txoval Samba Member
Joined: January 23, 2004 Posts: 3556 Location: The Woodlands, TX
Posted: Fri Jul 22, 2016 6:13 pm Post subject: Finally Installed Correct Front Seats |
I finally found a set of good 53-55 front seat frames for my 54. I stripped them down, repaired the areas that needed it, and sent them off to powder coat.
The upholstery theme is not stock, but I wanted to stick with something similar. It's amazing how nice these seats sit. The 64 seats I had at first were so flat because the seat rails on the later cars are slanted.
In the end it was worth it, even though the price for these seats now days is crazy.
A couple of pics
sled Samba Member
Posted: Fri Jul 22, 2016 7:48 pm Post subject: Re: Finally Installed Correct Front Seats |
very nice!!
try buying split seats _________________ drive your split. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Mon Jul 25, 2016 6:27 am Post subject: Re: Finally Installed Correct Front Seats |
looking good! _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
54ovsemi Samba Member
Posted: Sun Jul 31, 2016 12:10 pm Post subject: Re: Finally Installed Correct Front Seats |
Congrats txoval .....looks great! Who did upholstery? _________________ 2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval |
txoval Samba Member
Posted: Mon Aug 01, 2016 9:22 am Post subject: Re: Finally Installed Correct Front Seats |
I did everything but the front and rear seats, which were done by Classic Upholstery in Conroe, Texas |
Valmir Azevedo Samba Member
Joined: January 08, 2007 Posts: 15 Location: Santos - Brasil
Posted: Wed May 23, 2018 8:02 pm Post subject: Re: Finally Installed Correct Front Seats |
Would you have the design with the correct position on which the rails are soldered on the bench and on the floor, or do you know where it is? It's for a 54 beetle. Thank you! |
