Mat195 Samba Member
Posted: Tue Jul 05, 2016 3:05 am Post subject: 6v starter |
can anybody tell me how much CR my little 6v starter motor will turn over assuming it's all in good condition. I'm hoping it'll cope with 8.0 cr, am I dreaming and what are my options while staying with a 6v setup? |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1298 Location: south san francisco
Posted: Tue Jul 05, 2016 11:19 am Post subject: Re: 6v starter |
it can cope no problem. the 1500-s type three had 8.5 and was 6 volt. get the red optima gel battery if you want it to spin faster. 800 cold cranking amps ! _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13283 Location: Tejas!
Posted: Tue Jul 05, 2016 2:12 pm Post subject: Re: 6v starter |
sgmalt46 wrote: |
it can cope no problem. the 1500-s type three had 8.5 and was 6 volt. get the red optima gel battery if you want it to spin faster. 800 cold cranking amps ! |
the 1500S Type 3 also had a different starter than a bug. Part number part number 311 911 021, .6hp vs .5hp. Seems minor, but use a bug starter on a 1500S dome piston type 3 and you will see the difference _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Jul 05, 2016 3:09 pm Post subject: Re: 6v starter |
Erik G wrote: |
sgmalt46 wrote: |
the 1500S Type 3 also had a different starter than a bug. Part number part number 311 911 021, .6hp vs .5hp. Seems minor, but use a bug starter on a 1500S dome piston type 3 and you will see the difference |
did not know that. good to know .still think he is ok. we probably need more info on his engine. is it a 36 or 40 ? i assume so since this in vintage speed. stock cam? or something bigger. that will change the cranking cylinder pressure.. a red top optima makes a stock 36 turn like its got 12 volts. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Mat195 Samba Member
Posted: Tue Jul 05, 2016 5:05 pm Post subject: Re: 6v starter |
That's great info, thanks very much!
Looks like a red top optima and a type 3 6v starter is in order. Not really doing a vintage speed build, will be doing a 1600, dual 36 drla's and around 8-8.4 cr, with a 2280 cheater cam, but thought I'd ask here since you all are the 6v experts!
I'd love to do a vintage speed 40hp build in future though, now that Wolfsburg west and others are supplying some nice aftermarket heads, carbs, cams etc! |
