ManFromNapa Samba Member
Joined: March 08, 2012 Posts: 184 Location: United States
Posted: Sun Jul 24, 2016 1:37 pm Post subject: Scat Crankshaft / Flywheel Fit |
I have a Scat 8-pin crankshaft and a DRP flywheel I bought from Aircooled.net http://vwparts.aircooled.net/DPR-Chrome-Vanadium-2...ywheel.htm
The flywheel is a standard SPG pattern. I know it should be tight, but using the glad nut I can only get the flywheel about 50% way on. There is gap. Also, just to get it that far took a LOT of work. More than I would expect.
I've read a few threads about crank / flywheel combos. Should I just get a scat flywheel? _________________ North Bay Air Cooled - VW Club in Napa, CA
http://www.northbayaircooled.com/
Check out my band, Thru The Haze
http://www.thruthehazeband.com/ |
Danwvw Samba Member
Posted: Sun Jul 24, 2016 3:11 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
Sounds like something is wrong? Could be the crank or the flywheel. Try a different combination if you have another crank or something. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
modok Samba Member
Posted: Sun Jul 24, 2016 3:53 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
Scat cranks come with the dowel pins out, so you can check the alignment much easier with the pins out. Those should both be good quality parts you have there, but...... does any given crank bolt to any given flywheel?? well probably not.
The chances of drilling 8 holes in perfect alignment is like trying to win the lottery. The more you play the higher your chances of winning, so, yeah sure try a different flywheel or 2. You'd THINK a scat flywheel would fit a scat crank, but who knows, let us know what you find. Someday all 8 pins will line up, either by chance or thanks to improving technology, but I've never seen it happen yet. |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1172 Location: San Angelo, Texas
Posted: Sun Jul 24, 2016 3:58 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
I would see if you can pull four of the non offset dowels out of the crank and see if you can fit the flywheel then. You can then see what dowel is not lining up and make adjustments to the flywheel.
Leave the four loose dowels out till you get the end play set, then drive them through the flywheel back into the crank....makes everything a lot easier....tighten that nut to 350 foot/lb at least. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sun Jul 24, 2016 9:14 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
If it's that tight, don't use the gland nut to draw it on any farther. The nut is meant to hold 300 some (or more) foot pounds but if it's only part way in you could pull the threads. I wouldn't hammer the dowels through either, if it's off, something is going to distort. You might possibly never get the flywheel back off again.
The idea to pull some of the dowels and try different combinations is good; figure out which one or one's is off, and fix that. Modok has a recent post describing how he reams the holes to fit, you'll find some good advice there. _________________ modok wrote:
Posted: Sun Jul 24, 2016 9:31 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
I didn't say hammer the dowels through, I said make adjustments (ream is one way) to the flywheel for clearance and then drive the dowels through the flywheel....I've done it like this before and it works. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Mon Jul 25, 2016 5:32 am Post subject: Re: Scat Crankshaft / Flywheel Fit |
Are your Scat dowels 8mm or 5/16?
I had a problem several years ago and found they weren't 8mm. A ream may be all you need to fit your DPR flywheel to your Scat crank... |
mark tucker Samba Member
Posted: Mon Jul 25, 2016 9:42 am Post subject: Re: Scat Crankshaft / Flywheel Fit |
it may be the dowels or it may be the taper fit. is it dry? or did you lube it? I like some lube in there so it dosent gauld, that go,s for the threads too also the hp nuts have sharp edges on the flats that needs to be removed so it dosent gouge into the washer and farther increase tq it takes to tighten it. also if you have the seal(oring) in there it must be lubed, i like the silocone orings that also have a graphite coating on them. also deburr any sharp edges that may cut oring, and a slight champher to the dowel holes. but in the end yes they should be tighter than the popes.......golf cart going through a key hole. a skeleton key hole so his hat dont get knocked off.. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Jul 25, 2016 10:17 am Post subject: Re: Scat Crankshaft / Flywheel Fit |
Dougy Dee wrote: |
This is most likely the problem. Depending on what flywheel I use, I sometimes have to ream all the holes otherwise it won't fit.... _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Mon Jul 25, 2016 10:59 am Post subject: Re: Scat Crankshaft / Flywheel Fit |
esde wrote: |
Modok has a recent post describing how he reams the holes to fit, you'll find some good advice there. |
Can someone point me to that post? I think that's the right way for me to go. _________________ North Bay Air Cooled - VW Club in Napa, CA
Danwvw Samba Member
Posted: Mon Jul 25, 2016 11:50 am Post subject: Re: Scat Crankshaft / Flywheel Fit |
OK. Got a lot of things I need to check out and try. I'll update everyone in a day or two.
Thanks! _________________ North Bay Air Cooled - VW Club in Napa, CA
Posted: Mon Jul 25, 2016 5:50 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
Got home from work and took some measurements with the micrometer.
All of the dowels measure out to 8.01-8.03mm. Dowel holes on the flywheel measure out to 7.94-7.98mm.
I measured all of the gaps between the dowels to make 100% where the offset dowel was. I then did the same on the flywheel for the same reason.
I didn't have a tool to accurately compare the dowels on the crank to the holes on the flywheel. The pins are in there very tight. Not sure how to get them out. I think I can see where 2 of the dowels are ever so slightly different than the flywheel.
Should I carefully ream the 2 holes on the flywheel or should I try a Scat flywheel? John @ ACN offered to let me exchange flywheels.
Thoughts? _________________ North Bay Air Cooled - VW Club in Napa, CA
esde Samba Member
Posted: Mon Jul 25, 2016 6:23 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
I can't find the thread where Modok outlines his process, will look some more later. I have bought two flywheels from DPR, and both needed work to "fit" correctly on the flywheel pins. While a pain in the ass, it sure is better than having it too loose. The first time I had a shop do the work, and they just drilled the flywheel holes oversize. Then it was too loose, and I had oversize dowels installed. The next time I used some Dykem to help figure out where what hole was off, and bought a reamer to open two holes a hair.
Posted: Mon Jul 25, 2016 6:26 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
esde wrote: |
SD |
That sounds like a reasonable process to follow. Where did you get your reamer? What size? I found this on Amazon:
https://www.amazon.com/uxcell%C2%AE-110mm-Straight...8mm+reamer _________________ North Bay Air Cooled - VW Club in Napa, CA
the2ndcashboy Samba Member
Posted: Mon Jul 25, 2016 6:33 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
I don't think you're going to make decent holes in high strength steel with a 7$ reamer, and that one in particular I think is designed to be turned by hand with a T-handle. I'd lean more towards this reamer: https://www.amazon.com/Yankee-3150-Straight-Chucki...ng++reamer _________________
SRP1 wrote: |
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones. |
modok wrote: |
If anything comes out perfect it just means your measuring tools are substandard. |
esde Samba Member
Posted: Mon Jul 25, 2016 6:42 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
I used a small adjustable reamer. While not ideal, it's what I had, and it let me take a little bit at a time. The steel wasn't really hard to cut, and I was barely taking anything off. It's amazing how little material will keep the flywheel from fitting correctly.
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Jul 25, 2016 6:46 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
i thought everyone knew that SCAT flywheels dont fit right on SCAT cranks.
i guess i assumed that everyone also knew that SCAT is another word for SHIT. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Jul 25, 2016 6:53 pm Post subject: Re: Scat Crankshaft / Flywheel Fit |
esde wrote: |
SD |
This set should do the trick... Unless you have a recommendation.
https://www.amazon.com/Grizzly-H5938-7-Piece-Adjus...ble+reamer _________________ North Bay Air Cooled - VW Club in Napa, CA
