matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Braukuche Samba Member
Posted: Tue Mar 26, 2024 7:46 am Post subject: Re: 67 Sparsamba repair from Austria |
What sized engine are you building? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
Posted: Tue Apr 02, 2024 1:49 am Post subject: Re: 67 Sparsamba repair from Austria |
looking great already ! The Matra flywheel locking tool is awesome, also their original keyway design. The generator stand you had first was the older unit, for the 90mm generator (same size as 30hp with cast-in-block generator stand) I think that was ca 1960 - 1963 ish. My 62 beetle still has a 90mm gen. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Mon Apr 08, 2024 8:02 am Post subject: Re: 67 Sparsamba repair from Austria |
I would be afraid to run lines and position a cooler in front like that.
I use a stock 71 up doghouse cooler on my 1800 mini stroker in my Westfalia with no heat issues. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Apr 08, 2024 3:26 pm Post subject: Re: 67 Sparsamba repair from Austria |
Huetti_1989 wrote: |
Braukuche wrote: |
I use a stock 71 up doghouse cooler on my 1800 mini stroker in my Westfalia with no heat issues. |
Don't afraid, i not going to big off-road adventures i think, and if, the oil cooler pipes are really heavy duty.
We had 30 degrees here yesterday, some years ago we had snow here in that tome of the umyear... so i need to cool down.
Interesting that your doghouse keep the engine that cold, did you have a oil temp instrument?
-Christian |
My fingers.
Yeah I saw the temps on Tageschau. That’s warmer than here. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3450 Location: San Diego
Posted: Mon Apr 08, 2024 4:48 pm Post subject: Re: 67 Sparsamba repair from Austria |
There are oil cooler/fan setups that mount to the torsion tube with U bolts or brackets and can be fitted with a Thermostat. Alot closer to the motor. The high perf Vw Buses here in the usa use that setup alot to control temps. Usually a 180F Tstat |
Posted: Tue Apr 09, 2024 2:26 am Post subject: Re: 67 Sparsamba repair from Austria |
Braukuche wrote: |
Braukuche wrote: |
-Christian |
My fingers.
Yeah I saw the temps on Tageschau. That’s warmer than here. |
ok.
crazy Weather.
chrisflstf wrote: |
I thinked about that, but i dont like the cooler shooted by stones from the Tires.
I run a front oil cooler on several of my cars with no termostate, it worked good with low level oil temp on long Distance Trips.
-Christian _________________ My 1957 semaphore Single Cab:
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1954 Deutsche Bundespost Barndoor:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34 Flipseat Westfalia:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751 |
Posted: Tue Apr 09, 2024 6:04 am Post subject: Re: 67 Sparsamba repair from Austria |
I like your clever use of doghouse/firewall engine tin and routing the oil lines through the existing hole. must be much easier to feed the connectors through.
It would be very easy to add heavy duty ( 4 or 5mm) skid plate/ram protection bracket under your front oil cooler. if you really run over a deer or road debris thats big enough to rip off the cooler, you already hove some bigger problems by then... ...hopefully never, fingers crossed !
love your 'small' license plate.... _________________ Hotrods, Fords, Veedubs and Triumph Twins !
Posted: Mon Apr 15, 2024 1:28 am Post subject: Re: 67 Sparsamba repair from Austria |
djfordmanjack wrote: |
love your 'small' license plate.... |
the oil cooler is mounted on rubber, so they would bent back it they get a hit.
Yes,you are right, and i still have no lowered Bus, there is enough room under it to lay there if you don´t have a Beer Belly
Some very Intense Days and Nights, after that i tried the first test drive and failed while tried to drive out of the shop.
The reverse rear popped out, so back in, i adjusted the shifter many many times, meanwhile i tived out and in 1 times bevore it poped out again.
i checked everything end ended in shortening the plastic busching in the ww front shiftig rot, it stops the rod get completly in front.
after that i get some test driving, what a great feeling!!
-Christian
MY 1967 Sparsamba:
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1966 Location: Manitowoc, WI
BarryL Samba Member
Joined: November 01, 2004 Posts: 14274 Location: Casa de Oro, California
Posted: Mon Apr 15, 2024 6:20 pm Post subject: Re: 67 Sparsamba repair from Austria |
Yes ^^^ it looks all worn and original 21 window from the same date new. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12413 Location: Over 2002 posts deleted!
Posted: Thu Apr 18, 2024 9:51 am Post subject: Re: 67 Sparsamba repair from Austria |
That's pretty sleek? _________________ Some people are so busy being clever they don't have time enough to be wise. |
BarryL Samba Member
Posted: Thu Apr 18, 2024 6:19 pm Post subject: Re: 67 Sparsamba repair from Austria |
For sure. You should just build a girlfriend. |
