clarkster75 Samba Member
Joined: September 25, 2006 Posts: 161 Location: Lots of good clean livin' Utah
Posted: Fri Jul 08, 2016 8:53 pm Post subject: Welding ground question |
Besides a clean connection, or best you can do, is there a good spot on the car to connect the ground to, or do you always want to be as close to the weld as possible. And, if you are just doing a part not on the car, is a steel table the way to go?.. Thx in advance. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3448 Location: San Diego
Posted: Fri Jul 08, 2016 9:10 pm Post subject: Re: Welding ground question |
Close to the weld is best. Steel tables are good |
Danpa Samba Member
Joined: August 21, 2007 Posts: 1253 Location: Valparaiso, in
Posted: Sun Jul 10, 2016 5:18 am Post subject: Re: Welding ground question |
If you don't have a steel table, get a couple of alligator clips and a section of wire and use this to make a good ground connection between the two pieces till they are electrically connected by the weld.
Dan |
planenut Samba Member
Posted: Sun Jul 10, 2016 7:38 pm Post subject: Re: Welding ground question |
While I'm doing welding, I have a stud with a shoulder that I screw into a fender nut. Clean the metal, and use a longer bolt and nut, even. Just something to tighten against the metal, and long enough for your ground. |
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Sun Jul 10, 2016 8:01 pm Post subject: Re: Welding ground question |
i always liked the jacking point on a vw give it a lil wizz to make a clean spot , n go to town , ,,,,,,,,,,,,, fabricator john |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed Jul 13, 2016 1:58 pm Post subject: Re: Welding ground question |
I sometimes clamp a pair of Vise-Grips on to the part I am working on and connect the ground clamp to the Vise-Grips. _________________ Jesucristo es mi Seņor y Salvador! |
