jelwell1982 Samba Member
Joined: October 24, 2011 Posts: 73 Location: Lake Charles, LA
Posted: Fri Jun 24, 2016 8:11 pm Post subject: Wiper Switch locations |
Silly question but what it the wiper switch pattern.
Is all the way in the up position off or fully on?
Do activate the washer fluid do you push or pull?
Installing a new one tonight and nothing seems "normal".
1974 Super
Thanks |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Fri Jun 24, 2016 8:14 pm Post subject: Re: Wiper Switch locations |
Pull=squirt
one click up=slow speed
two clicks up=fast speed
doesn't seem normal? whats the deal? _________________ 1972 1302
HPMX 40's & 019 |
Posted: Fri Jun 24, 2016 8:16 pm Post subject: Re: Wiper Switch locations |
It Doesn't pull. There is no give at all. There didn't seem to be a wrong way to install it...hmm I'm sure it's possible though.
The turn signal and wiper switch are brand new and I just installed them tonight.
The turn signal snapped as soon as I clicked on the brights.
I'm considering sending them both back and trying again. |
Posted: Fri Jun 24, 2016 8:25 pm Post subject: Re: Wiper Switch locations |
That might be a good idea, the new ones i hear are crap.
You trying the air pressure, spare tire wash squirt as original? _________________ 1972 1302
HPMX 40's & 019 |
BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1821 Location: Oregon
Posted: Fri Jun 24, 2016 10:29 pm Post subject: Re: Wiper Switch locations |
I went through a couple different brand replacement switches and both were garbage. Finally bought a used German switch, which is what I should have done in the first place. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sat Jun 25, 2016 1:37 am Post subject: Re: Wiper Switch locations |
_________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5605 Location: 37.5N 77.1W
Posted: Sat Jun 25, 2016 6:38 am Post subject: Re: Wiper Switch locations |
Humm..never seen a bug with headlight washers. They must be good because after the first time you never have to worry about caked-on dirt or ice. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Joel Samba Member
Posted: Sat Jun 25, 2016 6:44 pm Post subject: Re: Wiper Switch locations |
runamoc wrote: |
Humm..never seen a bug with headlight washers. They must be good because after the first time you never have to worry about caked-on dirt or ice. |
It was an option in some European markets
