspection and reassembly......
My transmission in my 1990 made a funny "crunch" on an upshift yesterday...... I better get my A$$ in gear and start getting ready! The 1990 unit has way over 200,000 miles on it but I've no idea if the trans is original or not.
This is a spare I've had for 10 years. It only has 116,000 miles on it. I know the history of this unit...... it is no random transmission off the street.
It is either Do It Myself or shell out $2000+ to have it done and wait .......
What say you?
Yay
Or
Nay
Ghia
Vanagon
Beetle
jlrftype7 Samba Member
Posted: Fri Jun 30, 2023 2:11 pm Post subject: Re: 090 Automatic Rebuild? |
Go for it- You've got Kourt's extensive notes on the process. Not much in the way of tools is needed that is special at all.
https://www.thesamba.com/vw/forum/viewtopic.php?t=616506&highlight=
I took our apart in my Basement Shop in the Summer of 2020 to see why the Oil Pump Shaft twisted and broke[ oil pump jammed with needle bearing failure]
It's the kits that are becoming scarce, or the quality of them, and any hard parts you might run into like drum, oil pump, etc, that I think are the stumbling blocks currently.
I sourced our recent seal and part update on our '84 Auto with a mixture of Porsche part numbers, one part from Ebay, one Speedi-sleeve from Amazon/Timken, and had on hand the Master Rebuild Kit if I needed it, but I ended up not breaking into the Master Kit I bought a few years ago.
Mix of suppliers, but I got the seals installed, bushing for the TC, speedi-sleeve for the TC and it's all still working and dry so far... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Joined: January 01, 2007 Posts: 16893 Location: sticksville, ct.
Posted: Fri Jun 30, 2023 2:14 pm Post subject: Re: 090 Automatic Rebuild? |
djkeev wrote: |
you're going to have a stroke when you get todays prices
you're looking at 3K for a basic build and 3800+ for a top shelf build
whatever you decide, DO NOT fuck up either trans as parts are getting VERY hard to find _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
jocoman Samba Member
Joined: August 11, 2016 Posts: 427 Location: Ottawa, Canada
Take lots of pictures! yes, go for it especially since you have a spare! _________________ '86 Westfalia 2.0L Zetec
'97 Volvo 850 AWD Turbo
" The fun never stops" |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17163 Location: Retired South Florida
Posted: Fri Jun 30, 2023 3:01 pm Post subject: Re: 090 Automatic Rebuild? |
I vote “Yay”. Cleanliness and organization are key. You need a long bench so you can lay the parts out in order. The last time I did one, the apply pistons were not included in the kits. They had to be ordered separately.
Air test and measure as you assemble. Use the factory manual. One of our members sells new shims and valve body center plates in the classifieds. Go through the valve body as a separate project.
2nd gear brake band is inch pounds not foot pounds and don’t force anything. Vaseline works on the shaft square rings and the pump rings. Do the final measurement between the auto and differential. Don’t just reuse the same shims.
Shipping cross country twice is reason enough to do it yourself. I’ve read your posts and I believe this is within your wheel house. _________________ ☮️ |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6368 Location: Honolulu,Hawaii and France
Posted: Fri Jun 30, 2023 4:04 pm Post subject: Re: 090 Automatic Rebuild? |
You should do it, kits are affordable and it's a fairly easy job.
Replace the white plastic thrust washers, they get brittle with age: I sell them in the classifieds.
I also have the valve body separation plates should you need.
I'm leaving Monday to France, so if you need anything, it's now or August
Aloha!
Alika _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
xflyer Samba Member
Posted: Fri Jun 30, 2023 4:08 pm Post subject: Re: 090 Automatic Rebuild? |
"You need a long bench so you can lay the parts out in order." YES!
You can do it. Read the Bentley a few times. And change the metal rings on the turbine shaft even if they don't look worn. _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1501 Location: Victoria,B.C.Canada
Posted: Fri Jun 30, 2023 6:29 pm Post subject: Re: 090 Automatic Rebuild? |
Adventure.
https://www.youtube.com/watch?v=4EeaO1TC7Yw&t=42s
Get rebuild kit(s) with right frictions I saw somewhere.
Audi 5000 turbo upgrade while you're in there? on theSamba |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 961 Location: Northern California
Posted: Sat Jul 01, 2023 10:05 am Post subject: Re: 090 Automatic Rebuild? |
$2000 (in 2022) was more than worth it for me to take ours to a specialty shop. “A man’s gotta know his limits…” _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Posted: Sat Jul 01, 2023 3:56 pm Post subject: Re: 090 Automatic Rebuild? |
Well...... feeling inspired I started cleaning up my workshop area in my garage/now workshop.
I have a SnapOn 6'stainless steel workbench top with the raised oil drip edge on it.
This should be perfect for messy oil based work.
I have another worktop in another room of finished wood that will be great for laying out the disassembled and cleaned components.
My Wife uses this room a lot for her crafts so I'll need to be careful of oil and grease in there.
The space is heated and air conditioned so I can work comfortably.
Good lighting, good internet and it can be kept clean quite easily.
Contacted Alika about his parts, hope he is able to ship before he leaves!
I see many suppliers of rebuilt kits...... any that are better or worse?
I plan to get a kit with the steels.
Ghia
Vanagon
Beetle
Posted: Sun Jul 02, 2023 12:46 am Post subject: Re: 090 Automatic Rebuild? |
djkeev wrote: |
Dave |
Get
the Cobra kit 65006D
The rest is optional, but I would get the metal 3 tang thrust washers too.
Dosregard quantities from this order, that was for 2 transmissions plus 4 extra 65244 thrust washers. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3107 Location: ABQ NM USA.... Except when not
Posted: Sun Jul 02, 2023 7:08 am Post subject: Re: 090 Automatic Rebuild? |
Watching closely as I'll be having to do this and it will be my first time. Please post frequently and detailed(ly). .... The way your posts are I wouldn't be surprised if it becomes the premier Automatic Transaction Rebuild Step-by-Step!
Idk if an auto rebuild needs specialized tools like the manual and if it does, I would be open to contributing to such tools with the intention of having them to share within our community. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Sun Jul 02, 2023 10:19 am Post subject: Re: 090 Automatic Rebuild? |
Well crap Crap CRAP!!
Years ago I pulled the Servo Assembly for the 2nd gear band out of this extra unit.
I used it to fix my 86 leak and delayed shift issues.
I've since moved and although I've a pile of Vanagon Stuff all packed neatly in storage boxes...... do you think that Servo is in one of them?
Ohhhhh No it is not!
Well...... there is a guy in Michigan selling used 090 parts in the classifieds, I've contacted him, hopefully he has one 🙏
How stupid can I be to have lost that Servo!
Grrrrrrrr........
Well...... off to open up the Valve Body and see which plate I need ........
I know this plate is worn, I've had it open and did the "peening" repair on the mushed hole years back. _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Posted: Sun Jul 02, 2023 10:20 am Post subject: Re: 090 Automatic Rebuild? |
if it's recycledjack good luck
that guys is not very good to deal with, check his feedback _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Jul 02, 2023 11:11 am Post subject: Re: 090 Automatic Rebuild? |
Here is my Valve Body out of the 1986 090 transmission
Side towards transmission (up)
Side towards oil pan (down) you can see the circle where the oil screen screws on ...... it has a tag affixed to it stamped with "FFA"
Close up of the casting numbers .....
So, carefully remove all of the Phillips Head screws.
I actually didn't remove them just in case they are different lengths, I simply loosened them completely .
The lower left group of three hold on a steel disc that the accumulator seals against...... you must be careful, the disc will drop off. ......., see the disc sitting there next to the valve body?
Once loosened completely carefully lift the cover straight up and off, you will see the steel plate and lots of red oil........
I wiped off most of the excess oil......
My plate has the extra hole.... see the squarish slot with the rectangular slot next to it? Just inside the rectangular slot is a tiny pin hole..... not every plate has this hole. The hole is darn near center of the steel plate.
Here is the photo Alika sent me to ID the hole location......
Here I lifted off the steel plate and flipped it over ........ see the balls inside the maze of oil chambers? DO NOT LOSE THEM OR FORGET WHERE THEY GO!!
My fingers are pointing to A) the check balls and B the worn holes in the steel plate.......
A close up of the holes.......
I already texted Alika and advised him of my plate design. _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Posted: Sun Jul 02, 2023 12:17 pm Post subject: Re: 090 Automatic Rebuild? |
djkeev wrote: |
Yes.......
Aren't you just full of happy news?
They don't call me Raya for nothing.....Raya Sunshine _________________
Jake Raby wrote: |
Brian wrote: |
skemems Samba Member
Joined: February 23, 2017 Posts: 207 Location: Portland
Posted: Sun Jul 02, 2023 5:12 pm Post subject: Re: 090 Automatic Rebuild? |
Will be watching this post on rebuild
Thanks for documenting this... _________________ 87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project |
