mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Sun Feb 23, 2014 5:05 pm Post subject: |
145/65 fronts
Rears were probably 195/60 |
Freezzr Samba Member
Joined: August 12, 2005 Posts: 300 Location: The Netherlands
Posted: Wed Jul 09, 2014 1:16 am Post subject: |
Hello guys,
I'm in a hurry getting my bug fixed for some upcoming meetings so I'm trying to avoid the trail & error as much as possible...
I'll be mounting a set of early Fuchs (5,5J front, deepsix back) onto my 1960 bug the upcoming days but have a few questions, I hope you can help me out?
- I have converted to discs in the front, what is the advised length of the studbolts to use? Will these work?
- What is the best length to use for bolts? will 33mm work out? |
jason Samba Member
Posted: Fri Jul 11, 2014 9:24 pm Post subject: |
Those are what I use. Depends on the length of your studs. If I remember right they are supposed to go on at least 8 threads. |
nize Samba Member
Joined: June 21, 2004 Posts: 531 Location: Sweden - Cheesy town
Posted: Wed Jan 21, 2015 12:47 am Post subject: |
Bruce wrote: |
Check out the prototype Fuchs wheels:
Who's gonna be the first to take a die grinder to a set of 4½s? |
Two rims looking very much like this showed up in a Swedish add this week. No markings on the rim. I got a pic of them but this site does not like .png-files. _________________ ----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
slammed shady Samba Member
Joined: January 19, 2006 Posts: 257 Location: Wolfsburg, Germany
Posted: Sat Apr 11, 2015 1:05 pm Post subject: |
slammed shady wrote: |
Does anyone have pics of cars on Fuchs detailed like this one?
I thought about detailing my ones like that, cause I've never seen this style on a car anywhere. But I can't believe there're no cars like this out there....
Thx,
Jan |
Fake Fuchs, but no Photoshop this time |
Still fake Fuchs, but now on the Bus!
_________________ https://slammedsixty.blogspot.com
https://www.instagram.com/slammedsixty |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Sat Apr 11, 2015 7:47 pm Post subject: |
Very nice ^^^^^^^^ |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17296 Location: Left coast, Canada
Posted: Wed Nov 11, 2015 9:58 pm Post subject: |
Freezzr wrote: |
I'll be mounting a set of early Fuchs (5,5J front, deepsix back) onto my 1960 bug..... .
- I have converted to discs in the front, ..... What is the best length to use for bolts? will 33mm work out? |
Old post, but not answered.
For future reference, Porsches that came from the factory with Fuchs had wheel studs that extended 30mm from the face of the rotor. To determine what studs you need, measure your rotor's (drum's) thickness and add 30mm.
Many aftermarket studs in the VW world come with a stupid unthreaded part that you will have to cut off to use stock aluminum Porsche lug nuts. The length of that unthreaded bit adds to the complexity of finding out what studs you need.
If that wasn't enough, many parts sellers don't know how to measure the length of a press-in stud. The length should not include the height of the head. And to completely confuse you, they give you the length of metric studs in INCHES!
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6690 _________________
ento Samba Member
Joined: December 31, 2008 Posts: 181 Location: el paso tx
Posted: Mon Jan 09, 2017 12:37 am Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
Quick question. Just to verify the late 911 rims didn't come in a 5 1/2 did they? I have a set of flat 6's and would like to run a set of 5.5 non hearts in front to match them if possible. _________________ 66 European bug, 66 euro sunroof
76 baja
76 sun bug sunroof
64,66,67,68 bug
69,70 bay
61 Ragtop bug, 61 sedan(looking for the vert)
61 RHD Ragtop Semaphore bug fakeAF
64,64 KG
74 thing
55 oval
70 ratrod
73 fastback pignose |
Bruce Samba Member
Posted: Fri Jan 13, 2017 7:26 pm Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
You are correct, late Fuchs start at 6" wide.
You could take a pair of late 6s and have them cut down to 5 or 5½" by a competent wheel shop. This would be cheaper than sourcing original 5½s, and they would match your rears.
I have a friend who did the opposite for his fake Speedster. He had a set of 4 flat 6s and he had two of them widened with a 1" spacer on the inside to make them 7" wide, 911R offset. His Speedster is IRS and the 911R wheel is a perfect fit. _________________
Posted: Fri Jan 13, 2017 7:38 pm Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
I can narrow your late 6's if you want. |
ento Samba Member
Posted: Mon Jan 16, 2017 10:57 pm Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
mr. warehouse wrote: |
Thanks. I am looking for another full set so I can narrow two to 5.5 and and maybe two to 4.5 _________________ 66 European bug, 66 euro sunroof
76 baja
76 sun bug sunroof
64,66,67,68 bug
69,70 bay
64,64 KG
74 thing
55 oval
70 ratrod
Posted: Mon Jan 16, 2017 11:45 pm Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
ento wrote: |
Thanks. I am looking for another full set so I can narrow two to 5.5 and and maybe two to 4.5 |
No problem. 6" to 4.5" is do-able as well. |
BABYGAVIN Samba Member
Joined: December 05, 2018 Posts: 2 Location: Philippines
Posted: Wed Dec 05, 2018 9:57 pm Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
Anyone who can help me with the size of this wheels? 15 or 17?
oprn Samba Member
Joined: November 13, 2016 Posts: 12762 Location: Western Canada
Posted: Wed Aug 31, 2022 6:58 am Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
I hope you don't mine me hijacking this thread with some additional Fuchs questions.
I have 2 sets of Fuchs wheels that came on my 944s. The ones on my '86 have two small holes in all 4 center caps like this. What are they for?
The center caps on the '83 don't have them.
Also, how rare are the 4.5" and 5.5" X 15" Fuchs? I want to use the wheels from the parts '86 944 on my street Buggy but they are 7" and 8". I want the bigs and littles look so would prefer a narrow one on the front.
Thanks for your time! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Wed Aug 31, 2022 7:15 am Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
I would ASSume for a puller. _________________ Glenn
Member #1009
#BlueSquare |
oprn Samba Member
Posted: Wed Aug 31, 2022 8:41 am Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
Not too likely, I can pop them off with a pocket knife. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
OgCalLook Samba Member
oprn Samba Member
Posted: Wed Aug 31, 2022 1:16 pm Post subject: Re: 4.5, 5.5, 6.0, 7.0R 15" Fuchs |
Oh! That kind of a puller! I was picturing something like a bearing puller, I stand corrected. Sorry Glen!
Ya! You wouldn't want to break a nail on those caps now would you? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Bruce Samba Member
Posted: Wed Sep 28, 2022 3:48 am Post subject: |
nize wrote: |
Bruce wrote: |
Two rims looking very much like this showed up in a Swedish add this week. No markings on the rim. I got a pic of them but this site does not like .png-files. |
Seven years too late, I know.....
There are online converters that will convert a .png to .jpg for free. Or, send me a message for my email. Then you can send me the .png and I'll get it posted for you. _________________
