Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Tue Jun 21, 2016 7:00 pm Post subject: 72 Superbeetle - fresh air hoses |
I completely removed the fresh air box, disassembled, cleaned and about to put it back in. But the hoses that connect to it are loose in both "cavities" on left and right.
How does one reconnect these hoses? I can find no access holes or openings at the bottom. And it seems there are two sizes or hoses going down. I searched and found one good thread on the beating of a bug, but not much seems to be said about the fresh air hoses.
I almost contemplated removing the hood to see if my hand can squeeze down there, but after searching threads on hood removal I got scared.
Any ideas? _________________ ---------
Rubber Duck
1974 Westfalia |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Tue Jun 21, 2016 7:45 pm Post subject: Re: 72 Superbeetle - fresh air hoses |
There are no hoses from fresh air box to the vents, Its an insulated wrap. _________________ 1972 1302
HPMX 40's & 019 |
Posted: Tue Jun 21, 2016 10:46 pm Post subject: Re: 72 Superbeetle - fresh air hoses |
cletus_zuber wrote: |
There are no hoses from fresh air box to the vents, Its an insulated wrap. |
I meant from the body cavities just below the hood hinges on left and right. There are hoses that come from below and they connect to the airbox I think. My biggest problem is how to connect them to whatever they connect to at the bottom.
Btw...what's an insulate wrap? _________________ ---------
Rubber Duck
1974 Westfalia |
TheRustySuper Samba Member
Joined: June 24, 2009 Posts: 2076 Location: New Albany, IN
Posted: Wed Jun 22, 2016 6:13 am Post subject: Re: 72 Superbeetle - fresh air hoses |
So you're talking about the hoses that go from the depths of the front quarter panel up to the fresh air box, correct?
In that case...
There's one hose on each side that connects to the heater channels down in your front quarter panels, this area is often referred to as the "black hole" because of its ability to swallow up whatever you drop down there for eternity. Those hoses that connect to the heater channel go to a fitting in the trunk that splits it into multiple hoses that go to your defrost.
Unfortunately, it's a real bitch of a job to get the hoses re-connected. Pull back your carpet inside the car just forward of the door frame. There should be a small access hole of sorts. Shine a light in there--you'll probably see 40 years of debris. Clean that out, and you should see where the hose connects to. As far as actually connecting the hose, you've gotta get creative. You could remove the hood for easier access down there, I've seen people cut that access hole open and attach them that way.
Hope that helps some! _________________ My '72 Super |
Posted: Wed Jun 22, 2016 6:30 am Post subject: Re: 72 Superbeetle - fresh air hoses |
OK thank...so in other words, no easy way that I'm missing.
I peeled back the carpeting on the passenger side and could kind feel a hole there, but on the driver's side, there doesn't seem to be a hole. Maybe it got welded up...no wonder the remnants of the hose are so free moving there.
Oh well. Thanks for the help, but looks like I got some hard work to do. _________________ ---------
Rubber Duck
1974 Westfalia |
Maddel Samba Member
Posted: Wed Jun 22, 2016 4:36 pm Post subject: Re: 72 Superbeetle - fresh air hoses |
Maddel, thanks for that. I have now ascertained that I have that piece, at least on the driver's side. The hoses were loose anyway, so I pulled it all the way up and see this.
Great. So that short piece of hose connects to "something" at the bottom. This must be an impossible hose to fit! Judging from how torn up it is the PO must've given up at some point.
Any tips guys? _________________ ---------
Rubber Duck
1974 Westfalia |
Maddel Samba Member
Posted: Wed Jun 22, 2016 9:54 pm Post subject: Re: 72 Superbeetle - fresh air hoses |
Rubber Duck wrote: |
... So that short piece of hose connects to "something" at the bottom... |
Not a Super Beetle but the pic below shows that "something" on the right hand side of a 1960 Bug:
Notice the small "access hole" inside the car at the footwell area.
x2 what TheRustySuper said:
TheRustySuper wrote: |
Unfortunately, it's a real bitch of a job to get the hoses re-connected. Pull back your carpet inside the car just forward of the door frame. There should be a small access hole of sorts. Shine a light in there--you'll probably see 40 years of debris. Clean that out, and you should see where the hose connects to. As far as actually connecting the hose, you've gotta get creative. You could remove the hood for easier access down there, I've seen people cut that access hole open and attach them that way. |
Pic taken from this web site (all German):
http://www.old-bugs-never-die.de/meine-k%C3%A4fer/vw-1200-baujahr-1960/bilder-der-restauration/
Google translated version:
https://translate.google.de/translate?sl=de&tl...uration%2F
Here is how I routed the three smaller hoses at the trunk:
Posted: Thu Jun 23, 2016 7:33 am Post subject: Re: 72 Superbeetle - fresh air hoses |
Thanks Maddel, the photos you posted are very helpful. I did not peel back the carpeting that far to reveal the hole. That means the "hole" I have on my passenger side is probably rust.
Look like I got some contortions to do soon! BTW, your trunk is amazingly clean. _________________ ---------
Rubber Duck
1974 Westfalia |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Posted: Fri Jun 24, 2016 1:51 pm Post subject: Re: 72 Superbeetle - fresh air hoses |
Holee Smokes Pete! That's some thread! Yours did come up in my many searches, but the thread was so long that I gave up searching through it for the "holes of doom" section.
So skinny arms eh! I might have to get one my nimble-fingered daughters do it for me. And you did it all with the hood in place? I guess its all by feel right? I'm not sure how one could even look down there...I guess you just stuck the camera in to take the shot eh!
Thanks for the inspiration! It appears that the "Y's" come up almost to the top. That would make for easier hooking-unhooking for future. _________________ ---------
Rubber Duck
1974 Westfalia |
owdlvr Samba Member
Joined: June 23, 2008 Posts: 684 Location: Squampton BC
Posted: Fri Jun 24, 2016 4:16 pm Post subject: Re: 72 Superbeetle - fresh air hoses |
You'll want to be sure you have all the carpet nails out of interior before sticking your arm down there. Otherwise, it's rather uncomfortable! _________________ ---
Instagram: @DaveHord
1971 1302s - Salzburg Tribute the #RallyBug
1958 Beetle
1975 Beetle
1973 Super Beetle
1993 C3500 with Cummins swap
1967 MGB
1963 MG Midget |
Posted: Sun Jun 26, 2016 7:04 am Post subject: Re: 72 Superbeetle - fresh air hoses |
Thanks for the inspiration! It appears that the "Y's" come up almost to the top. That would make for easier hooking-unhooking for future. |
Yes, I did it with the hood in place. Getting a shot of the holes of doom really helps to see what you are trying to do, but almost all of it is by feel.
The tricky part was getting the old hose off the bottom of the pipe at the bottom of the holes of doom. They temp to be stuck on pretty good after being their for years and years.
A narrow, hooked scraper helps to get the old stuff off. If you dont get the old hose off you will have a heck of a time putting the new one on.
That's why I took a pic down the holes of doom to see it I'd got it all off.
Once you have it cleaned off, get the new hose and try to flare the end of the hose slightly with your fingers, and smear a small amount of grease on the end, then when you are fitting it, put one arm and your hand down the holes of doom whilst twisting the new hose onto the pipe. It's doable, but really tricky!!!! Good Luck _________________ My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189 |
