Racepedals Samba Member
Posted: Sun Apr 09, 2023 4:12 pm Post subject: Is there really a problem running radials on older 5 lug wheels |
I know the recommendation is to run tubes when running radials on 5 lug wheels with no interior hump to maintain the tire seal during certain spirited driving. However, has anyone actually had a radial lose the rim seal on these older wheels? I am replacing 20 year old radials on a recent purchased 67 beetle and now I am second guessing this since my wheels are stock 67 5 lug wheels without the hump. I am also planning to install 165/80 R15 on the stock 4” rims, which is the same size I am replacing. |
slalombuggy Samba Member
Posted: Sun Apr 09, 2023 5:35 pm Post subject: Re: Is there really a problem running radials on older 5 lug wheels |
Keep your tires properly inflated and you'll be fine |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2667 Location: Long Island, NY
Posted: Sun Apr 09, 2023 10:40 pm Post subject: Re: Is there really a problem running radials on older 5 lug wheels |
My '63 has its original 5-lugs with tubeless radials. No issues. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
EverettB Administrator
Joined: April 11, 2000 Posts: 69838 Location: Phoenix Metro
EVfun Samba Member
Posted: Mon Jul 10, 2023 6:10 pm Post subject: Re: Is there really a problem running radials on older 5 lug wheels |
I've never had a problem with the lack of bead lock on older rims. I've never had a tire shop question installing radial tires on those older wheels either. _________________
Wildthings wrote: |
modok Samba Member
Joined: October 30, 2009 Posts: 26797 Location: Colorado Springs
Posted: Mon Jul 10, 2023 8:01 pm Post subject: Re: Is there really a problem running radials on older 5 lug wheels |
I would say tire quality is more a concern.
I had a cheap tire pop off a j-lock rim once, so, clearly no system is foolproof.
I have michelins on old bus rims now, not worried at all. |
