Rebel2324 Samba Member
Posted: Mon Jun 27, 2016 4:41 pm Post subject: 36 HP oil strainer gaskets |
Am I missing something or are most places advertising 111-198-031 as 36 hp gaskets when they are actually 40 hp gaskets? And if this is the case where are you getting your gaskets from? Is there a better quality gasket available then the paper ones for these engines? Thanks. |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Mon Jun 27, 2016 4:54 pm Post subject: Re: 36 HP oil strainer gaskets |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111115488
Take care when removing the screen and you can make them last for several oil changes.
As far as other materials, I had one experience on a 40hp with silicone gaskets and they fell apart. I recommend sticking with paper. |
Posted: Mon Jun 27, 2016 5:10 pm Post subject: Re: 36 HP oil strainer gaskets |
Was also wondering whether there should be cap nuts on the studs. I'm trying to reduce the amount of oil leaks. |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Snort Samba Member
Posted: Mon Jun 27, 2016 5:30 pm Post subject: Re: 36 HP oil strainer gaskets |
I've had cap nuts on other motors and they seem to work pretty well, but they just don't look right to me on a 36hp and with good gaskets and copper washers you should be fine with standard nuts. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69833 Location: Phoenix Metro
Posted: Mon Jun 27, 2016 10:41 pm Post subject: Re: 36 HP oil strainer gaskets |
Rebel2324 wrote: |
Not originally but as far as I know you can use them.
My non-cap nuts don't leak anything noticeable though... I think you have bad copper seals or another issue. _________________ How to Post Photos
