2Dokas Samba Member
Joined: October 09, 2004 Posts: 752 Location: Santa Cruz, CA
Posted: Thu Jul 07, 2016 5:29 pm Post subject: end play |
I posted this yesterday but it disappeared,
I took my 36hp engine apart not knowing its history and for the fun of it a few years ago, and I am slowly working on putting it back together
I only replaced the cam, everything else looked good,
My end play is 0.0018 which is 10 below the minimum
seems odd to me that using everything the same would end up with something out of limits (28 minimum)
the shims are not flat, each one has a side that has somewhat of a bend(?) so I tried both sides and the end play is the same, I had guessed that the uneven side was against the flywheel as the bearing surface is as wide as the shim.
but the fact that the shims are not flat made me think the end play was not correct the last time it was rebuilt, when ever that was, but the pistons and connecting rods were marked so I know it had been rebuilt,
Is is safe to assume that the end play is the same as it was prior to taking it apart?
I measured the shims, they are 32, 34 and 40 (though the bentley does not show a 40, only a 3.
I am going to have to replace some, but they seem to be unavailable,
so, my question is, could I have done something to change the end play while only changing the cam?
I think I am looking for a couple of 32's to bring me within the minimum,
can I look for 40 hp shims as well? How about 1600?
peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Fri Jul 08, 2016 6:30 am Post subject: Re: end play |
I've seen a lot of dished and worn shims in used motors so consider yours to be unfortunately normal. End play can change as parts wear so as long as your case and crank bearings are still tight then set your end play by the book and ignore whatever it was before. Remember to include a paper flywheel shim in your measurements. |
2Dokas Samba Member
Posted: Fri Jul 08, 2016 1:43 pm Post subject: Re: end play |
awesome, thanks for the tip on the shims and reassurance on the wear. _________________ 87 Doka 2WD Ej22,
56 Convertible |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Fri Jul 08, 2016 7:31 pm Post subject: Re: end play |
You'll find a similar topic in the Vintage Speed section...
The early Porsche engines used a single thicker shim, which can still be bought and are the same size as our 36hp shims.
I went this route when rebuilding my 36hp as 36hp shims are difficult to find. Take the measurement, calculate what you need and then order the single shim to get you there. |
Snort Samba Member
Posted: Fri Jul 08, 2016 9:35 pm Post subject: Re: end play |
txoval wrote: |
Good idea. A little bit of payback to the Porsche crowd, the ones responsible for drying up the supply of 36hp crank bearings. |
2Dokas Samba Member
Posted: Sun Jul 17, 2016 10:11 am Post subject: Re: end play |
Back to this project, gone out of town for a while,
not sure I really grasp the endplay adjustment, was not really clear that the end play would be greater with thicker or thiner shims, but I assumed thinner shims would result in more end play.
So, I installed the flywheel without any shims to measure the end play to be sure I ordered the correct size.
not a good idea from what I can tell, there was no end play when I tightened the nut.
so i took off the flywheel and put the shims back in and I get some movement again, but not as much as before.
I was at 18 and now about 10.
When I push in the flywheel to measure, there is some resistance and it goes into 18 or so and then when I let off the pressure it comes back to 10.
The engine spins fine,
What might I have done?
56 Convertible |
Snort Samba Member
Posted: Sun Jul 17, 2016 4:26 pm Post subject: Re: end play |
Are you measuring in mm or inches? Either way you should be reporting your numbers as 0.xxx etc. For example, end play in mm should be 0.07mm to 0.12mm according to the manual. If you are measuring in inches then 0.003" to 0.005", is close enough.
If you are having trouble with taking correct measurements and the crank is springing back after pushing on it, you might have something binding in your rod/crank clearances or rod/wrist pin/piston assembly. |
ridehard Samba Member
Posted: Mon Jul 18, 2016 1:46 am Post subject: Re: end play |
Snort wrote: |
I agree with Snort,
Chances are there is friction catching somewhere in you'r engine if you far mechanically enabled then take it all out and give it a clean!! it will run like a beauty after... |
2Dokas Samba Member
Posted: Mon Jul 18, 2016 2:19 pm Post subject: Re: end play |
I am measuring in inches, sorry, yes, 0.0018 was the original and now I am at 0.0010 with some push back.
the engine is sitting on my work bench,
okay, will start over, again.
next time I'll check the end play before putting on the pistons/heads
going to have to clean up and use that nasty curil gasket material again,
Curil T or Curil K ?
56 Convertible |
Snort Samba Member
Posted: Mon Jul 18, 2016 5:46 pm Post subject: Re: end play |
Are your measurements with or without a paper flywheel gasket in place? The paper gasket should add about 0.006".
Here's something else I just remembered. One time I had a problem with my crank springing back on me just as you described after everything was assembled. It turned out being a new type of flywheel seal I bought from Wolfsburg West. It had two lips on it that contacted the flywheel instead of the normal one, the one closest to the clutch was rubbing on the radius of the flywheel where the sealing surface runs into the back side of the flywheel. I went back to the normal one-lip seal and problem solved. |
2Dokas Samba Member
Posted: Tue Jul 19, 2016 7:47 am Post subject: Re: end play |
Snort wrote: |
With gasket, and no seal installed, as I recall from 40 years ago, we made sure the right shims were in before putting in the seal,
thanks for looking for alternatives to spitting the case again _________________ 87 Doka 2WD Ej22,
56 Convertible |
2Dokas Samba Member
Posted: Sun Jun 18, 2017 7:20 am Post subject: Re: end play |
Almost a year gone by and the engine still sits on the bench. My back is getting slightly better so its time to try this again.
I removed the head off one side and it stopped the condition where the end play remained steady, (I was pushing the flywheel in and it would push back).
It seems to be the wrist pins. Years ago when I started this project, they were very difficult to remove, I used a socket and a hard rubber mallet, all 4 of them were this way.
Upon reinstalling them, they needed the same treatment to get them in, I had my son help hold the pistons against the "tapping".
There was a sweet spot where the piston was totally free to move up and down on the wrist pin, but it was small, and if in the wrong position the piston would not drop if I pulled it up.
So, why would they have gotten tiger with age?
and more importably, what should I do? Bore out the wrist pin bearing?
My shims are also very warped and I think part of my problem with varying measurements was that I was putting them on the crank in different orientations.
thanks
56 Convertible |
Snort Samba Member
Posted: Sun Jun 18, 2017 12:42 pm Post subject: Re: end play |
With some motors the wrist pins push against the keepers and deform the aluminum of the piston. This can be corrected with a light hone or an adjustable reamer. The wrist pin should be a finger-push fit in the piston and rod bushing when assembling. I'm working on a budget rebuild right now trying to put the best of all my used parts into service and I had one piston with a tight pin that I worked on with a bit of 320 grit sandpaper and it took a bit of effort but it was enough to get it working freely again. |
2Dokas Samba Member
Posted: Mon Jun 19, 2017 6:36 am Post subject: Re: end play |
Ill give that a try, thanks
56 Convertible |
2Dokas Samba Member
Posted: Tue Mar 13, 2018 4:16 pm Post subject: Re: end play |
Worked great Snort, thanks!
I bought a small hone and used it on the push rod bushings, and some 320 on the pins and the slipped in like a hot knife in butter.
The flywheel shims were all pretty deformed, not flat, one was really bad, must have been against the flywheel a long time, and another was less bad but still not flat, so I bough new ones from WW.
My idiots guide says the front seal should be flush or slightly below the lip of the case, but thats not what I am getting, slightly out beyond the case. Keep trying or is it okay? Using the wood end of a hammer and another hammer for persuasion.
56 Convertible |
Snort Samba Member
Posted: Tue Mar 13, 2018 4:29 pm Post subject: Re: end play |
It can be hard to tell if the seal is fully seated into the case. But as long as the seal is not crooked and you've driven it home as much as you feel is necessary then you should be good to go. Various case designs, various seal designs, they don't all add up to one perfect way to describe how it should look when it's fully in. Put a smear of grease on the seal where it rubs on the flywheel and you will have done as much as you can. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Mar 13, 2018 5:38 pm Post subject: Re: end play |
here's what the seal usually looks like when it is fully seated in a 36 HP. They stick out a bit so you should be OK. Hopefully you have a single lip seal and not the double lip like in the pic. (Thanks hazetguy)
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
2Dokas Samba Member
Posted: Thu Jun 21, 2018 8:39 am Post subject: Re: end play |
Back again, thanks for being so patient with an old guy...
I want your opinion on the seating of this rear seal.
It has 2 small waving areas that you can see from this image, one at about 7 o'clock and the other about 6:45
bad? Redo? Okay?
thanks in advance.
Peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
Posted: Thu Jun 21, 2018 11:35 am Post subject: Re: end play |
yes, redo or it'll leak. and oil the lip when you install it. _________________ Rick
tasb wrote: |
sb001 wrote: |
