clooney Samba Member
Posted: Sat Dec 05, 2020 1:47 pm Post subject: Type 1 DTM shroud |
there are quite a few threads on this but most are a few years old. Has anyone fitted and ran these recently?
I have had good luck with stock type 1 cooling, but i am thinking of giving the DTM a try for my new build - just for the sake of trying something different
new engine will be 2276, Tims Stage 3 heads CB Snakeskin valves, 1-5/8 exhaust ports Oteva springs, titanium retainers, WebCam 86C, Thorsten lifters, Pauter 1.4, HD aluminium pushrods, 10.5:1 CR, 48 DRLAs, Berg 26mm pump, CSP relief cover, Scat 2 quart sump. full trim, full interior bug, weekend driven , mostly street fun. transmission is 8 years old Rancho built, stock ratios, 4.125, super diff and old SAW axles. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6035 Location: CONGERS, N.Y.
Posted: Sat Dec 05, 2020 2:26 pm Post subject: Re: Type 1 DTM shroud |
Hi Clooney,
As you may know I wrote the T-4 Upright Conversion Manual and worked with Joe of Oregon Performance the creator and Jake Raby who took over Joes operation.
My manual is based on DIY, with T-1 and T-4 parts using a 36 hp fanhousing with doghouse. Using a T-4 engine and the T-1 fanhousing did a great job up to as far as I can prove 160 hp, and actually heard of more power full engines in Europe.
The DTM was designed to put out more cooling air equally to both sides of the engine. Down The Middle, and also had separate cooling to the oil cooler.
Again never heard of a DTM overheating.
Now lets go into the Gray area !!!!! The Type IV has heads that are 1/3rd larger then T-1 heads which dissipate heat much better then a T-1. Some actually have a hard time reaching running temp..
Even though you have smaller heads with the air the DTM puts out you should not have a problem.
As for the T-IV heads being larger most likely is the reason why my Cali Style worked with the T-4 engine .
As you know the DTM does not have a thermostat, that may be something to consider if you live in a colder climate as I do in NY. Then again your engine is not a T-4 so it may run hotter, which may eliminate the need for a thermostat.
Everything I said was a guess. Lets hear from someone that has a T-1 with a DTM.
It will be interesting. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Sat Dec 05, 2020 2:33 pm Post subject: Re: Type 1 DTM shroud |
thanks Joe, no, not concerned at all with no thermostat flaps, i prefer an oil thermostat instead which i run in all my motors.
i am curious to know the fit and finish of the DTM too, especially at the edges/corners and also the manifold area. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Dec 05, 2020 3:08 pm Post subject: Re: Type 1 DTM shroud |
Would it be hard to have a thermostat operating at the shroud intake? Just thinking out loud, I've never seen a DTM in the flesh. |
jg405i Samba Member
Joined: January 01, 2007 Posts: 40 Location: Oceanside, Ca
Posted: Sat Dec 05, 2020 3:31 pm Post subject: Re: Type 1 DTM shroud |
I have one that i am installing as of now and i see a lot of work a head of me.
I will need be be working with fiber glass to fit the case tight. i am finding alot of leaks that are not with OME tin. It just dose not drop on and go,but maybe it's just me. |
Fern_b57 Samba Member
Joined: November 05, 2023 Posts: 3 Location: Los Angeles
Posted: Fri Apr 19, 2024 3:01 pm Post subject: Re: Type 1 DTM shroud |
So if they are so great are they still available for purchase for a type 1 engine? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77059 Location: Sneaking up behind you
Posted: Fri Apr 19, 2024 3:06 pm Post subject: Re: Type 1 DTM shroud |
Fern_b57 wrote: |
After a 2 second Google search....
https://lnengineering.com/vw-type-1-dtm.html
Quote: |
Due to high demand, current lead time is approximately 26 weeks wait on all DTM kits. |
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9841 Location: Oregon
Posted: Fri Apr 19, 2024 4:28 pm Post subject: Re: Type 1 DTM shroud |
Glenn wrote: |
Fern_b57 wrote: |
Quote from inengineering.com website,
There was a DTM kit in the classifieds this morning. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1185 Location: San Angelo, Texas
Posted: Fri Apr 19, 2024 4:33 pm Post subject: Re: Type 1 DTM shroud |
A friend of mine had some bidness in California he had to attend to, and while he was there, (He is a Porsche freak) he went by a place called Powerhaus. Nice looking shop and all. He said they had billet engine cases and building them into 700 hp supercharged and turbo motors....he said they would blow off about any street car out there. Powerhaus uses these fan shrouds. May not be what you are looking for, but they are cool.
_________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
BFB Samba Member
Posted: Fri Apr 19, 2024 5:32 pm Post subject: Re: Type 1 DTM shroud |
Without the fan in it that shroud looks like a Halloween decoration _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
Posted: Fri Apr 19, 2024 8:24 pm Post subject: Re: Type 1 DTM shroud |
67rustavenger wrote: |
Glenn wrote: |
Fern_b57 wrote: |
There was a DTM kit in the classifieds this morning. |
Are they a legit company. If high in demand why 26 wait . Don’t want to be a statistic paying $700 and not being able to ask if it’s almost done!! Sounds funny you can’t ask for update if something you paid for . Mofoco vibes.. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5439 Location: Holland, MI
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4345 Location: Los Angeles, CA 90016
Posted: Tue Apr 23, 2024 12:12 pm Post subject: Re: Type 1 DTM shroud |
Kevin Zagar has had to fit many, and he hates it. They require tons of work to fit. I did one before, and had to slot everything and shorten the alternator stand about .200". _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 420 Location: Nowhere, USA
Posted: Tue Apr 23, 2024 12:36 pm Post subject: Re: Type 1 DTM shroud |
bugguy1967 wrote: |
Kevin Zagar has had to fit many, and he hates it. They require tons of work to fit. I did one before, and had to slot everything and shorten the alternator stand about .200". |
I've run these since 2005 on several different engines. They require trimming around the intake manifolds, and if running a bubble-top AL case in the center, just like every shroud ever made. They fit a mag case pretty much perfectly. My engines are almost always stock-width, so I can't speak to variations in that dimension.
No doubt, $700 is a lot for a chunk of FG and some pop-riveted aluminum pieces. That said, they take no more work to fit than the average 36 hp shroud and work as advertised -- I monitor all 4 cylinder temps at the plugs and the delta is within 10 deg. Do what you want, but I've never had to change anything on the alternator stand and I've purchased 4 of them over the years.
Your mileage may vary. _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Tue Apr 23, 2024 1:13 pm Post subject: Re: Type 1 DTM shroud |
Not a type1, but I did one on a 2.0 914 base engine quite a few years ago.
That combined with the 914 3/4/5 gearing was absolutely epic. That car would keep up with 911's all day long and the engine wasn't a big build.
Cooling was fantastic, constant even oil temp, and no issues on the hottest days pushing it as hard as I could.
I think this was a 4th gear pull. So...it had a ways to go.
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Wed Apr 24, 2024 7:53 pm Post subject: Re: Type 1 DTM shroud |
58 Plastic Tub wrote: |
bugguy1967 wrote: |
Your mileage may vary. |
. So you've ordered from LN?
Thank you |
