What did you do to your Eurovan or T4 today?
Forum Index -> Eurovan Share: Facebook Twitter
02Berry
02Berry is offline
PostPosted: Wed May 24, 2023 11:06 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Welp.
Here's what I did to my Eurovan today. ... well, it was the other day, actually.
Seems to have happened when I hit a pothole, hard.
(I'll be asking advice in a separate post.)
Learned to drive in a '67 Splitty.
New to '02 T4 EVW world.
Third generation camper family.
bikes!
bikes! is offline
PostPosted: Thu May 25, 2023 11:16 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
02Berry wrote:
Welp.
The exhaust on my 02 Weekender suffered a similar fate. I replaced it with the Techtonics Tuning stainless cat back system. Highly recommend for ease of installation. See my post earlier in this thread here: muffler fix.
02Berry
02Berry is offline
PostPosted: Thu May 25, 2023 3:40 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
bikes! wrote:
The JB weld "repairs" done to the holes in my van's exhaust system during a camping trip last month did not fare well, so I replaced the rusty and leaking stock exhaust with Techtonics Tuning stainless steel dual muffler system.
[snip] ... [/snip]
And, it sounds great - nice VR6 rumble when accelerating, but barely noticeable at highway speeds.
[snip]
How does it sound, compared with the stock exhaust system?
bikes!
bikes! is offline
PostPosted: Thu May 25, 2023 7:34 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
I think it is quieter, but the stock exhaust had a number of pinholes before it let go completely, so it’s a relative comparison. With the windows up and the stereo off, I can sort of hear it. They offer two versions: single and dual muffler. I got the dual.
HeyCrutch
HeyCrutch is offline
PostPosted: Fri May 26, 2023 12:26 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Added manual lumbar adjustment to my 1997 EVC driver's side seat.
Full write up here ... https://www.thesamba.com/vw/forum/viewtopic.php?p=10059539#10059539
Scott97EVC
Scott97EVC is offline
PostPosted: Fri May 26, 2023 9:47 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
quote="HeyCrutch"]
Scott97EVC wrote:
HeyCrutch wrote:
Started a cabinet facing upgrade project today. Will do the wardrobe doors and a couple of the walls arounds the cabinets next round.
Really like the wood look Thumbs Up , mind sharing how this is done?
It's just peel n stick wallpaper that I got off of Amazon. I did all the cabinet and wardrobe doors plus a couple of the wallsl. I still need to do the wall to the right of the galley and the wall next to the heater output. Used a razor blade to cut around the edges and any holes
It's not perfect - I have gotten some bubbles, but the cost was pretty low.[/quote]
I went and found some fun peel and stick online, here's my first pieces done. As you said, a few bubbles but good enough for sure. I also found same sized latches in black metal, It was that or paint the latches black because I can't get the plastic ones clean, but since they'll be handleda lot I figured I didn't want to paint them and it would be fussy to get right. So I found some with locks, two will get those and the rest non locking. Fridge getting a black coating of the flexible paint as well. I may remove it, but probably not right away.
HeyCrutch
PostPosted: Mon May 29, 2023 6:53 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
QUESTION + Where did you source those new pulls/latches? Did they fit right into the existing holes? I like the sounds of being able to lock a door.
QUOTE
[/quote]
HeyCrutch
PostPosted: Mon May 29, 2023 6:55 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Question: where did you source those new pulls/latches that lock?
Scott97EVC
PostPosted: Mon May 29, 2023 9:46 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
The links go to Amazon, you might also find them at a marine supplier?
The locking ones
2 Sets PUROCEAN Solid Metal Marine Lift Latch Full Metal Slam Latch Handle Lift Slam Lock for RV Truck Boat Marine Hatch Cabinet Deck Door with Size 2" https://a.co/d/7tiM1Xq
The regular
LATCH.IT RV Flush Latch Lock | 2 Pack Black Flush Slam Latch | Flush Mount Latch | 100% Metal Boat Latch | Heavy Duty RV Boat Lid Lock | Fits Lock Holes w/Diameter of 2” & Door Thickness up to 0.5”! https://a.co/d/hjbkbhi
They fit the same hole as the gray, but some are going to need modification to the bit of metal the latch latches onto, because the latch bit sticks out further in the new ones than the original gray ones. I also needed to get longer bolts for the locking ones because they were not long enough for the thickness of the cabinet.
Scott97EVC
PostPosted: Thu Jun 08, 2023 4:32 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
DIY seat covers from Mexican style blankets
Awesome wife did the sewing after I cut and pinned the headrest pieces.
darrenhatina
darrenhatina is offline
PostPosted: Fri Jun 16, 2023 9:08 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
I tried to refill my LP tank recently after a long camping hiatus and discovered a completely seized pin release mechanism. Fairly involved process to unseize everything starting with a WD40 bath but ultimately requiring repeated blowtorch & water quenching to finally get it apart. Packed it full of anti-seize compound and hopefully it will be good for another 30 years.
Scott97EVC
PostPosted: Fri Jun 23, 2023 5:28 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
This was showing its age too well… but no more.
HeyCrutch
PostPosted: Fri Jun 30, 2023 5:33 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Learned how to replace coils! When I bought Ghost, the 1997 EVC, last year it had a Firestone inflatable bag airlift system installed. I didn't know a lot about the system and never used it. Installing these new Supplex HD coils was the last step in getting the van back to how it should be. Gotta say that the combination of the Bilstein HD shocks, the 16 alloys/Yokohama tires, and the Supplex HD coils has really improved the ride over what it was before (stock shocks, old air bag coils, and 15 steelies with worn out tires. Thanks to MtnbikeMike for letting me borrow his impact driver. Without that I couldn't get the top shock bolt loose.
Before
After
Working to get the front end up to proper height. Got one torsion bar nut moving but the other is still not moving. Continuing to drench it in penetration oil. It will eventually turn I'm sure, and I'll finally get the van level on all corners (with the required rake up front). One last alignment and it should drive as good as it will ever drive.
And I finally got around the finishing the texture treatment. I did the bumpers last fall as they were easy to just remove and spray. Spraying the wheel arches and lower sills required a lot of taping ... so I had been putting it off until school got out (I'm a middle school teacher).
Before
During
After
HeyCrutch
PostPosted: Mon Jul 03, 2023 1:05 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Knowing the front passenger side wing/fender is a known debris trap that can lead to rust, I decided to get into mine to see what the case was. Here's what I found, and what it looks like after clean out. Thankfully it hadn't led to a rust situation.
This next photo with the wing removed was taken after I'd tried to remove a lot of the debris by hand (without fully removing the wing). IOW there was a lot more debris present than what is seen here.
Scott97EVC
PostPosted: Thu Jul 06, 2023 5:09 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
HeyCrutch - nice work on the cleanout, now I have one more to-do item…
Scott97EVC
PostPosted: Mon Jul 10, 2023 11:42 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Removed Norcold, capped the LP line and added sound dampening (gowesty) while I was at it. Ugh, dirty back there, glad I did it for that cleaning alone. I’ll slide my small 12v chest fridge in there for now, have not decided how I’ll use the space yet but I’m camping this week so, that’ll help me think it out. I found a YouTube video pretty easily that gave me the confidence to tackle this project. https://youtu.be/1jUNugWFcj8
HeyCrutch
PostPosted: Tue Jul 11, 2023 7:01 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Keeping things LP gas-related here in the "what did you do" thread today ...
The lower skid plate for my under-slung LP tank that protects the valves, gauge, and other controls was in pretty rough shape. Bottom of it was completely rusted over. Top was covered in tar spray, rust, grime, etc.
Popped it off (2 bolts), used Bug & Tar on the safety/instruction decals, gave it a quick once over with a wire brush on the raised rust areas, sprayed it a couple times with a RusOLeum Rusty Metal Primer, then 2 base coats of Arctic White, and a couple of clear coats afterwards. Wasn't trying to make it look perfect; just better than before. The Arctic White was supposed to be a direct factory OEM color match, but it turned out way whiter/cooler than the rest of the van. This might be due to aging on the van's original paint. The Previous owner had the a-pillars done and the paint on those is also whiter/cooler than the rest of the van.
It would probably look better painted black to match the lower sil of the body, but the stuff I've read discouraging the painting of an LP tank black led me to opt for the arctic white.
Anyway, here're are photos - not the best shots but should give the idea.
BEFORE (zoomed from an old photo)
Removing tape from over the safety/instructional decals
Top Side post painting and tape removal
Re-attached to the van
Maybe the cleanliness of the lower skid plate will help any uneasy LP gas attendants go ahead and fill 'er up. Can't hurt.
One day I'll get around the dropping the tank and giving it the same exterior cleanup.
02Berry
02Berry is offline
PostPosted: Thu Jul 20, 2023 8:20 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Finished four more things on the EVW's summer to-do list:
    Got new tires
    Applied the new Westfalia decals to the front & rear of the repaired & repainted pop-top
    Got a new cooler (okay, so that's not exactly doing something to the vee dub, but
    Received & installed the VW logo wheel center caps, replacing the plain-black plastic ones.
Not much left on the list, besides going camping!
Joshwa
Joshwa is offline
PostPosted: Wed Aug 16, 2023 8:37 am    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Just hauled home this 67 from Los Angeles to Seattle, behind my workhorse 1.9L TDI Eurovan. 101 nearly the whole way, as it was hot as hell on I5. The jeremyrockjock tow bar was rock solid. It was smooth sailing at 60mph on flats, but a pig on some steep hills, having to reel back to 3rd gear. long downhills were a little nerve wracking also. My fuel mileage was reduced to 26mpg from my normal 30mpg average, for the length of the trip. Fun times. Now to figure out where I start with the bus.
This was a stop in the coastal Redwoods, on the Avenue of the Giants.
93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93
bigfoot_ev
bigfoot_ev is offline
PostPosted: Thu Aug 17, 2023 10:00 pm    Post subject: Re: What did you do to your Eurovan or T4 today? Reply with quote
Joshwa wrote:
Just hauled home this 67 from Los Angeles to Seattle, behind my workhorse 1.9L TDI Eurovan. 101 nearly the whole way, as it was hot as hell on I5...
Much better choice anytime to take 101. We have relatives in LA and I have done the drive from Seattle to LA multiple times on 101 and 1. One time heading north right after Avenue of the Giants when the road straightens out before Fortuna some A-hole did a daring pass and gave us the finger. That's life in a VW van, I think it was because we were going the speed limit.
What's the plan for the '67? Perhaps something like this? https://youtu.be/59j-a86YU9M
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 7 of 8
