splitface Samba Member
Joined: March 01, 2004 Posts: 114 Location: Czech republic
Posted: Thu Mar 09, 2023 8:14 am Post subject: Re: 1954 typ 23 from Austria |
myklsmyth Samba Member
Posted: Thu Mar 09, 2023 10:05 am Post subject: Re: 1954 typ 23 from Austria |
I bet that feels good! |
Posted: Fri Mar 10, 2023 4:55 am Post subject: Re: 1954 typ 23 from Austria |
driver side was hit in middle and then very badly " repaired " in past
even 2 window frames were crippled
so everything needed repair on this side outside -inside
rest of car is near perfect
except floors damaged by more then 30 years serving as mouse hotel
Posted: Thu Mar 23, 2023 1:43 pm Post subject: Re: 1954 typ 23 from Austria |
Two Glove Boxes Samba Member
Posted: Thu Apr 13, 2023 10:35 am Post subject: Re: 1954 typ 23 from Austria |
karl h Samba Member
Joined: October 10, 2005 Posts: 579 Location: austria
Posted: Mon Apr 24, 2023 12:45 am Post subject: Re: 1954 typ 23 from Austria |
karl h wrote: |
looks drivable allready! going to be at Eggenburg? |
just finished at welder
I need to do lot of stuff before registering as historical vehicle and getting special licence plates
so no sorry will NOT make it even to BD gathering which was original plan
before stuck at welders
so my 3rd BD gathering again with my 1960 dove blue combi
car was NOT driven from 1966 so more work then it looks to be safe
we got nice weather for moving
Posted: Mon Apr 24, 2023 1:14 am Post subject: Re: 1954 typ 23 from Austria |
NOS bumper holders used to fit badly twisted rear bumber which was repaired and then original holders will be used later
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5510 Location: 1st Coast
Posted: Tue Apr 25, 2023 4:53 am Post subject: Re: 1954 typ 23 from Austria |
any recommendations how to treat old paint and surface rust within
to close rust scars and do not impact old paint ?
I heard about OWATROL OIL used and there are many similar producs
some personal recommendation used on your BD ? |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Apr 26, 2023 7:29 pm Post subject: Re: 1954 typ 23 from Austria |
A lot of that surface rust can be treated with a product called CLR massaged into the surface with 0000 steel wool or a Scotch Brite pad.
CLR:
https://clrbrands.com/Products/CLR-Household/CLR-Calcium-Lime-and-Rust-Remover
Here's sloans265 side by side CLR comparison:
And here is Skim's CLR work:
Search for patina paint threads on these forums and there is some great information. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Thu Apr 27, 2023 12:33 am Post subject: Re: 1954 typ 23 from Austria |
nice results, but I want to keep patina - surface rust
I consider faded dove blue / surface rust best two tone bus combination
I just want to inhibit rust on worst places like rear lower corners
and just conservate it somehow without impacting OG paint |
Lind Samba Member
Joined: November 06, 2000 Posts: 9917 Location: idaho
Posted: Thu Apr 27, 2023 5:10 am Post subject: Re: 1954 typ 23 from Austria |
splitface wrote: |
If the rust is soaked in oil, it won't really rust anymore. There are commercial products like waxoyl. These can be used to coat the unseen areas. Any wax or oil coating on the outside will change the appearance of your paint to some degree.
Of course there is rust on the backside of every panel in every bus just slowly working it's way through the metal. _________________ .
Wanted:
RockStock Samba Member
Joined: November 26, 2004 Posts: 3929 Location: England
Posted: Thu Apr 27, 2023 10:33 am Post subject: Re: 1954 typ 23 from Austria |
Collinite 476 Auto Wax scores high marks for patina rides in the UK
After reading reviews, I opted for this for my ‘56 Karmann Ghia (not yet applied) _________________ -StockRocks- |
Posted: Thu Apr 27, 2023 10:15 pm Post subject: Re: 1954 typ 23 from Austria |
For protection, You could try Fluid Film. It is lanolin based, and seals with a penetrating, water repellant film. As Lind says, these types of products will darken the appearance of the paint. _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Fri Apr 28, 2023 4:57 am Post subject: Re: 1954 typ 23 from Austria |
RockStock wrote: |
After reading reviews, I opted for this for my ‘56 Karmann Ghia (not yet applied) |
thx appreciated .. available even here in Czech republic , will try it |
Barndoor Mafia Il Capo
Joined: August 23, 2001 Posts: 6194 Location: EUSKAL HERRIA
Posted: Fri Apr 28, 2023 9:02 am Post subject: Re: 1954 typ 23 from Austria |
Beautiful Bus .......... |
Stocknazi Samba Member
Posted: Sun Apr 30, 2023 9:10 am Post subject: Re: 1954 typ 23 from Austria |
j.pickens wrote: |
For protection, You could try Fluid Film. It is lanolin based, and seals with a penetrating, water repellant film. As Lind says, these types of products will darken the appearance of the paint. |
Fluid Film is some awesome stuff. You could also used some boiled linseed oil, but it probably will not last as long as the FF.
Whatever you use please don't spray with clear coat. It looks like $hit and ruins the OG paint IMO.
This has to be one of the best preserved barndoors on the planet, just beautiful. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Mon May 01, 2023 11:39 am Post subject: Re: 1954 typ 23 from Austria |
I will just wax most of paint ..
sadly not many survived in mostly original paint
this one had accident on driver side where 1/2 paint not original
rest of car is OG factory paint luckily because of accident not much rust
because it was in traffic for only 10 years cca
here you can see "quality" of factory paint job
drops of paint visible on top of engine compartment and below front lower nose line
