ltjohnb Samba Member
Joined: April 09, 2020 Posts: 46 Location: Virginia Beach, VA
Posted: Sat Mar 09, 2024 7:00 pm Post subject: Re: Official Fuel injection questions thread |
busdaddy wrote: |
Sounds like you've got it covered, the only other thing to look at is throttle cable tension, is there any slack when it's closed? Also add a couple drops of oil to the felt pad down in the end of the distributor shaft (remove rotor), the mechanical advance may be hanging up. |
Will do. Thanks.
I will be sure to follow up when I finish. _________________ 74 Super Beetle Sedan "Vader"
79 Super Beetle Convertible "Mello"
19 Jetta "Blanco Muerte"
22 Taos "Betty White" |
Posted: Sun Mar 10, 2024 2:57 pm Post subject: Re: Official Fuel injection questions thread |
Wanted to follow up.
She's closer to purring like a kitten.
It would figure the day I planned to do a smoke test it was really windy. In an effort to keep moving forward, I did the following:
"Cold checks"
- Verified valves still at 0.006
- Verified good seal on both valve covers
- Visual inspection of engine for any loose, disconnected, or damaged hoses
- Verified 30 ohms resistance on the AAR
- Verified AAR was open (55 deg F outside today)
- Verified greater than 2700 ohms resistance on TS2
- Put a drop of oil on the felt pad of the distributor
Started the engine and verified Dwell was at 50 deg and idle was still high (~1200 rpm)
Let the engine warm up and did the following
"Warm Checks"
- Checked timing at idle (~10 deg, but not surprised since idle was high)
- Brought the engine up to 3000 rpm and checked timing (was WAY too advanced at >40 deg)
- Adjusted timing to 30 deg at 3000 rpm (with both vacuum hoses disconnected from my distributor and plugged)
The second I did that and brough the engine back to idle it was more or less purring at 900 rpm.
I still plan on doing a smoke test because I am sure there are still some leaks I can fix, but this feels like a big step in the right direction.
Thanks to Busdaddy for the help. _________________ 74 Super Beetle Sedan "Vader"
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51182 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Mar 10, 2024 3:16 pm Post subject: Re: Official Fuel injection questions thread |
ltjohnb wrote: |
.........but this feels like a big step in the right direction..... |
It sure sounds like one!, good job!
But why was the timing off?, is the plastic tab that rubs on the distributor cam wearing fast? (shrinking gap advances spark), a little dab of grease is part of the tune up routine. Or did aliens abduct your car when you weren't aware and messed with your distributor? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Mar 10, 2024 3:26 pm Post subject: Re: Official Fuel injection questions thread |
busdaddy wrote: |
ltjohnb wrote: |
But why was the timing off?, is the plastic tab that rubs on the distributor cam wearing fast? (shrinking gap advances spark), a little dab of grease is part of the tune up routine. Or did aliens abduct your car when you weren't aware and messed with your distributor? |
As much as I would like to blame aliens or shrinkage, I am willing to bet it was owner error.
When I couldn't get her to start at all I was messing with everything. I have a feeling I either set it wrong initially or knocked it when I was messing with something else.
I have made sure everything is firmly tightened in place this time. I will be sure to add a dab of grease the next time I'm out there and check it periodically to make sure it stays set.
My daughter helped me today and really had fun so I think I've found a helper for the future. _________________ 74 Super Beetle Sedan "Vader"
Posted: Sun Mar 10, 2024 3:41 pm Post subject: Re: Official Fuel injection questions thread |
ltjohnb wrote: |
busdaddy wrote: |
ltjohnb wrote: |
My daughter helped me today and really had fun so I think I've found a helper for the future. |
Well that might just be the best result from the whole day, keep it up! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cphipps79 Samba Member
Joined: May 11, 2009 Posts: 140 Location: Bristol, TN
Posted: Fri Mar 15, 2024 6:22 pm Post subject: Re: Official Fuel injection questions thread |
Good evening fellers! I have a quick question about thermostat/flaps. I know the thermostat for a fuel injected car has a different opening temperature. My question are the flaps different for a fuel injected car vs a carb car? Please forgive me if I’m asking a dumb question! I appreciate everyone’s help! |
Posted: Fri Mar 15, 2024 9:10 pm Post subject: Re: Official Fuel injection questions thread |
The flaps are the same, as is the link bar, rod down through the head and bracket, it's just the thermostat itself that opens at a slightly higher temp. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Gman73 Samba Member
Joined: April 25, 2018 Posts: 79 Location: Spotsylvania, VA
Posted: Sat Mar 16, 2024 6:26 pm Post subject: Re: Official Fuel injection questions thread |
so after dealing with a cold start issue, I adjusted my AAR to the max opening. It started and ran excellently until the AAR heater warmed up. So i Unplugged it and started it back up after it cooled a little and while it was running I sprayedsome brake clean to check for vacuum leaks and found that my plenum was leaking in the seam. so now tomorrow i will be fixing that. i can make a paper gasket for it, but should i use permatex #2 on it also? What do you guys recommend?
Thanks
Gary
My wife is bugging me to drive "her baby" |
Posted: Sat Mar 16, 2024 8:38 pm Post subject: Re: Official Fuel injection questions thread |
I'd glue one side at least, that one's awful skinny and has some long stretches between bolts, easy to suck in. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bjp98 Samba Member
Posted: Mon Mar 25, 2024 2:17 pm Post subject: Re: Official Fuel injection questions thread |
I currently own a 1977 Beetle with 37,100 original miles. The car runs great, except for one issue. The car will sometimes have issues starting. This only occurs when its warm out, however if I slightly press on the gas, the car starts right up. If its cold outside, the car will start just fine without pressing on the gas. An example is if I start it in the morning to drive to work, it starts without issue. However, if I come out for lunch or to head home and its warmer out, it will have issues starting until the gas is pressed or I let it crank for eternity. Could this be just a fuel pump or thermo time switch? What could cause this issue?
Things previously replaced that are in good working order (not all at once, but as needed):
1. Converted from points to electronic ignition.
2. New spark plugs and spark plug wires.
3. New starter.
4. New auxiliary air valve.
5. Not replaced but have checked all lines for leaks or cracks and did not find any issues.
All of that being said, I am a little stumped. |
Posted: Mon Mar 25, 2024 2:40 pm Post subject: Re: Official Fuel injection questions thread |
Welcome!, and great job on the detailed first post!
Most of what you describe sounds like the threads where the temperature sensor (TS2) screw into the LH head are dirty and not making full electrical contact. You can start by testing it with an Ohm meter: https://ratwell.com/technical/TempSensorII.html
If it does indeed read high then be careful getting it out, it may be stuck and break off.
If cleaning up the threads and retorquin it doesn't improve things then it's time to replace, sadly the Uro brand ones offerd by most sellers suck, but there's ways around the problem: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bjp98 Samba Member
Posted: Tue Mar 26, 2024 6:33 am Post subject: Re: Official Fuel injection questions thread |
That seems to have fixed the issue! My car did have the extender attached, which I thought was weird, since the issue was starting up and never anything related to warming up. So when I reinstalled the sensor, I did not include the extender, which did not seem to cause any issues.
Last night after reinstalling the cleaned sensor, I tried starting it and it was still a little rough, however I took it on a test drive and everything was fine. So I returned home, waited about 4 hours, started it again and it started without issue! To be safe, I waited until this morning to determine if the issue is gone, since I knew it was going to be warmer than normal out and would be a good testing opportunity. I started it this (warm) morning without issue, which is beyond relieving!
Thanks for the easy and fast help! As a result, I'm able to continue daily driving my Beetle! |
Posted: Tue Mar 26, 2024 7:52 am Post subject: Re: Official Fuel injection questions thread |
Nice!, fixes that don't require new parts are the best!
Thanks for following up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
tommu Samba Member
Posted: Thu Mar 28, 2024 3:34 pm Post subject: Re: Official Fuel injection questions thread |
bjp98 wrote: |
That seems to have fixed the issue! My car did have the extender attached, |
I have a theory that all FI bugs had an extender installed. I've not seen a stock one without? _________________ |
bjp98 Samba Member
Posted: Sun Mar 31, 2024 7:05 am Post subject: Re: Official Fuel injection questions thread |
That very well could be true. I have never had a stock FI beetle until now, so all of this is new to me and a little confusing, if I am honest.
That being said, I went to leave work Friday and it seems the issue is back. I replaced the sensor with a NOS one (with cleaned extender) I got from my local VW parts store, which did not improve the issue any. Any other ideas on where to look? My first thought would be a fuel pump but I am not sure if that would make sense since my issue is not all the time, but when its warm out.
Also, I did replace the thermo time switch with a NOS one that came with the car to see if that would do anything, which it did not. I also took out the cold start valve and watched it shoot into a cup during the starting process. So I am not thinking they're the issue either, which leads to more confusion on my end. |
Posted: Sun Mar 31, 2024 7:45 am Post subject: Re: Official Fuel injection questions thread |
bjp98 wrote: |
...... it seems the issue is back. ....... |
OK, now we have to find out if the reason for the hard start is too much gas?, or not enough?
If you can find a small squirt/squeeze bottle bring along some gasoline, next time you anticipate a tough time give it a spoonfull's worth of gas into the S boot, does that make it even harder to start?, or does it fire right up?
On a side note, have you ever adjusted the valves? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 449 Location: Rhode Island
Posted: Sun Mar 31, 2024 2:24 pm Post subject: Re: Official Fuel injection questions thread |
bjp98 wrote: |
That being said, I went to leave work Friday and it seems the issue is back…. Also, I did replace the thermo time switch with a NOS one that came with the car to see if that would do anything, which it did not. |
Next time you have the hot start problem, unplug the connector to the Thermo Time Switch. This will ensure the Cold Start Valve (5th injector) does not deliver fuel. You’ll probably have to wait a few minutes and crank the engine a lot after disconnecting- assuming the engine was flooded.
Thermo Time Switch's are not reliable imo. They can fail with the switch shorted to ground - making the 5th injector deliver fuel when it should not. (Even though you replaced the Thermo Time Switch, this is a quick test and it’s worth a try) _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
bjp98 Samba Member
Posted: Sun Mar 31, 2024 3:02 pm Post subject: Re: Official Fuel injection questions thread |
Thanks everyone for the help! I took busdaddy's suggestion and sprayed a little bit of gasoline into the s boot and the car started. So it seems the issue is the car not getting enough fuel. When the car started, it was very rough and seemed to want to die, until I hopped in and pressed on the pedal a little.
Regarding adjusting the valves, I normally check/adjust my valves every 3,000 miles when I change my oil. I am about 1,000 miles away from being due for an oil change/ valve adjustment. However, I do not mind changing my oil and checking the valves early, if you think that would be a good idea.
Side note, when I did check my cold start valve, it was late at night in my garage, so would be around the same cooler temp as it is in the mornings here, when I do not have issues starting the car. |
Posted: Sun Mar 31, 2024 3:20 pm Post subject: Re: Official Fuel injection questions thread |
Excellent!, now we have a starting point.
So is this lean condition due to the TS2?, or fuel pressure?, since you've already fiddled with the TS2 a fuel pressure test is the next logical step.
Any 0-50 psi water pressure gauge will do, Home depot?, Harbor freight?, you'll also need a fitting to adapt it to a 5/16" hose barb. Install it in place of the CSV and see if the pressure drops off when parked, and if it remains low when trying to start it warm (it should jump up to 28-30 as soon as you turn the key to start).
Good to hear you are on top of the valves, some owners don't realise it's part of regular maintenance.
BTW the CSV should only operate below ~50 degrees, and only for a little short squirt when the starter is running, many have removed it entirely and it still starts fine unless it's the coldest winter day. It should be completely out of the picture on a warm engine. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
plextor Samba Member
Posted: Mon Apr 08, 2024 5:34 pm Post subject: Re: Official Fuel injection questions thread |
My '75 is a California model with the cat. I've replaced the muffler in the past 2 years, but I noticed that the muffer to cat connection is leaking again. Even after putting in a fresh donut and exhaust copper gasket maker it is leaking. The cat's pipe opening isn't great, so it may just be not able to make a good seal (and/or I'm doing it poorly).
Given this old cat isn't doing anything useful given its age, I can either replace it or just switch to a non-California exhaust muffler (no smog in Texas for this age of vehicle). It looks like it is an easy bolt on and drops some extra parts. Any downsides to doing that that I'm missing? (there should be no heater box etc modifications from what I can tell).
And I see some high quality JP Dansk mufflers that are spendy, but wonder if they're a better quality than the ones half the price...
Photos of the current stuff... (yes the clamps were just removed and that's the old donut etc).
_________________ 1975 VW La Grande Bug (Super Beetle, 1600 EFI, owned since May 2021) |
