Rickles Samba Member
Joined: January 22, 2016 Posts: 213 Location: South Jersey
Posted: Sat Jul 23, 2016 10:10 am Post subject: Oil Drain Plug Crush Washer Size |
Which is the proper I.D. for T1 oil drain plug copper crush washers, 14mm or 14.2mm? Or something else? Good source? I'd like to get a few to have on hand; although, I will drop the screen each time anyway. _________________ Rick
1967 VW Beetle - Savannah Beige
2002 VW GTi - Reflex Silver (Sold)
1966 VW Beetle - Bahama Blue (Sold)
1961 Porsche 356B Roadster - Signal Red (Sold)
1966 VW Beetle - Sea Sand (Sold)
South Jersey Volkswagen Club
Central Jersey Volkswagen Society |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jul 23, 2016 12:44 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
Just buy ten or more of these kits.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113198031
Personally have found it not necessary to replace the plug sealing washer over many oil changes.
If you have 40 HP or later engine you can get one of the CB or VW of Mexico filter oil pumps and skip the need to pull the sump plate off. Plus the engine bearings are much better protected against debris in the oil. _________________ In Stereo, Where Available! |
Posted: Sat Jul 23, 2016 2:18 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
Thanks, E&B, but I have the silicone strainer gaskets that are supposed to be reusable. What is the CB Filter Oil Pump? Never mind I see what that is. _________________ Rick
Posted: Sat Jul 23, 2016 2:33 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
You can take your sump bolt down to the FLAPS or ACE hardware. Both should have the crush washers, or at least copper washer to do the job. _________________ In Stereo, Where Available! |
Posted: Sat Jul 23, 2016 2:40 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
Thanks, never thought of ACE; they're right down the street. _________________ Rick
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Jul 23, 2016 2:48 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
I don't think I've ever seen a "real" crush washer at a hardware store before, and not at a FLAPS either... but I have seen the flat-copper and those hard fibre style gaskets though. _________________ Andy T.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Sat Jul 23, 2016 4:18 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
I'm going to check at ACE tomorrow. Imagine, could be right down the road. _________________ Rick
Posted: Sat Jul 23, 2016 5:18 pm Post subject: Re: Oil Drain Plug Crush Washer Size |
If no luck, do try a real fastener supply shop. Tis amazing if the fellows who man the counter are friendly of what they either have on hand or can order something for you. _________________ In Stereo, Where Available! |
