SOLiiD Samba Member
Joined: June 01, 2016 Posts: 141 Location: in the hot
Posted: Sat Jul 23, 2016 10:39 am Post subject: oil filter adapter suggestions |
Im looking for something that adapts to a spin on filter and that is cheap, as in affordable. Not cheap in quality.
I see so many on all the sites that I dont know what to make heads or tails of! Thanks guys. _________________ 72 Super RIP
70 Baja |
Brian Samba Moderator
mark tucker Samba Member
Posted: Sat Jul 23, 2016 11:40 am Post subject: Re: oil filter adapter suggestions |
that is cheap, as in affordable. Not cheap in quality. now thats a funny statement. I dont know what you want.a filter pump? a oil pump that has a in&out? a oil filter addaptor that hoses go to&from and the oil screws on to it? a full flow kit? so the best i can say is stay away from latest rage &cip.1 look on the cb performance site,ac.net site and pick what your pocket can afford and what will work for you. |
SOLiiD Samba Member
Posted: Sat Jul 23, 2016 2:29 pm Post subject: Re: oil filter adapter suggestions |
mark tucker wrote: |
This is what all confuses me. I've had the car less than a week so I'm not familiar at all other than the basic concept of a air cooled engine. I want to make changing the oil and filter to be somewhat easier than hunting down a piece of filter paper. I'll save that for when the world ends and I have plenty of old shirts. _________________ 72 Super RIP
70 Baja |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sat Jul 23, 2016 2:35 pm Post subject: Re: oil filter adapter suggestions |
From the factory the Beetle didn't have an oil filter, just a screen in the sump. A filter can be added and there are a few different ways to do it.
I have no idea what you mean by "filter paper." _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
SOLiiD Samba Member
Posted: Sat Jul 23, 2016 3:52 pm Post subject: Re: oil filter adapter suggestions |
Thats just what Ive heard on the oil change videos, that theres a paper in there with the mesh screen. It makes sense after changing deep fryer oil in kitchens.
Like these http://www.webstaurantstore.com/royal-paper-fe1422...21106.html _________________ 72 Super RIP
70 Baja
Cusser Samba Member
Joined: October 02, 2006 Posts: 31386 Location: Hot Arizona
TX-73 Samba Member
SOLiiD Samba Member
Posted: Sat Jul 23, 2016 5:23 pm Post subject: Re: oil filter adapter suggestions |
So how do I know if I have a 3 bolt or 4 bolt cam, flat or dished? How do I know what filter it uses? _________________ 72 Super RIP
70 Baja |
Posted: Sat Jul 23, 2016 7:20 pm Post subject: Re: oil filter adapter suggestions |
How much do you know about the motor? If not enough, then you take the oil pump off and see what cam you have. You use whichever filter fits. PH16 is the Fram number I have on mine. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Sun Jul 24, 2016 8:41 am Post subject: Re: oil filter adapter suggestions |
might want to get some books, and do some research.both ac.net&cb performance have some good reading. |
SOLiiD Samba Member
Posted: Sun Jul 24, 2016 9:26 am Post subject: Re: oil filter adapter suggestions |
What are some recommended books? I have the Bentley on order. _________________ 72 Super RIP
70 Baja |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24768 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 24, 2016 10:39 am Post subject: Re: oil filter adapter suggestions |
Think you mean INEXPENSIVE. Cheap is like hiring a $20.00 hooker that later you have to spend hundreds to cure the STD.
CB oil filter pump is really good, but does not fit with some of the stock mufflers. That can be dealt with by cutting, angling down slightly and rewelded back together the neck and run a drill back thru.
TRUE VW of Germany never installed a stock oil filter on the upright engine used in type 1 & 2s, but VW of Mexico did and it should clear any stock muffler without modification.
VW of Germany made the type 4 engine from the get go with a stock filter, and in the 72-79 bus those engines easily lasted 200,000 to 300,000 miles easily if not floored and ignored and if maintained properly. Not saying that the oil filter alone made that difference, but that it sure helps.
Personally running a 1641 cc engine with CW crank and oil filter pump in our 1960 walk thru panel camper with now over 140,000 miles on it since last rebuilt. Engine still runs like new...
Bentley is the best repair manual if you can not have any other. The Idiot's Manual by John Muir is a very good companion manual to go with the Bentley. _________________ In Stereo, Where Available!
SOLiiD Samba Member
Posted: Sun Jul 24, 2016 12:30 pm Post subject: Re: oil filter adapter suggestions |
Well now Im on the fence for which one I want to go with, CB or TAC. I plan on build a MPG motor according to ACN topic and it says exhaust needs to change to a header. _________________ 72 Super RIP
70 Baja |
TX-73 Samba Member
Posted: Sun Jul 24, 2016 3:55 pm Post subject: Re: oil filter adapter suggestions |
I used stock muffler with preheat on right side. Fits fine, came from aircooled.net
113-251-053AJ _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
SOLiiD Samba Member
Posted: Mon Aug 01, 2016 5:44 pm Post subject: Re: oil filter adapter suggestions |
What is the pre-heat, a prius on fire? Reading the ACN mpg motor build sheet again, It seems to be some sort of emissions deal? Im not staying in my no-emissions state for much longer so thats something Id have to consider. South Texas will more than likely be the next home, and they test.
Here, have your beetle pee in this cup. We have the pecker checker on stand by _________________ 72 Super RIP
70 Baja |
Zundfolge1432 Samba Member
Posted: Mon Aug 01, 2016 6:15 pm Post subject: Re: oil filter adapter suggestions |
Eric&Barb wrote: |
Here is on an engine
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Aug 01, 2016 7:12 pm Post subject: Re: oil filter adapter suggestions |
SOLiiD wrote: |
What is the pre-heat, a prius on fire? Reading the ACN mpg motor build sheet again, It seems to be some sort of emissions deal? Im not staying in my no-emissions state for much longer so thats something Id have to consider. South Texas will more than likely be the next home, and they test. |
Pre-heat is is manifold heating for center mount carb. |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Mon Aug 01, 2016 7:36 pm Post subject: Re: oil filter adapter suggestions |
Here's another look at the oil filter unit posted by Eric&Barb, this photo shows some different angles:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
