stevo96 Samba Member
Posted: Sun May 06, 2018 7:43 pm Post subject: What size hex tool? |
Hi guys, before I round these off what is the correct size of hex/Allen key I need? Bus is a 70 lowlight.
Joined: January 01, 2007 Posts: 16903 Location: sticksville, ct.
Posted: Sun May 06, 2018 8:03 pm Post subject: Re: What size hex tool? |
6mm _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22696 Location: NYC/Upstate/ROW
Posted: Mon May 07, 2018 12:30 am Post subject: Re: What size hex tool? |
You will need a hex socket to crack those, they are tight. If you try that’s with a key, it will get ugly.
After you get the hex key deeply into each one, give it a shot of penetrant WD40, then rap them with a hammer few times _________________ .ssS!
Randy in Maine Samba Member
Posted: Mon May 07, 2018 4:00 am Post subject: Re: What size hex tool? |
I had to use the socket attached to my impact driver to get those to come loose. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4526 Location: Oklahoma City, OK
Posted: Mon May 07, 2018 4:59 am Post subject: Re: What size hex tool? |
Would not even attempt till applying a rust penetrant several times over a day or two, especially between the hinge and hatch for the treads are in the hatch. Not sure what you all have down under but Kroil or PB Baster work quite well. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4431 Location: Stuck in Ohio
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon May 07, 2018 5:35 am Post subject: Re: What size hex tool? |
I'd get one of the hex sockets for that job. In addition to liberal use of PB Blaster, I would take that socket and tap it with a hammer. I long-ago learned the "100 taps" trick. Basically use a hearty spray of penetrant, then rap fastener 50 times quickly-approximately 50 in 30 seconds with good sharp raps with a hammer. Then spray again, and rap another 50 times.
The raps help break up the rust.
Doesn't guarantee success every single time but it certainly does increase your odds of success. _________________ Dave Cook
1973 Wild Westerner
My Thing |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2544 Location: Ocean Beach in Beautiful BLUE California
Posted: Mon May 07, 2018 7:17 am Post subject: Re: What size hex tool? |
vwwestyman wrote: |
Doesn't guarantee success every single time but it certainly does increase your odds of success. |
Tried all of those ideas. On 3 of the 4 bolts the head still stripped. When I swap out the rear hatch (being painted now) I will have to drill them out. Sigh. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Joined: August 31, 2013 Posts: 12875 Location: North Carolina
Posted: Mon May 07, 2018 7:22 am Post subject: Re: What size hex tool? |
Get a Snap-On T-45 torx (low quality bits will shear off) socket & pound it into the stripped head & turn them out, works every time. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Mon May 07, 2018 7:23 am Post subject: Re: What size hex tool? |
If you've got a welder weld a nut to that head and turn it off. Or sacrifice a 6mm allen key and weld it on. I've had to do that it works a treat because the heat from the weld breaks it loose in no time. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20302 Location: Sandpoint, ID
Posted: Mon May 07, 2018 9:00 am Post subject: Re: What size hex tool? |
Randy in Maine wrote: |
This is my usual process, too. _________________ nothing |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21536 Location: Oklahoma City
Posted: Mon May 07, 2018 10:39 am Post subject: Re: What size hex tool? |
I have had a handful of impact drivers...and I must say I agree...the Lisle impact driver is the absolute best quality tool of its kind out there. There may be others...I just have not found any better.
The others are right as well. Get quality driver bits. The ones that come in the Lisle sets are excellent.
Heat those screws up a bit. You only need about 300 F. Then put penetrating oil on and give it a handful of sharp raps and then let it cool.
As others have noted the rapping sets up vibrations that crack teh rust a little.
The heat expands the rust and the metal and as it cools it draws in penetrating oil. The thinner the oil the better...so this may be one of the best locations for the acetone/ATF mix.
Then get after it with the impact driver. Use a 3 lb hand sledge....nothing less. Ray |
timvw7476 Samba Member
Posted: Mon May 07, 2018 1:13 pm Post subject: Re: What size hex tool? |
another vote for impact driver!!!
I swear VW assembled those front doors/back hatches with unpainted
allen bolts, then came back amd gave them a protective coating of paint later,
making the 6mm tool a tight fit. I started hammering the allen portion in the
socket, then fitting the rest of the socket tool, then impact driver.
Nothing worse than rounding one of those little monsters. |
