carsdlt Samba Member
Joined: May 02, 2012 Posts: 317 Location: So. OC, Calif.
Posted: Sun Jul 03, 2022 8:52 pm Post subject: SNAP!...CLUNK...GRIND... |
That's what I heard from the front as I pulled out of my driveway. When I straightened out, the 1-2" of free play in the steering wheel suddenly became 12" and the steering locked up..then popped loose. NOw I have a steering column that shifts up and down,side to side, loose as a goose.
Won't be able to get into it for a few days but I'm thinking maybe steering box or ...? _________________ Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own." |
74 Thing Samba Member
dlicious Samba Member
Joined: September 07, 2006 Posts: 245 Location: Spring(pronounced Sprang), TX
Posted: Mon Jul 04, 2022 6:07 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
And don't buy a red urethane one. They are known to disintegrate with out warning. _________________ '63 Caravelle Camper
dLk |
Semper_Dad Samba Member
Posted: Tue Jul 05, 2022 4:11 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
Ugh! That's a mess Semper Dad. Hope mine's not that bad. I suppose I'll have to pull the gas tank to get at that bad boy or can a replacement be done another way? (I just filled the tank so it will be a pain to drain it all...😠) _________________ Thanx, DLT
Posted: Tue Jul 05, 2022 6:49 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
carsdlt wrote: |
Ugh! That's a mess Semper Dad. Hope mine's not that bad. I suppose I'll have to pull the gas tank to get at that bad boy or can a replacement be done another way? (I just filled the tank so it will be a pain to drain it all...😠) |
It's one of those jobs you wished you had drained and pulled the tank AFTER you tried doing it through the wheel well.
Stay away from those orange urethane couplers. Make sure the replacement coupler has layers of both rubber and cloth reinforcement. Sometimes reffered to as a "rag" coupler. And one last thing,.....don't forget to replace the ground jumper between the coupler otherwise your horn may not work. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Tue Jul 05, 2022 9:41 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
Found one at theThingShop..plain black..looks like rubber. I've always had good luck with their stuff,but it's only $9.00. Seems kinda cheap... _________________ Thanx, DLT
Posted: Wed Jul 06, 2022 6:39 am Post subject: Re: SNAP!...CLUNK...GRIND... |
carsdlt wrote: |
Found one at theThingShop..plain black..looks like rubber. I've always had good luck with their stuff,but it's only $9.00. Seems kinda cheap... |
You'll probably pay more in shipping. Most likely an EMPI product. You never know whether it's a good product until you get your hands on it. Get the same coupler on Amazon cheaper and no postage if you are a Prime Member.
As a general rule, any part number that begins with "111" is a standard Beetle part and can be found cheaper at places that are NOT 181 exclusive sites. Not always true but worth checking out. Goes for any parts that begin with "211" also. Those are generally bus parts. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Wed Jul 06, 2022 8:57 am Post subject: Re: SNAP!...CLUNK...GRIND... |
Look at the link that I posted above. There are plenty of VW ones available, but you need to pay. |
Posted: Wed Jul 06, 2022 10:19 am Post subject: Re: SNAP!...CLUNK...GRIND... |
Yeah, I think I'll stick with the OEM stuff in the classified. Got to eyeball it first to see what I need. Stay tuned. _________________ Thanx, DLT
yel-mel Samba Member
Joined: May 07, 2015 Posts: 427 Location: Tampa Florida
Posted: Wed Jul 06, 2022 12:19 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
You can definitely do this job by pulling the front wheel and working with some jack stands. I did my a few months ago and did not pull the fuel tank. Took me about an hour. Its a bit fiddly but easy ! I also changed the steering damper at the same time.....its in the same area and very easy.
Have fun |
Posted: Wed Jul 06, 2022 2:22 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
You want one with multiple plies of fiber reinforcement. I would call whatever vendor you choose to use and ask them how much reinforcement their product has.
EMPI and CIP are just not good sources for this kind of part. |
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 186 Location: Englewood, New Jersey
Posted: Thu Jul 07, 2022 4:23 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
_________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
Posted: Thu Jul 07, 2022 5:21 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
No reinforcing cordage to be seen, not good. |
Posted: Thu Jul 07, 2022 5:57 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
Yep, if it tears then there is no safety backup without the fiber discs woven in like the urethane ones (they are known to crack). |
Posted: Tue Jan 10, 2023 9:31 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
Ok...finally got to get to this chore. New coupler in but now I have a grinding noise when I turn the steering wheel. Maybe the bushing behind the snap ring? _________________ Thanx, DLT
Posted: Wed Jan 11, 2023 9:59 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
...removed the snap ring but CANNOT get that bearing to pull off. Is there some trick to that? _________________ Thanx, DLT
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Fri Jan 13, 2023 2:10 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
hey Carsdlt,
Check and see if the 'cage" or steering crushable area part of the steering is rubbing on the gas tank when you turn the steering wheel.
I ran into that changing mine out years back, I ended up mucking with it and added some new gasket material to the gas tank to body which raised the gas tank up "just a bit" to clear that cage.
I did have to remove the tank to redo the tank to body gasket.
I can't remember if it was from changing out that rag joint or if it was when I replaced the gas tank but I defiantly had some tank to cage rub going on.
Not sure if there's another way but that fixed mine.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Posted: Fri Jan 13, 2023 9:39 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
Thanks, D ...I'll check it out and post my findings. _________________ Thanx, DLT
Posted: Fri Jan 13, 2023 9:40 pm Post subject: Re: SNAP!...CLUNK...GRIND... |
