easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Wed Nov 02, 2016 11:26 pm Post subject: Re: Reproduction Westfalia SO-42, SO-44, Dormobile Pop-Top Seal |
Sample arrived.
Unfortunately needs revision.
Markups provided...
The bummer is... several things weren't even within spec. Not like I was just nitpicking & finding new things I wanted to change. Like a curve was supposed to have a radius of say 25mm.... and it was like 5mm.
Sad trumpet sound... wah, wha, whaaa
I'll report back when I get feedback on the markups. Hopefully soon.
EDIT: I already heard back... the rep was apologetic & said they'd adjust tooling. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Col_Forbin Samba Member
Joined: November 25, 2011 Posts: 84 Location: Austin, Texas
Posted: Mon Nov 07, 2016 4:12 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
man that's too bad, what a pain.. thanks a ton for taking the time to go through this process! _________________ Goin' where the climate suits my clothes
Levon the 66 Westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=655780
71 Deluxe Bay |
easy e Samba Member
Posted: Mon Nov 28, 2016 7:32 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
The manufacturer reported today that they can't make the seal...
"Because of a different steel plate, your rubber seal is a one time extrusion, but our rubber seal needs to be a two step process. This caused three of your design parameters to be difficult to control. Our production department tried many times to meet the requirements, meanwhile, we expended an additional $500 on extra molds, but still not meeting the requirements, truly sorry Evan."
I'll see if they can do it out of standard rubber... instead of EPDM.
This company makes seals for Volvo, so I believe there is an inherent issue that may be unresolvable.
I'll keep looking for options (to get the correct shape). _________________ aka: Evan
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Nov 28, 2016 1:42 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
I've been in contact with Evan (easy e) regarding his efforts but have been waiting to see if his source could come through before I proceeded. Now that his efforts have been (apparently) unsuccessful, I thought I'd share what I have found.
Firstly, I'm not trying to step on anything easy e has done thus far, and I'm thankful for his efforts to date. He's done a lot of heavy lifting.
I have a local company that produces EPDM seals for cars all day long and have contacted them regarding reproducing this seal. I've provided a chunk of NOS seal in perfect condition to them to investigate. So far it is doable for them in their opinion.
If it seems reasonable for me to proceed with sourcing this from this US company, I'd like to see what others think.
So, what shall I do? |
easy e Samba Member
Posted: Mon Nov 28, 2016 2:07 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
You wouldn't be stepping on my toes...
I just wanted the seal to be realized... for all of us pop-toppers!
I can send you the drawing & I probably still have a recognizable piece of seal.
It should save some design effort ($).
Cheers for picking up the baton ) _________________ aka: Evan
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Mon Nov 28, 2016 3:24 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Cheers to both Evan and Nancy for trying to help us all realize a near correct pop-top seal, better than what we've been offered so far. Thanks to both of you!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Nov 28, 2016 5:58 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Agreed, yay for both of you!
Bummer the first supplier tapped out, hopefully Nancy's can get er' done, depressing yet exciting at the same time. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22465 Location: Escondido CA
Posted: Mon Nov 28, 2016 6:33 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Id think this is the same for the full pop tops through the bay Westfalias? No? If it is Id be interested in it as a replacement for the bulb type on there now. With that said - I would need a bunch more than the turret top crowd. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Mon Nov 28, 2016 7:00 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
I've been wondering if Dormobile tops or any of the bay tops take this same seal. If so, the market is greatly expanded making the cost a bit more palatable.
Anyone know if there are any other applications for this seal? |
Posted: Mon Nov 28, 2016 7:52 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
This first pic is the same stuff available to you - modern Bulb type. I have issue with the wide strip for the end lip to roof rack seal, just the main gasket.
This is of a dormobile from xavi_242. Left one is OG. Looks like the one you are making and the type I removed off my 77 pop top. I cant find an og shot of Bay rubber.
t3kg wrote: |
1964 1500 S
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5510 Location: 1st Coast
Posted: Tue Nov 29, 2016 3:51 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
I'm ordering this one because I have 2 other replacements I do not like.
LAGrunthaner wrote: |
Yes crofty I like that even better.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
delx23 Samba Member
Posted: Tue Nov 29, 2016 11:27 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
i don't have my camper here so i can't check measurement but i need to order it too, can u share total length needed for pop top?
Thanks |
Posted: Wed Nov 30, 2016 3:23 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
I need to measure mine but I would think 4 meters would cover it but we need to measure it first to be sure. It sure looks like a much better seal than all the other repros.
delx23 wrote: |
Thanks |
Maui Roadsters
Lind wrote: |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14277 Location: Casa de Oro, California
Posted: Wed Dec 07, 2016 9:33 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Somewhere in this thread I think it was mentioned but I'll bring it back up as I have seen this seal. It is from a Ford Windstar 1995 to 2003 rear hatch and front door. Though not exactly right on either side of the U but the clamping part is big and strong. The donut side is huge and the squeegee side is huge. Maybe a possible replacement for the Westy seal? They are extremely well made and supple.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19673 Location: Land of Whine and Phonies
Posted: Wed Dec 07, 2016 11:07 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Hard to tell but I don't think seal would be long enough to touch the body _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Sat Dec 10, 2016 11:59 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Agree, I like the other one best.
crofty wrote: |
Hard to tell but I don't think seal would be long enough to touch the body |
Maui Roadsters
Lind wrote: |
BarryL Samba Member
Posted: Sat Dec 10, 2016 7:18 pm Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
crofty wrote: |
And this is too wimpy, huh. http://www.stylintrucks.com/parts/precision_parts_...3925-.aspx |
easy e Samba Member
Posted: Tue Dec 13, 2016 9:24 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
I'd go with the seal I posted before that. _________________ Your Vanagon sucks, Stop waving at me.
easy e Samba Member
Posted: Fri Dec 16, 2016 11:13 am Post subject: Re: Reproduction Westfalia SO-42 SO-44 Pop-Top Seal |
Nancy has made some promising progress with the vendor she's working with!
She sent me a drawing & I provided her some comments. I can't wait to hear how the vendor responds. Big props for her taking this to the next step.
Vendor's first sketch for review is labeled "Rev. 0" at the top-center of the pic. Remainder of stuff around it is my comments.
