toxicavenger70 Samba Member
Posted: Wed Jan 18, 2023 3:20 pm Post subject: Re: andrigs fan |
My hat is off to Andrigs thinking out of the box and trying some new. Very few people have the balls to do so. |
vamram Samba Member
Posted: Fri Feb 03, 2023 5:59 am Post subject: Re: andrigs fan |
bump for another reader. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1309 Location: North Carolina
oprn Samba Member
Joined: November 13, 2016 Posts: 12896 Location: Western Canada
Posted: Fri Feb 03, 2023 9:32 am Post subject: Re: andrigs fan |
Very cool stuff indeed! The double fan idea looks really promising. He is still sticking with straight blades it seems and I wonder if curved blades would be more efficient both in terms of air flow, noise and air temperature increase through the fan.
I also wonder at what point does increased air flow start to be counter productive. The cooling fins on the VW head and cylinders have a finite area to pass air through. At some point they will become the bottle neck to more air flow. Beyond that point increasing the airflow will become a detriment to cooling as the higher the fan shroud pressure goes the more the air is heated by the fan and the smaller will be the benefit of higher flow rates.
The other thing I wonder about is are his test results documented with a full set of tins with flaps, as in upper and all the lowers or some combination of the two? And what would be the difference/effectiveness of his new fans, full tins and flaps vs the usual hot rod practice of only the top two tins? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
vamram Samba Member
Posted: Fri Feb 03, 2023 9:47 am Post subject: Re: andrigs fan |
I don't believe he uses factory flaps w/a thermostat. He manufactures and sells a set of replacement flaps that are in a fixed position at all temps. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
oprn Samba Member
Posted: Fri Feb 03, 2023 9:48 am Post subject: Re: andrigs fan |
I think for the vast majority of the air cooled crowd the stock fan is more that adequate. For the high HP guys this increase in volume is perhaps a useful thing. For us regular folks I can see the lighter weight of the fan being a good thing and if it puts out a higher volume of air that could mean we could gear our cars higher and run lower RPM on the highway for better fuel efficiency and longer engine life.
On second thought maybe the VW Bus guys will benefit from this more so than the 1/4 mile guys!
It would also be sweet to have a quieter fan for long trips! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1509 Location: Buford GA
Posted: Sat Feb 04, 2023 5:37 pm Post subject: Re: andrigs fan |
oprn wrote: |
The other thing I wonder about is are his test results documented with a full set of tins with flaps, as in upper and all the lowers or some combination of the two? And what would be the difference/effectiveness of his new fans, full tins and flaps vs the usual hot rod practice of only the top two tins? |
A more efficient fan could be turned slower. |
94touring Samba Member
Joined: October 24, 2020 Posts: 323 Location: Oklahoma - OK
Posted: Sat Feb 04, 2023 7:05 pm Post subject: Re: andrigs fan |
Just checked out his new design today, based off a 547 porsche, and it looks like it might work. I liked his shroud with the built in flaps. I welded in fixed flaps on my shroud too. Also blocked off my oil cooler and only run external. Having the bottom of the shroud over the case enclosed is a perk. As a bus owner who drives in high temps, loaded to the gills, I'm up for trying his new design. Not sure if there's clearance for my CSP push-pull throttle linkage though. |
lowbus Samba Member
Joined: August 07, 2004 Posts: 74 Location: tucson, AZ
Posted: Sun Jul 09, 2023 9:31 pm Post subject: Re: andrigs fan |
I have the 1st Gen fan, I do not have the nut. Does anyone have the nut? Photos, dimensions? Better yet, send me it so I can duplicate it for my fan and I will send it back.
I have sent a few messages to andrig with no response. I am planning on assembling my engine next month.
Thanks. _________________ Looking for license plate donations (or super cheap). Do not need to be vintage. Would like to have plates from as many countries and states as possible. |
mikemck Samba Member
Posted: Mon Jul 10, 2023 2:41 pm Post subject: Re: andrigs fan |
I removed my Andrig's fan and probably have the parts you need.
It would be easier for me to identify them if you could send photos.
If you can do that, I would be happy to send them to you. |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1323 Location: Modesto, CA
Posted: Mon Jul 10, 2023 3:42 pm Post subject: Re: andrigs fan |
mikemck wrote: |
Curious why you removed the fan. I have one for my 1641. Not sure what I'll do for my future 2180.
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
Posted: Mon Jul 10, 2023 5:03 pm Post subject: Re: andrigs fan |
I removed it because I didn't like the sound it made in my open car.
After I got it off I noticed that the hole in the plastic was started to open up a bit. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9869 Location: Oregon
Posted: Mon Jul 10, 2023 10:29 pm Post subject: Re: andrigs fan |
H2OSB wrote: |
H2OSB |
Do like every other 2180 builder/driver. Run a Doghouse fan, oil cooler.
Built right, they don't run any hotter than a stock 1600.
I'm experimentally running Andrig's fan on a 2276. We'll see how that works out! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
txoval Samba Member
Joined: January 23, 2004 Posts: 3574 Location: The Woodlands, TX
Posted: Tue Jul 11, 2023 5:01 am Post subject: Re: andrigs fan |
If you have the original, you need the “hub kit” that he put out.
The original washer/nut would come loose |
H2OSB Samba Member
Posted: Tue Jul 11, 2023 7:24 am Post subject: Re: andrigs fan |
I do have an original fan. Andrig sent me the hub shortly after he discovered the need.
67rustavenger. I made a mistake, I'm planning a 2110. I WANT to go 2180, but I keep forgetting my biggest carbs are 44 IDF. I don't want to buy anymore carbs. Now, if I lose my mind and decide to go EFI and use my VFR800 ITBs, I may reconsider the 2180. Honestly though, I'm sure I'll be happy with a 2110. Particularly if I build it to do what I want.
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3315 Location: Rapid City, SD
Posted: Tue Jul 11, 2023 9:08 am Post subject: Re: andrigs fan |
H2OSB wrote: |
H2OSB |
What makes you think a 2180cc wont run with 44's?
Brian _________________ www.type-emotorsports.com |
H2OSB Samba Member
Posted: Tue Jul 11, 2023 9:38 am Post subject: Re: andrigs fan |
Ignorance. If you say it will, I'm down to build a 2180.
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15343 Location: Deep in the 405
Posted: Tue Jul 11, 2023 10:09 am Post subject: Re: andrigs fan |
H2OSB wrote: |
H2OSB |
Carbs don't care what size the engine is. You can put a stock Solex on a 2180 and it will run. I've run 44 IDF's on my 2276.
Dual 44 IDF's can support about 180 HP. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
H2OSB Samba Member
Posted: Tue Jul 11, 2023 11:39 am Post subject: Re: andrigs fan |
Good to know. In all honesty, I looked at CBs list of engine build kits and the biggest displacement with dual 44s is the 2110. The 2180 goes to dual 48s. I figured they would go on the conservative side, so thought I'd be safe with my 44s. I've also heard 2110 was the biggest displacement while maintaining factory-like reliability. ALL based upon what I've read and interred, not actual experience.
