vamram Samba Member
Posted: Fri Jun 24, 2016 9:12 pm Post subject: Re: Needle Valve Question |
SB - yep, each time about 2 minutes after the car had sat for 20.
Busdaddy - good idea, never occurred to me to do that. Does a place like AutoZone carry one with the correct pressure? If so, I might as well throw one in as a backup. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51165 Location: Surrey B.C. Canada, but thinking of Ukraine
vamram Samba Member
Posted: Sat Jun 25, 2016 6:18 am Post subject: Re: Needle Valve Question |
Do they require or should I use a relay? I can power the relay off of the alternator's hot terminal (key on, pump on), then plug the pump to the relay.
[EDIT] The specs for the Holley pump say not for use w/ethanol gas. That's all we have around here, E10. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sat Jun 25, 2016 9:27 am Post subject: Re: Needle Valve Question |
Interesting, I didn't read the fine print, guess they are covering thier asses.
A relay is always a good idea but for a temporary test it may not be required, that's up to you and how deep you want to get in to it. Others run pumps directly off the coil permanently, eventually the ignition switch dies an early death, the relay is better. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
vamram Samba Member
Posted: Sat Jun 25, 2016 12:37 pm Post subject: Re: Needle Valve Question |
Unfortunately, I use this as a daily driver and need to find a fix this weekend. I looked for a pump locally, best I could find is an Empi. Installed it under the gas tank by the napolean's hat, wired it. Works, but the damn thing leaks at the base of the outbound brass fitting that gets connected to the fuel line. I'm picking up a Spectra brand one at the local autozone, same price.
Fortunately, the guy who sold it to me has agreed to take it back. But, man, there goes my Saturday. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sat Jun 25, 2016 8:11 pm Post subject: Re: Needle Valve Question |
Reading some more about it... the EMPI pump probably wouldn't have leaked of I had used something called PTFE tape on the threads of the fitting. Like the Teflon tape used in plumbing. Live and learn. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sun Jun 26, 2016 6:54 am Post subject: Re: Needle Valve Question |
One detail that may have come back to haunt me here...I didn't put grease inside the base of the current mechanical fuel pump when I installed it a couple of years back. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
djack47 Samba Member
Joined: October 21, 2010 Posts: 52 Location: Poteau OK
Posted: Mon Jun 27, 2016 1:47 pm Post subject: Re: Needle Valve Question |
Don't Laugh
Put Seafoam in your gas and on stuck parts
seriously, Jack |
vamram Samba Member
Posted: Mon Jun 27, 2016 2:38 pm Post subject: Re: Needle Valve Question |
djack47 wrote: |
Don't Laugh
seriously, Jack |
Yeah, i've used seafoam in the gas before and down the carb throat to burn off carbon deposits. Neighbors love the fluffy clouds.... _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sun Jul 03, 2016 9:09 pm Post subject: Re: Needle Valve Question |
Update/Successful conclusion:
Here's what happened w/the pump. I had the correct size rod. What happened is that I have a manual fuel cut-off valve in the line between the fuel pump and the carb bowl. I forgot to OPEN this valve before restarting the car w/the replacement pump. There was enough gas in the bowl to fire up the car and run it just long enough for pressure to build up in the line as the pump was trying to push gas to the bowl and BOOM! The seals that are in the pump blew (loudly) and gas poured out the mid-point of the pump until the car stalled a second later.
As to my ORIGINAL problem - here's the original (factory I believe) VW bakelite guide for the fuel rod on the left, the replacement one on the right.
Clearly the hole in the old one is significantly smaller than the new one.
I got a new mechanical pump and gaskets, installed it using the new bakelite and have since driven about 200 miles (including 60-miles round trip w/the wife to a Doobie Brothers concert last night! Those old rockers have aged well and sounded great!) w/*ZERO* stalls or stumbles due to fuel delivery issues. I'm pretty sure the old bakelite swelling was the cause of the problems I'd been having over the last month.
BTW - Busdaddy, I bought the Holley electric pump and have a relay ready to use w/it, but decided to keep it as a spare and continue running w/the mechanical pump for the time being.
Thanks all for your suggestions in resolving this problem!
Click to view image
Save the Supers!! |
Frank Bassman Samba Member
Posted: Mon Jul 04, 2016 7:43 am Post subject: Re: Needle Valve Question |
That is definitely what I would call "some schnidt."
Good call.
-Frank |
