stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Sun Jun 04, 2017 11:18 pm Post subject: Type 3 vs. Type 1 shifter |
Hello,
I purchased a chrome stock Type 3 shifter for a few bucks for my Manx buggy ('63 type 1 pan). When I installed it, It didn't seem to be engaging in any gears, so I took it out I compared it to both early and late Type 1 shifters I have around. I noticed that the Type 3 shifter appears to be shorter between the "cup" of the shifter (where it contacts the bolt-down base) and the ball of the shifter, where it fits into the shift rod:
My question: Is the shifter base of a type 3 shifter shorter, or otherwise much different than a Type 1 shifter base? The base that came with the Type 3 shifter I bought looks just like the Type 1 shifter plates I have, but I noticed that other Type 3 shifters have a different, much larger boot, along with a different base:
Thanks for any info you can give. _________________ 1963 Manx copy
1968 Bus |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5371 Location: Lefty, CA
Posted: Mon Jun 05, 2017 1:28 pm Post subject: Re: Type 3 vs. Type 1 shifter |
Multi69s wrote: |
Do you have the slot cut into the shift rod cup to accommodate the locating pin the Type 3 shifter? If not the ball of the shifter will not engage into the shift rod cup. When I installed a Type 3 shifter in my 69 Baja, I had to cut this slot into the shift rod cup.
Thanks - yes, the shift rod cup does have the slot. _________________ 1963 Manx copy
1968 Bus |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Tue Jun 06, 2017 8:46 am Post subject: Re: Type 3 vs. Type 1 shifter |
Hi. Yes, the shifter base is matched to the type 3 shifter.
There was a change at approx. '71 or '72 where the shifter seemed to have a slightly shorter "throw" from gear to gear. I'm not sure if VW changed the later base to possibly be a closer, or identical, match to the type 1 components.
Bill. |
Posted: Tue Jun 06, 2017 5:09 pm Post subject: Re: Type 3 vs. Type 1 shifter |
rockerarm wrote: |
Bill. |
Bill, thanks so much. Now to find a base to match the shifter. _________________ 1963 Manx copy
1968 Bus |
santosmotorsports Samba Member
Posted: Tue Feb 13, 2024 6:50 am Post subject: Re: Type 3 vs. Type 1 shifter |
Steve
did you resolve the issues ,mine is a Fastback 69 and i removed a bushing from the top of the lever
and order the couple holder and is the same now in 4th gear got loose from the rod , cut a plastic bottle neck to help push in the lever.
i think the lever use a super beetle bushing.
i want to buy a short sifter but if i don't resolve this ill never happened _________________ VW FASTBACK 1969
[email protected] |
catbox Samba Member
Joined: May 16, 2007 Posts: 866 Location: Portland, Oregon
Posted: Fri Mar 22, 2024 11:28 am Post subject: Re: Type 3 vs. Type 1 shifter |
Interesting, I never would have thought there would have been a difference.
I guess I will find out on my '70 when I fit one of the Hurst shifters to my Square. _________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13284 Location: Tejas!
Posted: Fri Mar 22, 2024 2:42 pm Post subject: Re: Type 3 vs. Type 1 shifter |
catbox wrote: |
I guess I will find out on my '70 when I fit one of the Hurst shifters to my Square. |
I've put many hurst's into many type 3's, it's my favorite somewhat budget shifter - I guess now not so much. Anyways, no issues, no mods needed. Enjoy _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
catbox Samba Member
Posted: Mon Apr 15, 2024 4:53 pm Post subject: Re: Type 3 vs. Type 1 shifter |
Erik G wrote: |
catbox wrote: |
I've put many hurst's into many type 3's, it's my favorite somewhat budget shifter - I guess now not so much. Anyways, no issues, no mods needed. Enjoy |
Awesome sauce.
Thank you for that bit of information!
I have two Hurst shifters, a straight and a bent one.
I will just have to see which I like more in the car. _________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
