rybotix123 Samba Member
Posted: Tue Jul 07, 2020 10:17 am Post subject: Oil Filler tube to Block sealant? |
Hi All-
I have a 1.9 wbx ....mostly apart as I replaced mounts. I had a fair amount of oil leaking at the filler tube/block junction. I have a gasket and am ready to put it back together.
Do I use gasket and sealant? If so what and how? I have a fresh tube of Reinzosil....
Thanks in advance! |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Tue Jul 07, 2020 3:14 pm Post subject: Re: Oil Filler tube to Block sealant? |
A light smear of any good adhesive on the paper gasket..both sides will not hurt anything. It may be tough to clean up for the next fellow that takes it apart though. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10256 Location: N. Idaho
Posted: Tue Jul 07, 2020 9:48 pm Post subject: Re: Oil Filler tube to Block sealant? |
Agree and if I recall that is a tough spot to deal with after install. I put some product on a couple likely leakers I just didn't want to see after my rebuild, so I applaud the move also. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Tue Jul 07, 2020 10:44 pm Post subject: Re: Oil Filler tube to Block sealant? |
Thanks all...will do! |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed Jul 08, 2020 7:27 am Post subject: Re: Oil Filler tube to Block sealant? |
Hylomar. Seals and easy to clean up if you have to. |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Wed Jul 08, 2020 9:08 am Post subject: Re: Oil Filler tube to Block sealant? |
No gasket, I used Permatex® Black. Excellent seal against hot oil. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
