René R. Samba Member
Joined: July 06, 2015 Posts: 1712 Location: No. Calif.
Posted: Thu Jun 23, 2016 8:46 am Post subject: Installing inside door trim |
I got an upholstery kit from Sewfine -- it looks terrific. Now I want to install the stainless trim for the side panels, which I bought from Wolfsburg West.
But-- there is no way in hell the provided clips will fit into the channel on the back of the trim pieces. I've even tried filing / grinding them a bit but to no avail.
Is there some secret to this? Or a source for correctly-sized clips? Very frustrating. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Jun 23, 2016 12:13 pm Post subject: Re: Installing inside door trim |
I never bought anything from WW... if they sell the trim ,they must sell the small slide-in clips... no? You'd think so... how about the originals? _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Thu Jun 23, 2016 1:36 pm Post subject: Re: Installing inside door trim |
They supply the clips with the trim. I guess I need to call them to find out why they won't fit.
Unfortunately I don't have the original trim to recover the old clips from. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Thu Jun 23, 2016 5:49 pm Post subject: Re: Installing inside door trim |
René R. wrote: |
Unfortunately I don't have the original trim to recover the old clips from. |
I might have an extra early '55 door panel and trim. i'll look and advise, tomorrow. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
56Island Samba Member
Joined: July 08, 2010 Posts: 133 Location: North Carolina
Posted: Thu Jun 23, 2016 6:03 pm Post subject: Re: Installing inside door trim |
I purchased both the molding and the trim clips from WW and had no issue with the fitment. There are early and late model clips, are you sure you have the correct ones? _________________ Rock, stock and 2 smoking tail pipes. |
hutmo Samba Member
Joined: February 05, 2002 Posts: 37 Location: Pittsburgh, PA
Posted: Fri Jun 24, 2016 9:43 am Post subject: Re: Installing inside door trim |
Purchased the trim and the clips from WW... totally satisfied. You must have the wrong clips.
Silver clips... simple "L" shape. Slides right in.
HUTMO _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002 |
Posted: Fri Jun 24, 2016 9:47 am Post subject: Re: Installing inside door trim |
I have emailed WW to ask. The clips were sent as part of the set, they weren't ordered separately. But there's absolutely no way they will just slide right in so perhaps they did send the wrong ones.
To be continued! _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
txoval Samba Member
Joined: January 23, 2004 Posts: 3556 Location: The Woodlands, TX
Posted: Fri Jun 24, 2016 11:35 am Post subject: Re: Installing inside door trim |
Can you post a pic? |
Posted: Fri Jun 24, 2016 3:00 pm Post subject: Re: Installing inside door trim |
Problem solved. WW said they were the right clips, and to use a strong pair of pliers to slide them since they're tight. Well, I had tried that but they were much too tight. I decided to try flattening the raised ridge on the base of the clip to relieve some of the tension in the channel. A couple of hard squeezes with pliers lowered the ridge enough to allow the clips to slide, still with a lot of difficulty but at least it was possible. The picture below shows the slightly flattened clip above a normal one.
Once I finally got them in place it was smooth sailing. They're all mounted and they sure aren't coming off. Looks great.
