merv101 Samba Member
Posted: Sun Aug 07, 2022 5:51 pm Post subject: Stumbling when hot |
Hey all,
I'm sure this topic has been discussed time and time again, so please direct me to the right thread if available.
I have an 1988 VW Cabriolet with CIS-E and K-Jetronic fuel injection, and when the ambient temperature is warm/hot, the car will begin to struggle and die. The car has good pep and power, but after driving for 10 minutes or so, it wants to die. I've learned via cabby-info.com that fuel pumps are the go-to thing to replace to fix this issue. I've replaced the in-tank pump once and the in-line pump twice to no avail. The fuel filter, the fuel pump relay, and the fuel injection power supply relay have all been replaced as well. Pic for attention.
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Aug 08, 2022 8:27 am Post subject: Re: Stumbling when hot |
They did not make a Cabriolet with CIS-e, at least here in the USA.
Did you do any tests? How do you know if those pumps are any good? What is the name brand of the pump? |
Joined: August 31, 2013 Posts: 12865 Location: North Carolina
Posted: Mon Aug 08, 2022 9:04 am Post subject: Re: Stumbling when hot |
Check your distributor cap & rotor. Many aftermarket ones are made of subpar materials that melt or burn away causing similar scenarios. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Aug 08, 2022 2:44 pm Post subject: Re: Stumbling when hot |
Butcher wrote: |
Thanks for that distinction.
I can't imagine why the pumps would be faulty. In-tank is from URO Parts and in-line is Bosch. |
Posted: Tue Aug 09, 2022 8:03 am Post subject: Re: Stumbling when hot |
I would be more surprised that a new URO pump worked longer than a few hours.
Not certain what would last longer. A cold beer on a hot day, a URO fuel pump, or a Vemo fuel pump. |
