My Baja bug class 11 style build
Justbuggin175
Justbuggin175 is offline
PostPosted: Thu Apr 16, 2015 6:39 pm    Post subject: My Baja bug class 11 style build Reply with quote
I'm turning my daily driver 73 vw bug in to a class 11 style Baja bug here's the car before I started
Justbuggin175
PostPosted: Thu Apr 16, 2015 6:46 pm    Post subject: Reply with quote
Tweed 3.5 lift spindles
Installed the lift spindles with the stock brakes
Had to pick up a bearing race kit from harbor freight to replace some old worn bearings
Before on the right and after on the left
Justbuggin175
PostPosted: Thu Apr 16, 2015 6:55 pm    Post subject: Reply with quote
Before I pulled the rear apart
Pull the rear suspension apart and turned the torsion
Put it back together with new bolts I think I got like 2" + of lift in the rear
Justbuggin175
PostPosted: Thu Apr 16, 2015 6:59 pm    Post subject: Reply with quote
Post lift still need tire got 3.5" in front and like 2.5" in the back
Justbuggin175
PostPosted: Thu Apr 16, 2015 7:15 pm    Post subject: Reply with quote
I got some free 225/75r15 tire
Had to trip the bump stop about 1/2" to prevent rubbing
71StandardReduction
71StandardReduction is offline
PostPosted: Thu Apr 16, 2015 7:28 pm    Post subject: Reply with quote
Subscribed!
You made a good choice on the lift spindles.
Good work.
One thing I ask from the Lord, This only do I seek:
That I may dwell in the House of The Lord all the days of my Life, to gaze on the beauty of The Lord and to seek Him in His Temple~Psalms 27:4
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
https://www.thesamba.com/vw/forum/viewtopic.php?t=779597&highlight=
https://youtube.com/@SCOFabwerx?feature=shared
Justbuggin175
PostPosted: Thu Apr 16, 2015 7:56 pm    Post subject: Reply with quote
Thanks man I'll post some interior pics and some pics of the roll cage I just installed soon
Brian
Brian is offline
PostPosted: Fri Apr 17, 2015 12:51 am    Post subject: Reply with quote
Interesting. Don't know if you needed to grind that.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
enjoyther1de
enjoyther1de is offline
PostPosted: Fri Apr 17, 2015 8:23 am    Post subject: Reply with quote
I was wondering what is going on there as well. Seems on my car I could use a little more length on the bump stop, as it is now my tires rub the fender wells on a good G-out.
Love the class 11 style though! Probably the coolest form of desert travel there is. But I may be biased. Wink
HBB took me to BBV.
Bashr52
Bashr52 is offline
PostPosted: Fri Apr 17, 2015 8:44 am    Post subject: Reply with quote
Are you going to notch your spring plates to get the additional 1" on the rear to level the car out?
Brian
Brian is offline
PostPosted: Fri Apr 17, 2015 10:14 am    Post subject: Reply with quote
Class 11 style is the best because bugs are damn sexy stock looking.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Bret2094
Bret2094 is offline
PostPosted: Fri Apr 17, 2015 11:27 am    Post subject: Reply with quote
That and if you want to go back stock, you dont have to reweld clips and track down new metal
Bret
1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A)
Justbuggin175
PostPosted: Fri Apr 17, 2015 11:29 am    Post subject: Reply with quote
No I'm going to remove the bottom bump stops and run limit straps
Justbuggin175
PostPosted: Fri Apr 17, 2015 5:09 pm    Post subject: Reply with quote
Here's some pics of the cage being installed a couple weeks ago
The wire mess that I ripped out before the cage install
nobuggybob
nobuggybob is offline
PostPosted: Fri Apr 17, 2015 6:43 pm    Post subject: Reply with quote
enjoyther1de, What spindles are on your car? what size?
You Can't Quit Poverty
enjoyther1de
PostPosted: Fri Apr 17, 2015 10:00 pm    Post subject: Reply with quote
3.5" tweeds same as justbuggin's
HBB took me to BBV.
enjoyther1de
PostPosted: Fri Apr 17, 2015 10:01 pm    Post subject: Reply with quote
HBB took me to BBV.
nobuggybob
PostPosted: Sat Apr 18, 2015 5:30 am    Post subject: Reply with quote
Thanks! Both cars look great! Cool
EnjoyNukaCola
EnjoyNukaCola is offline
PostPosted: Sat Apr 18, 2015 3:24 pm    Post subject: Reply with quote
Wow, nice job on the cage so far. Someone's car used to be yellow Very Happy
"when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help"
gargamel
gargamel is offline
PostPosted: Wed Apr 22, 2015 10:32 am    Post subject: Reply with quote
Very nice work! I'd like to see more, as things go.
As time and money allow, I am also working on a class-11 style bug. I just need new bigger tires but I was taken back by something I was not aware could be an issue. Yes I am new but when you said you "had to trip the bump stop about 1/2" to prevent rubbing" I was taken a bit back. IS this needed only when there is rubbing? By this you mean tire to fender,etc? Sounds like something I need to also consider.
Man, I like that cage.
