BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Aug 09, 2019 8:50 am Post subject: Re: Can-Am style Fiberglass body |
I sent you a couple messages via Samba |
squareweave Samba Member
Joined: November 15, 2004 Posts: 449 Location: British Columbia
Posted: Sat Aug 10, 2019 8:53 am Post subject: Re: Can-Am style Fiberglass body |
Looks like they used Ford Maverick tailights .
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 648 Location: Reno NV
Posted: Sat Aug 10, 2019 9:14 am Post subject: Re: Can-Am style Fiberglass body |
Ford Maverick tail lights
Dodge Charger fuel cap
Datsun windshield looks like a Datsun 1500 |
Posted: Mon Aug 26, 2019 7:06 pm Post subject: Re: Can-Am style Fiberglass body |
I picked up a 68 doner it has been sitting for about 10 years
Posted: Mon Aug 26, 2019 7:08 pm Post subject: Re: Can-Am style Fiberglass body |
I got the body on and set at the rear and found out that something is not right
Posted: Mon Aug 26, 2019 7:11 pm Post subject: Re: Can-Am style Fiberglass body |
the rear body bulkhead does not line up with the bulkhead on the pan
Last edited by halfassleatherworks on Mon Aug 26, 2019 7:23 pm; edited 3 times in total |
Posted: Mon Aug 26, 2019 7:14 pm Post subject: Re: Can-Am style Fiberglass body |
If i line up the bulkheads the rear tires are way out
Last edited by halfassleatherworks on Mon Aug 26, 2019 7:20 pm; edited 2 times in total |
Posted: Mon Aug 26, 2019 7:16 pm Post subject: Re: Can-Am style Fiberglass body |
the front lines up fairly close
Posted: Mon Aug 26, 2019 7:28 pm Post subject: Re: Can-Am style Fiberglass body |
kinda looks like a Mad Max car
Last edited by halfassleatherworks on Mon Aug 26, 2019 9:20 pm; edited 1 time in total |
Posted: Mon Aug 26, 2019 7:31 pm Post subject: Re: Can-Am style Fiberglass body |
with the extra room at the rear i may go mid eng
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Mon Aug 26, 2019 7:35 pm Post subject: Re: Can-Am style Fiberglass body |
It would seem like the chassis needs to be shortened as mentioned in the magazine article. _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
Posted: Mon Aug 26, 2019 7:42 pm Post subject: Re: Can-Am style Fiberglass body |
it calls for 14.5" when you line up the tires and fenders its moves the bulkhead of the body way forward to the foot well in front of were the rear seat is. in the pic that is were the battery would have been at. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20396 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Aug 27, 2019 7:11 am Post subject: Re: Can-Am style Fiberglass body |
Yes chassis is a wee bit long....
Measure twice cut once....If you get it right the first time build is a lot easier....
Posted: Tue Aug 27, 2019 11:25 am Post subject: Re: Can-Am style Fiberglass body |
top pic is with the body set over the front tires .
bottom pic is with the rear fenders and tires centered.
23" - 14.5" = 8.5 " gap
It is going to make a short cab
slalombuggy Samba Member
Posted: Tue Aug 27, 2019 1:44 pm Post subject: Re: Can-Am style Fiberglass body |
You need to move the front end back. Measure the distance from the end of the master cylinder to the front beam and take some out there. I know a guy who built a custom on a 24" shortened pan and never though about driving position. It's painful watching him drive the car and there is no way I can physically get in his car, and it has no roof.........
Honestly at this point I'd start thinking about a tube frame to put that body on. It will be less work square tube for the basic floor is easy to work with. Buy a set of beam clamps and a 2.25" hole saw to cope them into the chassis tubes with. Then you can mount pedals far forward with the master at the beam and get some leg room in the car.
D a search for "tube chassis" in the gallery section and see what others have done, it will give you some ideas.
The first page or 2 or my race car build might give you some ideas. ignore all the race stuff and use a torsion housing in the rear. and you'll want to make it a bit wider too
https://www.thesamba.com/vw/forum/viewtopic.php?t=687219&highlight=
brad |
Posted: Tue Aug 27, 2019 1:59 pm Post subject: Re: Can-Am style Fiberglass body |
well i went out and put a block in it for a seat and your right, my knees are bent above the dash and the dash is only about 1 foot from the pedals so looks like a tube frame, and I may have to cut the body anyway, I just need to decide on what I will use for the engine and trans, have a complete 1.8 type 2 eng with a automatic, a complete type 3 single port with a automatic, and the 68 swing axle. decisions decisions. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 855 Location: South Florida
Posted: Wed Aug 28, 2019 12:55 pm Post subject: Re: Can-Am style Fiberglass body |
slalombuggy wrote: |
.... 24" shortened pan ... |
That's what my pan is, actually 24.5" shorten'd, resulting in 70" wheelbase; and, very cramp'd seating area. After almost 10 years of driving with steering wheel between knees, I moved pedal cluster 5" forward, made it pretty comfy for me at just 5'-7" tall.
Mini-Camaro shell mounts such that passenger cab backwall butts up against rear torsion tube ends:
Built my seat backrest as far rearward as possible: |
Posted: Tue Dec 03, 2019 12:02 pm Post subject: Re: Can-Am style Fiberglass body |
update been a few months but I did get a titled 69 T1 pan to use. decide to use a set of wheels I had laying around 76 to 82 Corvette wheels. with adaptors, 225/60/15 on the front and 275/60/15 on the rear. will have more updates ,but first things first the wifes Bug comes first.
_________________ Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, ***** |
biggraham Samba Member
Posted: Tue Jul 14, 2020 11:28 pm Post subject: Re: Can-Am style Fiberglass body |
Looks similar to this! _________________ 67 S0-42 Pop-Top Walkthru |
Rome Samba Member
Joined: June 02, 2004 Posts: 9673 Location: Pearl River, NY
Posted: Thu Jul 16, 2020 1:46 pm Post subject: Re: Can-Am style Fiberglass body |
From the front fenders rearward, the body shape reminds me of the Hot Wheels "Jackrabbit" but without the roll bar.
Wishing you perseverence and enjoyment working on the car, to offset your illness. |
