Zundfolge1432 Samba Member
Posted: Tue Aug 02, 2016 4:16 am Post subject: Re: oil filter adapter suggestions |
hopkin wrote: |
Here's another look at the oil filter unit posted by Eric&Barb, this photo shows some different angles:
Did anyone mention that this VW filter pump is 30 mm and must be used with a dished cam? |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2481 Location: Ottawa, Ontario
Posted: Tue Aug 02, 2016 5:23 am Post subject: Re: oil filter adapter suggestions |
Thanks Zundfolge, I don't know compatibility, that's why I posted the different angle picture. I should have said that it my post . _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
windfish Samba Member
Posted: Tue Aug 02, 2016 6:47 am Post subject: Re: oil filter adapter suggestions |
I posted a topic a little while back on my CB Maxi 2 install - http://www.thesamba.com/vw/forum/viewtopic.php?t=629729
May be helpful.
The heat risers off the muffler eliminates carb icing with center-mount carbs; might get away with running without them in hot climates, but the engine will run better with. |
nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Tue Aug 02, 2016 6:51 am Post subject: Re: oil filter adapter suggestions |
For what its worth, I installed the EMPI filter pump to my 68 1600DP. Fit and finish is good, granted I had to grind the top of the cover to clear the breast plate. Not a big deal. Filter clears the shorty headers. My oil pressure light goes off during cranking so I imagine oil pressure is good.
-Nick- |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Aug 02, 2016 7:57 am Post subject: Re: oil filter adapter suggestions |
Did anyone mention that this VW filter pump is 30 mm and must be used with a dished cam?[/quote]
I have one that has been modified to work with a Flat cam. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
