AndrewCologne Samba Member
Joined: September 05, 2015 Posts: 71 Location: Cologne
Posted: Mon Jul 04, 2016 12:35 am Post subject: Correct Door window scraper install |
Hello everybody,
just got my split window bug on friday and Im trying to install new door window scrapers as the old ones are too soft and they slip down along the glass into the door bay when winding the window down.
I see the scraper comes with a lip where Im not sure how deep the scraper should be installed and if the lip will be above the edge of the door shell (Fig.1) or even a bit inside the door bay (Fig. 2).
In my case if installing like seen in fig.1 the scraper isn't close/tight enough to the window glass. So I just "assume" the Fig.2 way would be the correct one.
Can someone approve or even show me a close picture of his correct installation.
Thanks and best regards.
Andrew
_________________ 1950 Split Window Grey
1955 Oval Window Stratosilber
1982 Porsche 911 3.0 SC Black |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1463 Location: Finland
Posted: Mon Jul 04, 2016 7:01 am Post subject: Re: Correct Door window scraper install |
But then in fact I would need to install the scrapers in a way the lip will be inside the door bay. See fig.3 below.
Cause if I would flip the rubber then the smaller side won't be wide enough to make the cuts/holes for the wiring fit on the rubber.
So which of the above wire installations is the correct one? _________________ 1950 Split Window Grey
Posted: Mon Jul 04, 2016 8:54 am Post subject: Re: Correct Door window scraper install |
Thanks! _________________ 1950 Split Window Grey
