TRS63 Samba Member
Joined: December 17, 2017 Posts: 1000 Location: Stuttgart - Germany
halbug Samba Member
TRS63 Samba Member
halbug Samba Member
DariuszPlich Samba Member
Posted: Tue May 23, 2023 1:30 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Very good job. It's nice to see such an approach to sheet metal repair. |
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Tue Jun 13, 2023 11:54 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Every post a lesson in craftsmanship and perseverance.
I can't wait for the next one. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Marcdeb Samba Member
art_lessing Samba Member
Joined: February 20, 2014 Posts: 154 Location: Sacramento
Posted: Wed Jun 14, 2023 11:29 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hey man, since we are so deep in this thread, can you answer these questions:
what welder?
what settings?
what metal?
do you mock everything up with carboard first?
You make it all look so easy. Is it as easy as it looks , or do you go through much headache before the final result?
Thanks for your hard work! |
TRS63 Samba Member
Posted: Fri Jun 16, 2023 12:39 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Thanks a lot guys for the support, really appreciated !!
art_lessing: happy to help, here the answers, please feel free to ask more if needed !
-what welder?
I have both a MIG-Welder (Migatronic Rallymig) and a TIG-Welder(Stahlwerk AC/DC 200) and use both almost as much depending on the access (to weld and to planish), the condition of the metal,...
-what settings?
My MIG-Welder has pre-configurarion depending on the thickness of the metal and they are really good, it is really rare that I need to change something. For the TIG-Welder: 30A/millimeter thickness of the metal.
-what metal?
I bought my sheet metal from a body shop so don't know the market name. I have 0,8/1/1,5mm thickness and I try to always use the same thickness as original when redoing something.
-do you mock everything up with carboard first?
Not everything but really often!
-You make it all look so easy. Is it as easy as it looks , or do you go through much headache before the final result?
Second option definitely ! I am only a hobby-restaurator, did not study it, and it's far from my daily job so it is a lot of trial and error. More than often I try to build something, then realise another methode is necessary, and start back from new. That can be frustrating but it is also the interesting part to me as I am learning a lot on the way! I also spend a lot of time for the planning and what to do when, as to not need to undo/redo something afterwards because of forgetting a step.
So, let's make another update as I do have more to share!
The front and rear parts of the fenders will be adjusted on the car but they had a lot of holes from either bad fixes or accessories that needed to be taken care of and it's easier with them disassembled so:
Driver's side:
And fixed:
Passenger side:
And fixed:
And the antenna hole (my car won't have a radio, I love the look with the plate and only hear the flat 4-sound in my VWs):
Bests
Antoine _________________ Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
https://www.thesamba.com/vw/forum/viewtopic.php?p=10086685#10086685 |
TRS63 Samba Member
Posted: Wed Jul 12, 2023 10:44 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
So, long time no update but a lot of work in the background!
Since I will be finishing the bottom/front of the fenders when everything will be mounted/aligned, I thought I should start on the front mask. I know, it is available as a repro but where is the fun, right?
So, first removing the rest of the air-boxes to have a good access:
They will require a lot of work (or I will build new ones!):
But focus is the mask first. Lots of small repairs:
Before:
During:
After:
Before:
During:
After:
Before:
After:
Before:
During:
After:
Before:
During:
After:
Before:
During:
After:
Before:
After:
What is left is the bottom part:
But first I focused on getting it back in shape as it was completely out of form:
Lots of checking:
And trial mountings:
It is starting to look good, at least good enough to position it and use it to mount the fender. But before that, some steps are still necessary, stay tuned!
Braukuche Samba Member
Posted: Thu Jul 13, 2023 6:45 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Looking good. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
TRS63 Samba Member
TRS63 Samba Member
Posted: Tue Jul 18, 2023 4:40 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Always super interesting to see your posts and amazing photographs. I like that you are showing all The details of how the Karmann Ghia body was engineered. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
TRS63 Samba Member
