frostpinfold Samba Member
Posted: Sun Jul 17, 2016 9:37 am Post subject: Ghia suspension height |
I have rebuilt a 71 convertible but did not do the floor pan as it was done by the previous owner
The front suspension looks low, the cill is lower at the front than the back by 1 3/4 inches. I don't know if that is correct or not
Also the right side is one inch lower than the left at the front
The pan appears to be straight and the front cross beam is straight and central
The right front tyre rubs on the wing when on full lock and more so when their is a passenger in the right hand seat. The car is LHD
Is the front suspension low and can it be lifted. It appears not but I don't know what to do next
Any suggestions would be gratefully received
Rob |
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Sun Jul 17, 2016 10:38 am Post subject: Re: Ghia suspension height |
The beam could have some broken leaves. Look in the middle of the beam for adjusters. If there are none and it's sitting low in the front and leaning I'd imagine broken leaves.
You'll need to pull the beam to replace them. _________________ 63 ghia coupe |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Sun Jul 17, 2016 10:57 am Post subject: Re: Ghia suspension height |
Take a photo of the center of your front beam and of the ball joints. That will tell you if it has been lowered either through the installation of adjusters in the beam, drop spindles, or both. If not, then you will need to check if any torsion leaves have been removed or are broken. See this thread for more information on the methods of lowering and raising ghias:
http://www.thesamba.com/vw/forum/viewtopic.php?t=95935 _________________ 1966 Karmann-Ghia convertible |
c21darrel Samba Member
Posted: Tue Jul 19, 2016 1:35 am Post subject: Re: Ghia suspension height |
I believe the car is standard, that is not lowered as far as I know but Im no expert
So my question was:- Is the floor of the car supposed to be horizontal, that is parallel to the ground
Second question, on a standard car when the front wheels are turned how close is the tire to the wheel arch. (The curved opening in the fender)
On the right hand side the tire is only 1/2 inch from the fender and if the car goes over a bump the tire rubs on the fender
The rear suspension looks OK and is the same height side to side
I am not sure what to do next |
