foamermetal Samba Member
Joined: February 17, 2011 Posts: 274 Location: Warner Robins, Georgia
Posted: Thu Jul 21, 2016 5:53 pm Post subject: Rear gas heater. |
Has anyone mounted a Stewart Warner gas heater in the engine compartment? I have one for a 67 Beetle that mounts up front but have wondered if it would work mounted where the battery is now on the 68 and routed to the factory heater channel |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Fri Jul 22, 2016 4:36 am Post subject: Re: Rear gas heater. |
I recall coming across photos related to your question here from time to time; a search may turn some up. IMHO mounting a gas heater with the exhaust downwind is not a bad idea, and the roominess of the Ghia engine compartment is a real plus. Ducting the air inlet and/or hot air return can be an issue for some folks. My experiences are limited to installing Eberspächer gas heaters in the engine compartment of a '72 bus and in the passenger compartment of a '71 Karmann Ghia cabriolet (first photo in my gallery), so I may be able to answer some of your questions. On the other hand, have you considered following the trail blazed by Bluedot with an electric heater? How many BTUs of heat do you need down there in peach country? |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Fri Jul 22, 2016 8:24 am Post subject: Re: Rear gas heater. |
foamermetal wrote: |
Sounds interesting ducting it to the heater channels. _________________ Ghia Owner Emeritus |
aerosilver Samba Member
Posted: Fri Jul 22, 2016 9:53 am Post subject: Re: Rear gas heater. |
Gas heaters were fitted in the engine bay in period, have some literature on it some where..
Posted: Fri Jul 22, 2016 5:55 pm Post subject: Re: Rear gas heater. |
crocteau I like your Photo and the fact that it's a type IV. I was thinking sometime in the future building an upright cooled 2.0, thus the heater would be in place of the heat exchangers on either type engine. I really just like thinking outside the box in the placement of the heater. I do sheetmetal work for a living so thats not an issue. Courious as to where to pick up fresh air through the intake boot. I'll search some split bus heater pics. |
Posted: Fri Jul 22, 2016 6:09 pm Post subject: Re: Rear gas heater. |
Eberspacher fuel line. Is it run from the tank by itself or a tee? |
Posted: Sat Jul 23, 2016 6:22 am Post subject: Re: Rear gas heater. |
It is a tee off of the fuel line. _________________ Ghia Owner Emeritus |
Posted: Sat Jul 23, 2016 6:06 pm Post subject: Re: Rear gas heater. |
crocteau... Courious as to where to pick up fresh air through the intake boot... Eberspacher fuel line. Is it run from the tank by itself or a tee? |
hi foamermetal, in my bus I ran fuel from a tee; in the Ghia the stock fuel line only supplies the heater, while a separate line supplies fuel for the carbs at low PSI. Since the Espar heater is in the passenger compartment of my Ghia, it pulls cabin air into its intake directly, while the heated air is channeled downward to a "Y" mounted above the transaxle and then through flexible ducts to the heater channels.
Recirculating the air heats it up faster, as does insulating the hot air delivery tubes, but it may not be necessary depending on your typical ambient winter temperatures. After all, the Ghia's heater channels have no insulation and the stock heat is still keeping folks' feet warm somewhere.
Fresh air for combustion and exhaust enter and exit from the bottom of the Espar. I don't know, but it's possible your Stewart Warner heater has similarly configured connections. You may be able to discern the Espar connections in this photo just to the left of the clutch cable: the silver tube is exhaust to the rear apron, the black tube is fresh air for combustion. I hope that gives you some useful ideas.
As an aside, the gentleman who supplied me with this Espar heater has installed the diesel burning version in the cabs/sleepers of hundreds of trucks. If your combustion chamber isn't cracked and you don't have fuel leaks, then you shouldn't have to be concerned about CO asphyxiation or roasting in a fireball.
Posted: Sat Jul 23, 2016 6:48 pm Post subject: Re: Rear gas heater. |
Great info. I'll keep all that in mind. Thanks for the input. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 24, 2016 6:05 pm Post subject: Re: Rear gas heater. |
_________________ In Stereo, Where Available! |
Posted: Mon Jul 25, 2016 8:39 am Post subject: Re: Rear gas heater. |
As I recall there were two types of the Eberspecher heaters made for AC VWs. I think the earlier models required a separate fuel line from the tank. The later models did not. This may have had something to do with the fuel pump used as I think the earlier models are attached to the heater while the later model has a pump at the tee below the tank. The one I have in my Ghia is mounted in the luggage compartment with a tee off of the fuel line coming out of the tank. The fuel pump at the tee supplies fuel.
Air is drawn in from the passenger compartment just above the driver's right knee. Heat comes out a duct above the driver's left knee. You would not be able to attach this set up to the heater channels. I think this was the only configuration available in the later models - probably because of the battery location on those models.
My heater is a BN2. It has the Ghia specific ducting for the air intake and output which can be difficult to find although you can make your own. _________________ Ghia Owner Emeritus |
Starbucket Samba Member
Posted: Mon Jul 25, 2016 2:13 pm Post subject: Re: Rear gas heater. |
Why not run it through the rear window shelf that way you will get a rear window defroster. It's going to cook you out of the car anyway as a Ghia passenger compartment is smaller than a beetle. I have a S/W heater that I couldn't bring myself to mount next to the gas tank as open flame and gas fumes doesn't give me a warm and fuzzy feeling, but I was thinking rear shelf. |
