4devins Samba Member
Posted: Mon Jun 26, 2023 2:10 pm Post subject: Looking for a mechanic in Houston |
Hey all, I'm looking for an engine mechanic in the south houston area that is good with air cooled motors. I am consistently missing on the #1 cyl, and about 90 psi during a compression test in the same, with the other three cylinders running 125-135psi. Cant wait to have my speedster rep back on the road.
Thanks in advance. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2039 Location: Southern California
Posted: Tue Jun 27, 2023 4:37 pm Post subject: Re: Looking for a mechanic in Houston |
I take it DFW is too far away from you? |
Starbucket Samba Member
Posted: Sat Jul 01, 2023 2:57 pm Post subject: Re: Looking for a mechanic in Houston |
Get it out on the highway for a good high speed run if you have just been puttering around town as your valves may have a bit of carbon on the seat and a good run with the motor turning 4K will clean it out. Did you squirt a small amount of motor oil in the plug hole to see if the low compression was rings (compression will rise) or valves (no change)? |
Posted: Mon Jul 03, 2023 10:43 am Post subject: Re: Looking for a mechanic in Houston |
Yeah, DFW is too far away unfortunately. I will do the oil test for ring sealing as well.. Thanks for the suggestions. |
Posted: Tue Jul 04, 2023 3:02 pm Post subject: Re: Looking for a mechanic in Houston |
Contact the 356 club in TX for a mechanic referral at 356tubclub.org |
Posted: Tue Jul 04, 2023 10:17 pm Post subject: Re: Looking for a mechanic in Houston |
The Tub Club is located in the DFW area--too far away per you. Try the Lone Star 356 Club based in Sugar Land, which as you probably know is in the greater Houston area. POC is Mark Roth (who is also a 356 Registry Trustee FWIW). 281-844-4259 [email protected]. Good luck!! |
wheel607 Samba Member
Posted: Wed Jul 26, 2023 10:28 pm Post subject: Re: Looking for a mechanic in Houston |
the best on 356 is in San Antonio..............a little closer than DFW, If you can go
email me! |
jwp67 Samba Member
Posted: Wed Aug 02, 2023 3:37 pm Post subject: Re: Looking for a mechanic in Houston |
I think I know where you’re talking about. I pass by his place everyday on the way home. Always a lot of nice cars in the work lot getting attention. _________________ 21 million of these cars were built,and everyone of them were sold...kinda astounding given how unreliable they are.---johhnypan |
