richardc Samba Member
Joined: September 06, 2010 Posts: 269 Location: New Jersey & North Carolina
Posted: Wed Jun 22, 2016 7:52 am Post subject: 2005 Passat front caliper replacement |
Normally I'm in aircooled section, my question is what tools do I need to replace front caliper only Sons passat? Im going down NC to do it.
Thanks, Rich _________________ 1970 Ghia vert
1970 Beetle sedan
Joined: August 31, 2013 Posts: 12862 Location: North Carolina
Posted: Wed Jun 22, 2016 8:17 am Post subject: Re: 2005 Passat front caliper replacement |
Why does it need a caliper? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Jun 22, 2016 8:27 am Post subject: Re: 2005 Passat front caliper replacement |
7mm Allen to remove caliper slide pins, 11mm wrench for bleeder valve (DO NOT compress caliper piston without opening bleeder valve even to get caliper to clear lip on rotor. You WILL damage master cylinder if you don't.) Flat blade screw driver to remove tension/anti rattle spring. Jack, jackstands & 17mm lug wrench. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Jun 22, 2016 8:46 am Post subject: Re: 2005 Passat front caliper replacement |
What size wrench for hose to caliper? 11MM? _________________ 1970 Ghia vert
1970 Beetle sedan |
Posted: Wed Jun 22, 2016 9:05 am Post subject: Re: 2005 Passat front caliper replacement |
11mm for the hard line to the caliper, 10mm for the line bracket to caliper. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Jun 22, 2016 9:17 am Post subject: Re: 2005 Passat front caliper replacement |
Perfect, just what I needed. Thanks again _________________ 1970 Ghia vert
1970 Beetle sedan |
