GearheadJim Samba Member
Joined: April 10, 2003 Posts: 181 Location: Columbus Ohio
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Wed Jul 05, 2023 7:59 am Post subject: Re: This is the year |
Look at that thing... its got all the goodies. Im assuming this a 2110 the traditional way vs mine which is 76x94 _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Tue Aug 01, 2023 5:53 pm Post subject: Re: This is the year |
Interior progress under way.
Square weave from SewFine. After reading various posts I ordered the carpet kit without cutouts for heater vents, shifter, ... Good move. The cutout locations marked on the back of the carpet did not line up correctly. _________________ Drive 'em!
65 Notchback build: https://www.thesamba.com/vw/forum/viewtopic.php?t=773405 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Wed Aug 02, 2023 6:16 pm Post subject: Re: This is the year |
Looks good Jim. Engine looks sweet, and should run good, and the interior is coming together nicely. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Fasty69Jester Samba Member
Joined: November 13, 2008 Posts: 54 Location: Houston, Texas 77381
Posted: Wed Aug 02, 2023 7:35 pm Post subject: Re: This is the year |
Stellar work cant wait to get to that point. Keep spreading the motivation. _________________ It's gotta run cool and easy with a little pleasing.
!!RCVDUBS!! |
Posted: Mon Aug 07, 2023 6:25 pm Post subject: Re: This is the year |
How tight should the engine hanger tube fit into the engine hanger? I assume this is not good and should be replaced:
Posted: Tue Aug 08, 2023 2:20 pm Post subject: Re: This is the year |
I think you're 1 shim short (you have 6, not 7). Keep in mind that it's not supposed to be tight, as it's really just a snubber to keep the engine from moving too much under acceleration. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22466 Location: Escondido CA
Posted: Sun Aug 13, 2023 5:28 pm Post subject: Re: This is the year |
I'm looking for input on mounting my MSD 6AL CDI. I want to keep it out from under the deck lid and close to the battery. I'm considering under the rear seat or in the trunk. Anyone care to share their experience? How/where did you mount? Where did you run wires?
I'll have a small stereo system, use a bluetooth to retain the original radio
A pair of old school Rockford Fosgate amps driving one shallow 10" subwoofer and a pair of 6.5" coaxial's in the rear tray. Will address some rust cleanup in the process.
I'm planning a mounting panel on the trunk divide for the amps, might include the CDI there as well.
Posted: Fri Sep 01, 2023 4:09 pm Post subject: Re: This is the year |
!!RCVDUBS!! |
Posted: Sun Sep 03, 2023 4:54 pm Post subject: Re: This is the year |
Looking for input on the gap I have between my steering wheel adapter and the turn signal. The adapter is bottoming out on the shaft before the gap closes. Could it be as simple as the loosening the steering column hosing and sliding it up?
Posted: Mon Sep 04, 2023 9:41 am Post subject: Re: This is the year |
GearheadJim wrote: |
If I remember right it should be 2 to 3mm gap. If your horn starts going off during turns, you might want to increase it just a little more. That's why there are slots in the column head to mount to the dash. Just make sure you loosen the clamp bolt first. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Sep 05, 2023 6:42 pm Post subject: Re: This is the year |
Thanks for the replies. I have the column adjusted as far as the slots will allow but still have a considerable gap.
I think I'm missing something simple. @Bob, you may have hit upon the key with regards to the clamp bolt but not sure I follow. What clamp bolt are you referencing, #13?
With the slot in the flange (#34) to lock in the clamp bolt (#13) does the steering shaft (#35) actually have any adjustment or does that slot for the clamp bolt essentially set the location of the shaft (maybe just a micro adjustment)?
Posted: Wed Sep 06, 2023 10:40 am Post subject: Re: This is the year |
The clamp bolt I'm referencing to is at the base/bottom of the column head where it attaches to the column tube. But it could also be how deep you have the column shaft into the upper coupler (34), as that adjusts the length of the steering shaft. Does turning the wheel cancel the turn signal? Just asking as the "blade" (your 2nd pic attached to the steering wheel adapter) should sit inside the turn signal mechanism to cancel the turn signal operation (left or right turn). It makes me wonder if you have the right adapter, as there are 2 different ones that I know of.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Sep 06, 2023 5:09 pm Post subject: Re: This is the year |
Yes, turn signal cancel works. My first check was to the manufacturer to see if they may have sent the wrong adapter, they only have one and noted previous success with other Type 3 customers. The mystery continues. _________________ Drive 'em!
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24167 Location: Southeast USA
Posted: Wed Sep 06, 2023 8:51 pm Post subject: Re: This is the year |
Is it possible to just loosen the clamp and wiggle the steering column back a bit to meet the wheel? (If the wheel can't meet the column, make the column meet the wheel!)
Quick! Quick! Your window for having it back on the road this summer is closing! _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Posted: Thu Sep 21, 2023 3:20 pm Post subject: Re: This is the year |
Working to wrap up some interior details before the seats and door panels are done. Stereo is a bluetooth receiver into a crossover then out to two Rockford Fosgate amps I've had since the late 80's. A Punch 100 into a 10" sub and a Punch 40 into a pair of 6.5" coaxials. The mounting panel holding the stereo components and the MSD will get covered in vinyl. A frame on the perimeter of the parcel tray covered in speaker grill material will hide the speakers.
I just picked up one of the newly available BBT early grey parking brake boots (about 3 days after I purchased a black one because it was the only thing available at the time). I'm on the search for coat hooks and assist straps, need to figure out early vs late so I get the right set once I find them. The arm rests will be a future project. Neither of those will stop me from driving at the end of this month, maybe the first week into October. _________________ Drive 'em!
