6v with okrasa
gingerporsche
gingerporsche is offline
PostPosted: Tue Sep 13, 2022 6:49 am    Post subject: 6v with okrasa Reply with quote
Hi, just wondering if most are still running 6v with an okrasa engine,
Mines just been newly built with ww okrasa crank-cam-top end kit plus new barrels and pistons etc..
Now finding it turns over a lot slower to start than when it was standard!
Is everyone else’s similar?
Bub
Bub is offline
PostPosted: Tue Sep 13, 2022 9:59 am    Post subject: Re: 6v with okrasa Reply with quote
Check your timing first, that can be one thing that makes the engine turn over slow. And then the usual stuff.
When I had that problem I crawl underneath and jump the starter. If it still cranks slow it's the starter. If it cranks decent it's wiring, ground, switch etc..
In my case it was the starter and I got a super cheap one from Rockauto, 4 years on and it's still great.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
PeteSC
PeteSC is offline
PostPosted: Wed Sep 14, 2022 5:19 am    Post subject: Re: 6v with okrasa Reply with quote
Mine is still 6v and cranks over fine. As mentioned check your timing (they like a lot - at least 32* max, possibly higher if your jetting allows), grounds, etc. I did add a hard start relay some time ago which greatly improved the starter performance.
Redlabel6
Redlabel6 is offline
PostPosted: Thu Sep 15, 2022 6:04 am    Post subject: Re: 6v with okrasa Reply with quote
NAPA has rebuilt 6volt starters for $66.29 online. I picked up one for my '57, it was a Bosch.
d
1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe
gingerporsche
PostPosted: Fri Sep 16, 2022 11:10 am    Post subject: Re: 6v with okrasa Reply with quote
Thanks chaps, Think it maybe time for a new battery as I’m not sure how old it is! any recommendations?and what capacity (ah) etc
All earths and wiring all look good..
Braukuche
Braukuche is offline
PostPosted: Fri Sep 16, 2022 11:52 am    Post subject: Re: 6v with okrasa Reply with quote
Make sure you use 2 gauge battery cables makes a big difference.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Mr. Mike Premium Member
Mr. Mike is offline
PostPosted: Sat Sep 17, 2022 8:11 am    Post subject: Re: 6v with okrasa Reply with quote
On a sedan, I run a longer bolt (so it extends beyond the pan) under the seat for the negative ground and then run an additional cable from that bolt (with a nut) to the ground on the starter.
Cheers!
1964 Sedan 6 volt
scotty timmerman
scotty timmerman is offline
PostPosted: Sun Sep 18, 2022 4:21 pm    Post subject: Re: 6v with okrasa Reply with quote
Optima 6volt battery. Turns over my 74x83 1602cc okrasa engine.
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition
gingerporsche
PostPosted: Mon Sep 19, 2022 1:41 pm    Post subject: Re: 6v with okrasa Reply with quote
Thanks chaps, but think I’ve sorted it!
Cleaned all connections and replaced the earth on the battery an now turning over loads better 👌🏻
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Sep 20, 2022 11:28 am    Post subject: Re: 6v with okrasa Reply with quote
Also clean the surfaces between the starter and transaxle where they mate together and same for the starter to starter solenoid. Those grounds need to be CLEAN and DIELECTRIC GREASED to get the most out of the starter.
In Stereo, Where Available!
5500
5500 is offline
PostPosted: Wed Sep 21, 2022 2:12 am    Post subject: Re: 6v with okrasa Reply with quote
No issues with mine. Clean grounds, fresh cables and added a hot start relay to enhance starting.
Lingwendil
Lingwendil is offline
PostPosted: Wed Sep 21, 2022 11:01 am    Post subject: Re: 6v with okrasa Reply with quote
I've never found the need to run a hot start relay on any vehicle that has clean connections.
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
PeteSC
PeteSC is offline
PostPosted: Wed Sep 21, 2022 1:25 pm    Post subject: Re: 6v with okrasa Reply with quote
Getting a bit off topic here, but I like the idea of not running the full starting amp load through my hard-to-find lowlight ignition switch, and instead through the more easily replaceable relay, so I run one, even with my meticulously cleaned and dialectric-greased connection points. Smile
Bub
Bub is offline
PostPosted: Wed Sep 21, 2022 4:24 pm    Post subject: Re: 6v with okrasa Reply with quote
Same here. Except that I actually did install one not long ago on my 54' that was cranking slow. Wasn't long before my brain said:
bubs Brain wrote:
Want to rethink that relay thing? You shouldn't need it."
Swapped the starter and haven't needed it since. They are just a band-aid for a problem, but band-aids aren't always bad temporarily.
5500
5500 is offline
PostPosted: Sat Sep 24, 2022 12:20 am    Post subject: Re: 6v with okrasa Reply with quote
In addition to running a hot relay, I fabbed new 2 gauge cables, redid all grounds with larger diameter wire, added discreet relays to the headlight,fog light, wiper circuits and replaced light bulbs with LED units. My goal was to preserve as much of the original wiring and switches as possible and prevent any catastrophic electrical failures. Engine cranks effortlessly. Don't think of it as a bandaid... more of an improvement over a primitive design.
gsthomas
gsthomas is offline
PostPosted: Sun Jan 21, 2024 9:07 am    Post subject: Re: 6v with okrasa Reply with quote
The compression on my latest Okrasa build is higher so the stock-size 6V battery sometimes struggled. I upgraded to a higher capacity Optima battery and no issues since then. Also run current through relay and make sure no corrosion on both sides of the loop from battery to starter.
(o\ ! /o) (o\ ! /o) (o\ ! /o) (o = i = o)
1956 1961 1962 1973
