cdolsen1 Samba Member
Joined: June 28, 2016 Posts: 66 Location: Crystal Lake, Il
Posted: Tue Jul 26, 2016 5:07 pm Post subject: Fuel injectors? |
1977 Bus .
Been in storage for 12 years.
I have it running.
I have replaced all fuel lines and pump.
When driving i get a back fire when putting torque on the engine.
I have fuel system cleaner and sea foam in fuel.
It is getting better but I am wondering if the injectors are so gone that they are not spaying correctly.
Any ideas?
Thanks |
Randy in Maine Samba Member
curtp07 Samba Member
Posted: Wed Jul 27, 2016 3:21 am Post subject: Re: Fuel injectors? |
As Randy said, I used both. Good results!
Wouldnt hurt to find an extra one or two to always have on hand. _________________ Subaru |
Bleyseng Samba Member
Posted: Wed Jul 27, 2016 6:35 am Post subject: Re: Fuel injectors? |
I'd check the dizzy (distributor) advance to see if its advancing and not sticking. Sitting for 12 years the dizzy grease on the advance weights will get solid so it won't advance and you get no power and missing. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Fri Jul 29, 2016 5:57 pm Post subject: Re: Fuel injectors? |
I found the vacuum part on the distributor only has one screw holding it on. Possible movement there. Finding a new screw could be fun. Also found minor rust in the distributor, Will clean and see how it works.
Thanks |
Posted: Fri Jul 29, 2016 5:59 pm Post subject: Re: Fuel injectors? |
Would I be better off sending the injectors out for cleaning or should I just replace them? |
Xevin Samba Member
Posted: Fri Jul 29, 2016 7:03 pm Post subject: Re: Fuel injectors? |
Depends on what they look like I suppose. But most of the time better to send out. Don't wait to long to put them back in when you get them back. Sometimes they go back to sleep and need to be waken back up (not cleaned again). I'm sure there are fuel injector service shops in Chicago area if you didn't want to send them out. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Aug 05, 2016 2:36 pm Post subject: Re: Fuel injectors? |
I found the vacuum advance on the distributor is missing a screw. Where would I be able to find one? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51163 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Aug 05, 2016 3:19 pm Post subject: Re: Fuel injectors? |
There's a lot of screws on one of those, which one?
Your best bet is likely Ace hardware, even Home depot has small metric machine screws. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
SGKent Samba Member
Posted: Mon Aug 08, 2016 8:24 pm Post subject: Re: Fuel injectors? |
send them off to witchunter or cruizin performance. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Zelten Samba Member
Posted: Mon Aug 08, 2016 8:37 pm Post subject: Re: Fuel injectors? |
SGKent wrote: |
send them off to witchunter or cruizin performance. |
I sent them to witchunter already. It was 6 years ago but I may send them again.
Has anyone every had their injectors go bad? _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
SGKent Samba Member
Posted: Fri Aug 12, 2016 5:35 pm Post subject: Re: Fuel injectors? |
btw - I read a couple times. How old is the fuel? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 186 Location: Englewood, New Jersey
Posted: Sat Aug 13, 2016 11:54 am Post subject: Re: Fuel injectors? |
My injectors were mismatched, one white and 3 blue, did't want to fix something 40 yo. Replaced with these new not rebuilt for under $40 @.
Runs good now.
http://www.rockauto.com/en/moreinfo.php?pk=47508&cc=1285938&jsn=357
good luck. _________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
Posted: Sat Aug 13, 2016 7:39 pm Post subject: Re: Fuel injectors? |
fuel is new |
Posted: Wed Aug 17, 2016 5:22 pm Post subject: Re: Fuel injectors? |
OK I just replaced the fuel injectors. Now the bus wont run unless I feather the pedal. What would cause this problem? |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Wed Aug 17, 2016 5:27 pm Post subject: Re: Fuel injectors? |
You have a vacuum leak _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
SGKent Samba Member
Posted: Wed Aug 17, 2016 5:41 pm Post subject: Re: Fuel injectors? |
X2
or the injectors have a way different flow rate than what you took out. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
