NewTechnicIan Samba Member
Joined: May 28, 2013 Posts: 367 Location: Burlington, VT
Posted: Mon Jul 25, 2016 7:25 am Post subject: Two Switches on my Transmission? |
Hi all,
Having some trouble finding an answer on this, I have two switches on my transmission and I'm wondering what one of them is.
I'm putting together a '73 standard transmission and if you look at the picture I found in the gallery, you can see the tranny on the right side has 2 switches. The one facing the front of the car is the backup light switch, I know that. The other switch facing toward the driver's side (right in the picture) is what I'm not sure on. It's only got one tab like an oil pressure switch. What's that for?
_________________ My 73 Standard build - It's painted! It drives under its own power! Time to get it wired and upholstered!
My 1679 Engine build. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jul 25, 2016 8:22 am Post subject: Re: Two Switches on my Transmission? |
seat belt warning light _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Jul 25, 2016 8:24 am Post subject: Re: Two Switches on my Transmission? |
Some late models had emissions which turned on and off depending on gear selection and engine temp-- Maybe some thing like that- in what gear does it activate?
edit- mystery solved- but would explain why it's not connected to any thing.- hate those buzzers- once had a yamaha the 5 things had to happen befor the starter would run. eeeeeer. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
robrings Samba Member
Posted: Mon Jul 25, 2016 8:58 am Post subject: Re: Two Switches on my Transmission? |
I'm new to this but with my 72 Super the seatbelt warning light only comes on if car is in gear, so i assume seatbelt warning. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22672 Location: NYC/Upstate/ROW
Posted: Mon Jul 25, 2016 11:58 am Post subject: Re: Two Switches on my Transmission? |
NewTechnicIan wrote: |
Aaah, gotcha.
One less thing to hook up then! |
No, you should still hook up your seat belt.
_________________ .ssS! |
